Project Weißer Regen: 91 318iS Restomod
  • econti
    • May 2014
    • 1143
    #511
    I was intending on ordering one for my project. Perhaps not now
    • Jordan
      • 12913
      #512
      The steering coupler on airbag cars has been NLA for awhile now, it may come back available but who knows. I had two good used ones, and I vapor honed the best one.
      Looks damn near new.
      https://mtechniqueabs.com/
      • TeXJ
        • 1914
        #513
        i'd hate to know how much that paint work is gonna be O.O
        1990 325is
        m52b28
        3.73lsd
        g260 (1987 325is 5spd tranny)
        • parkerbink
          • Jun 2004
          • 10138
          #514
          One ocd restored & rebuilt S14 drivetrain?
          • TeXJ
            • 1914
            #515
            haha
            1990 325is
            m52b28
            3.73lsd
            • Jordan
              • 12913
              #516
              Preparing bits and bobs to take with me to Imperial Collison the day after Christmas so I can get the chassis down on its suspension.
              Fuel tank with new fuel pump, sender, all new OE soft lines, Oetiker clamps throughout and some foam to replace the stuff thats long gone.
              Fuel filter carrier.
              Rear subframe side plate hardware
              Steering knuckle, shaft, upper and lower column, NOS MTech 2 steering wheel.
              • D.Martijn
                • Sep 2016
                • 1024
                #517
                Hmmm makes me wonder, since when I replaced my fuel tank with an aftermarket one I have a humm coming from my fuel pump. I don't think I used the foam as the original one crumbled to pieces. Could this be the cause of the vibration..?
                Did tou paint those hex screws for the rear subframe hardware
                1990 325iX Touring - November 2018 R3V Car Of The Month
                1980 Volkswagen Golf mk1 1.1
                1974 BMW 2002 Touring
                Instagram
                • Jordan
                  • 12913
                  #518
                  I rather doubt it, the hum is almost certainly from the pump itself. Is it a genuine VDO pump or any number of aftermarket options. All the cheapie pumps I've installed were much louder than stock, and the original VDO comes with a 4mm thick closed cell foam rubber sleeve over the pump body for noise attenuation.
                  The Wife's F25 loaded up with all the E30 parts needed for tomorrow. Complete front and rear suspension assemblies, fuel/brake lines, complete fuel tank, differential, four brake rotors, steering column, steering wheel, all of the individual bagged hardware assortments, and of course the tools needed for installation.
                  All four tires laminated with shrink wrap so the tires don't get dirty rolling over body shop dust.
                  Then a restored M3 header, muffler and differential to drop off while I'm there.
                  • Reichart12
                    • Aug 2012
                    • 2163
                    #519
                    Beautiful work. I've been thinking about replacing fuel lines as I have a bit of gas smell escaping somewhere. Seeing your tank all prepared is definitely my goals.
                    Instagram: Reichart12
                    • mjweimer
                      • Dec 2015
                      • 648
                      #520
                      Impeccable work Jordan. I followed the last build too and absolutely love the attention to detail in your work.
                      I see that you installed the control arm bushings prior to install of the subframe. Do you have a trick to clocking these or do you use a non-drying lube? I was thinking of doing similar pre-assembly on my project.
                      Thanks,
                      MJ
                      • D.Martijn
                        • Sep 2016
                        • 1024
                        #521
                        It's the same pump as before, it didn't have the hum before the swap though.
                        Instagram
                        • jeenyus
                          • Aug 2011
                          • 2064
                          #522
                          Lovely - but I don't like how seeing this makes me feel like my upcoming doors/glass-out paint job still won't be enough. Sigh. Oh well, I'll just sit back and watch this.
                          This. I get that feeling a lot. lol
                          • Jordan
                            • 12913
                            #523
                            Had a very productive day up at Imperial Collision today putting everything on the car and ultimately lowering it down and off the rotisserie for the first time in over a year.
                            Fuel and brake lines installed:
                            Fuel tank mounted up:
                            Add one fuel filter assembly:
                            Hello there swaybar:
                            Front subframe, steering rack and control arms installed as an assembly:
                            Add a strut:
                            Rear subframe, trailing arms and axles installed as an assembly:
                            Add some LSD pumpkin spice:
                            Rear shock mount poking through into the impeccably finished trunk compartment:
                            Flipped right side up for rotor installation:
                            Steering linkage (nevermind the missing pipe on the rack I'm waiting on from Germany)
                            Steering column installed:
                            and that is all she wrote for today!
                            • Powling
                              • Jan 2015
                              • 1290
                              #524
                              WOW! Crazy how fast everything can come together with proper planning.
                              Steve • Toronto
                              1991 318is • Brillantrot
                              Build Thread
                              • fresh_TD
                                • Aug 2013
                                • 2457
                                #525
                                Beautiful work. You should stroke the M42 going in the car.
                                Sent from my Pixel 3 using Tapatalk
                                '91 318i (Alpine) - daily
                                '88 325ix (Zinno) - drive here and there!
