What did you do to your E30 today?
This is a sticky topic.
  • slammin.e28
    שמע ישראל
    • 12054
    #5266
    Started it.
    • MPLFoster
      • May 2013
      • 1490
      #5267
      new distributor cap/rotor, ignition coil, TPS and and an oil change. Followed by a spirited drive up chukanut and back.
      form.follows.function IG @mplfoster
      • Eufonik
        • Feb 2014
        • 459
        #5268
        Took care and upgraded the pedal box. Brake pedal with Derlin bushings and the clutch pedal with Oilite Bronze bushings. Pain in the butt!
        Instagram @prsvere88
        Transaction Feedback
        • IceWhite
          • Jan 2015
          • 945
          #5269
          Not today, but about a month ago.
          Before:
          After:
          1990 325i
          2004 330i Individual 6-speed
          • barbierij
            • Sep 2012
            • 1294
            #5270
            My dad put this cover on his mtech1 wheel
            Sent from SPACE using Tapatalk 2
            FS NY: two Audiobahn A235HC amps and audiobahn 1farad capacitor
            Saab/GM tech2 programming
            My for sale thread
            1990 325iX for sale or part out
            Did you buy something from me? Please leave feedback!
            Originally posted by K20RI_211
            And I have to ask if you make a hobby out of thread-bombing with retarded questions?
            • rzerob
              • Jun 2013
              • 2315
              #5271
              Welded, primed and painted seat brackets so I can install my seats tomorrow. Switched parts around in my cluster trying to get everything to work. Currently I have my battery on trickle charge.
              • rzerob
                • Jun 2013
                • 2315
                #5272
                Removed 6 button OBC and wiring harness. Installed 13 button OBC and wiring harness. The light bar is dead so I need to order a new one. Installed new hood strut. Painted headlight surround rings. Cleaned and conditioned my seats. Hopefully I get them installed tomorrow.
                • rzerob
                  • Jun 2013
                  • 2315
                  #5273
                  Installed seat brackets to driver side seat and installed seat. Hopefully passenger side tomorrow. Removed CD changer. Replaced e-brake accordion and plastic handle with leather boot and leather handle. And vacuumed the carpet.
                  • Toodaloo
                    • Sep 2014
                    • 872
                    #5274
                    Did a little front end cleanup. Sanded down my ugly break ducts, primed and repainted them in a gloss black, used some rubber undercoating on my ugly lip, and some on my oil cooler trim! Next step: shave front valence fill in any ugly spots, prime, and paint with color matched paint! Sooon!
                    I also hard wired my POINTLESS window cutout and wired in my sub amp ignition line so it works as a sub cutout. Oem plus ftw!
                    Check out my Alpine's DEAD build thread http://www.r3vlimited.com/board/showthread.php?t=348571
                    E36 M3 Build thread http://www.m3forum.net/m3forum/showthread.php?t=597637
                    • rzerob
                      • Jun 2013
                      • 2315
                      #5275
                      Installed seat brackets to passenger side seat and installed seat, finally.
                      • fporro
                        • 1860
                        #5276
                        friends e30's over the weekend.
                        - re-greased brake caliper sliders
                        - re greased brake pads for squeal free braking
                        - adjusted throttle and kick down cables
                        - added 16x7 et25 Hartge rims.
                        - Adjusted trunk latch
                        - swapped ICV
                        on 318iS we did
                        - installed new rear rotors.
                        - installed rear shock mounts reinforcement plates
                        • rzerob
                          • Jun 2013
                          • 2315
                          #5277
                          Finished my exhaust. Installed adapters and wheels. The rears are rubbing really badly. And installed new power steering pump. It was a fairly busy day.
                          • E30Jigzaw
                            • 1197
                            #5278
                            Started to install ix flareson my sedan .. Looking for a drivers side skirt if anyone has one please pm me ..
                            Buy e30 cup holders
                            http://www.r3vlimited.com/board/show...41#post4159541
                            Buy BMW Motosports handles
                            http://www.r3vlimited.com/board/showthread.php?t=302846
                            Buy BMW MOTORSPORT valve covers http://www.r3vlimited.com/board/showthread.php?t=330146
                            • runnoelrun
                              • Apr 2013
                              • 32
                              #5279
                              Gave it some real TLC.
                              Mid life crisis.
                              • rzerob
                                • Jun 2013
                                • 2315
                                #5280
                                I installed a longer serpentine belt and bled my new power-steering pump.
