Japandrew73's OEM Euro Restore
This topic is closed.
  • kishg
    • Sep 2006
    • 2624
    #871
    why kph? do you live in canada?
    '12 F30 328i Sport Line
    '91 SpecE30 #523
    '00 Ford F-350 Dually Tow Vehicle
    BMWCCA #360858 NASA #
    128290
    • Miasma
      • Apr 2007
      • 2009
      #872
      Thanks for the info on the different keys.
      • Japandrew73
        • 2164
        #873
        Originally posted by Jean
        Andrew - you'll need a different oil pan/oil pickup you know that right?
        Jean, thank you I didn't even realize this. I need a front sump pan, correct? Which model pan should I be using?
        This is a Euro restoration. Which means restoring it to Euro Spec.
        • Jean
          • 18228
          #874
          Doesn't look like you read this thread - http://www.r3vlimited.com/board/showthread.php?t=100614
          Read all of it. E32/e34 535/735.
          • kishg
            • Sep 2006
            • 2624
            #875
            planning on getting a euro title too? euro insurance?
            '91 SpecE30 #523
            128290
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              #876
              At the end of the build, he will be swapping in a euro owner I hear.
              • kishg
                • Sep 2006
                • 2624
                #877
                who will r3v and go buy an e36
                '91 SpecE30 #523
                128290
                • kdevitt
                  • Dec 2008
                  • 278
                  #878
                  Not all of us in Euro land use Kph :)
                  1990 Diamond Black E30 320i Touring
                  1994 Jet Black E36 320i
                  • Japandrew73
                    • 2164
                    #879
                    I have on idea how I missed this. Thank you very much.
                    And to criticizers of the KPH odo, not only is it euro spec, but it's to my personal spec that I think looks and operates the best. And that's really what matters most is what you think of your car.
                    • E30FourLife
                      • Aug 2009
                      • 217
                      #880
                      Very impressive work Andrew! Cant wait to see the outcome of the swap!
                      00 Audi S4 2.7tt 6MT
                      02 Audi S6 Avant 4.2
                      • Japandrew73
                        • 2164
                        #881
                        So when taking apart my speedo, I can clearly see what went wrong. I tightened the tensioning screw a bit too tight and it made it too tight for the gears to spin smoothly, this caused the top, little gear to shred into pieces, and teeth on other gears to break. So here is a pic of the US gears.
                        And here are the newly installed Kilometers per Hour Gears.
                        Once installed and put back together, it fully works in Kilometers!
                        Also, might also note that a girl who's a friend of mine at my school is an excellent parallel parker and scraped the edge of my rear euro bumper trim. She thought nobody saw and drove away because she wasn't a good enough parker to fit in the spot with her giant 2009 SUV every kid seems to inherit at the age of 16 in Newport Beach. Little did she know my friend was in his car right behind her and told me about it. I nailed her with the expenses however I went easy on her due to the fact that it's super awkward to ask somebody about it. The scrape really wasn't bad at all and wet-sanded out to perfection. All I asked her for was the $30 for the new mounting parts. And that's what I got.
                        Nothing really else to take pictures of. The trim just fits more snugly now and the old mounting bracket on the left side wasn't in the best shape but the other one was perfect, so I only ordered one. But Kronus, I finally got the correct hardware to secure the rear bumper end pieces. Thanks for the tip about hardware being there when I originally installed the rear bumper.
                        I have bought a b35 oil pan and pump that will be arriving in a week or so. The cold tank pile will have to wait, no use in paying for two separate batches. Anyways with the bottom end off, I've had it looked at and the estimated mileage on the bottom end is roughly 50,000. The top end has a none factory stamp, it says "RPS" on the edge of top of the head. I've never heard of this company and google hasn't brought any answers. I know the head has been rebuilt though, however if I could contact the people who rebuilt the head, I could actually find out what exactly they did, and how long ago. Pretty cool though, I've got a very nice engine to work with :)
                        • Jean
                          • 18228
                          #882
                          Just do a carfax check on the VIN instead of guessing the mileage ;) It can look the same with 150k miles. You would have to inspect the bearings, so it's easier to run a carfax.
                          That's pretty cool that they still make the mounting kit, front kit is available as well?
                          • Japandrew73
                            • 2164
                            #883
                            Will do on the carfax. Yea both mounting kits are still available in full and for cheap too!
                            They have part numbers for each individual piece of hardware, and then a part number for the mounting kit which includes all hardware. Very handy.
                            Front mounting kit: 51 11 9 057 083
                            Rear mounting kit: 51 12 9 057 084
                            (rear doesn't include mounting brackets, as the front does)
                            Both are roughly $50 each.
                            • TrentW
                              • 2815
                              #884
                              Thanks for beating me to that Jean--if someone says they can tell the miles on an engine that way they'd either have to have x-ray vision like Superman or just be full of bs.
                              • Jean
                                • 18228
                                #885
                                Look at the timing too http://www.r3vlimited.com/board/showthread.php?t=149738
