*!Build of the year candidate!* Strange PNW Build: E30+Volvo
  • adam.nonis
    • Apr 2017
    • 755
    #361
    Starting the mold making process. I’m using a borrowed hood and was asked to not clean it up at all, so I took the jankiest vinyl I could grab and wrapped it first to protect the patina. Gonna mean I’ll have a decent amount of work to do to the mold before I can pull a part, but it’ll be nice to have.
    • ForcedFirebird
      • Feb 2007
      • 8300
      #362
      Sounds great! Reminds me of a Billy Boat m20, with a bit more crisp. Well done.
      john@m20guru.com
      Links:
      • adam.nonis
        • Apr 2017
        • 755
        #363
        A quick little lunch break job. Pull handles. Going minimalist on the door panels for now. May get fancier later.
        Still need to machine some caps to cover the ends, but they’ll work for now.
        • adam.nonis
          • Apr 2017
          • 755
          #364
          With end caps and a plate to make sure the caps stay straight.
          Another project I’ve been messing with. Hope to have it done by the end of next week.
          • parkerbink
            • Jun 2004
            • 10137
            #365
            What can't you do???
            Amazing!
            • geckster
              • Apr 2018
              • 2
              #366
              I've just read through the whole thread and must say that your project is fantastic. Your bandwith of skills is really impressive.
              • adam.nonis
                • Apr 2017
                • 755
                #367
                Amazing!
                Brain surgery. But I’m reading a book about it.
                Thank you. I’m just a guy who likes to work with my hands.
                • 2mAn
                  Señior Mod
                  • 20249
                  #368
                  Originally posted by adam.nonis
                  Brain surgery. But I’m reading a book about it...
                  I find YouTube videos are much more helpful with hands-on stuff like brain surgery
                  Simon
                  Current Cars:
                  -1966 Lotus Elan
                  -1986 German Car
                  -2006 Volkswagen Jetta TDI
                  Make R3V Great Again -2020
                  • Nader393
                    • Dec 2015
                    • 408
                    #369
                    [QUOTE=adam.nonis;4889578]Just like everything else, trying to do something simple turns into more. Just trying to install a short shifter and the selector on the trans’ bushing was shot. Looks like you’re just supposed to replace it whole. I just bored out what was left and made some aluminum replacement bushings.
                    You're doing some interesting things, but that shifter bushing is also a pivot joint; it needs to be a durable, slippery material, like delrin or bronze. The aluminum will eventually bind/gall, then wear out.
                    '91 325i
                    • Staszek
                      • 2533
                      #370
                      Every time I come back to this thread it gets better and better!
                      • adam.nonis
                        • Apr 2017
                        • 755
                        #371
                        Guess that’s when I’ll replace it. Any idea how much it rotates? Or what motion causes rotation at that joint? Just trying to gauge how fast I should get a replacement here.
                        • LJ851
                          • 7918
                          #372
                          Still loving this thread, keep it up !
                          How did you attach the cnc "volvo amazon" plate to the valve cover ?
                          Lorin
                          The M30 is God's engine.
                          • adam.nonis
                            • Apr 2017
                            • 755
                            #373
                            Welded a couple spots around the edge and plug welded from the inside.
                            • IRON-E
                              • 16548
                              #374
                              Speechless, way to go man. You're the truest definition of *built not bought*
                              @IRON-E30 aka Edwin:D
                              • adam.nonis
                                • Apr 2017
                                • 755
                                #375
                                So, I think I killed my fan clutch last night. I was doing a bunch of service stuff (timing belt, tensioner, cam seals, water pump, hoses and belts) and while I had the fan off I degreased it and scrubbed it down. Last night on the way home it started running hot. Since I replaced the thermostat a while back, it hasn't run anywhere but dead straight up once it warms up. I got home and started trying to think through the possible issues. Air pocket, too much anti-freeze/not enough water, etc. I'm pretty good at getting all the air out of the system, so I don't "think" it's that. On the way to work this morning, if it would start running hot, I'd shift into a lower gear and bring the RPMs up and it would start cooling down (I know that technically decreases load, but not much on a flat road). Once I got to work I popped the hood and while it was still hot (car off), I could freewheel the fan with ease. When it's warm, isn't that when the fan should lock up and be closer to 1:1?
