Long Time Dream Fulfillment: E30 Street and Track Car Combo
  • CubbyChowder
    • Mar 2012
    • 1488
    #121
    Well…. I think my oil filter housing mishap yesterday revealed a deeper issue. I placed a clean drain pan under my engine before I pulled the housing off to catch residual oil, and I noticed that there appeared to be some glittery speckles in there. I ended up draining the oil and filter into a separate clean pan and the oil appears glittery and I’m seeing small specs of shiny non-magnetic metal flowing out of the filter and floating around in the oil. Not a good sign.
    what do you guys think? I’m really unsure of what to do moving forward. Do I put fresh oil in it, cross my fingers and continue moving forward with the swap since I am so close? I’m half tempted to just continue finishing it and try driving it for a while since I’m planning on S50 swapping down the road anyways. I don’t know! I’m pretty torn on what to do. The idea of tearing all of this back apart puts a pit in my stomach.
    --Roundie Revival 2.0 - 1973 BMW 2002 Build Thread--
    --Golden Boy E30 Build Thread-- (sold)
    • Panici
      • Dec 2009
      • 2506
      #122
      Oof that's a rough one. Always the chance you (and I) take with an unknown engine though.
      My vote is to throw in a heavier "high-mileage" oil and send it. Meanwhile find a replacement 24v engine and build it up.
      I bet it will last longer then you think.
      It'll get your car on the road and all the gremlins ironed out. Then you can swap in the replacement engine as time allows.
      • 2mAn
        Señior Mod
        • 20877
        #123
        Thicker oil and if you can throw in new rod and main bearings, just do that and drive the piss out of it
        Simon
        Current Cars:
        -1966 Lotus Elan
        -1986 German Car
        -2006 Volkswagen Jetta TDI
        Make R3V Great Again -2020
        • CubbyChowder
          • Mar 2012
          • 1488
          #124
          Panici & 2mAn - Thank you guys for the input! Any recommendation on a thicker oil that might be suitable for this specific scenario? Like a 20w-50 or similar? I bought some Rotella T6 5w-40 to run but can always return it.
          • amcp
            • 489
            #125
            Hell go 10w-60.
            • It's Soda Not Pop
              • Jan 2022
              • 877
              #126
              I use VR1 20w-50
              88' Seta 2.7i Zinno
              https://www.r3vlimited.com/board/for...430-my-88-seta
              • CubbyChowder
                • Mar 2012
                • 1488
                #127
                Alright, the M50 swap is buttoned up for the most part and the car runs and drives. Put maybe 40 miles on it last night and drove it home. The last few pieces of the puzzle:
                Got the power steering system all dialed in. Had to order a new E36 high pressure hose and modify the two reservoir hoses to make it all work as the reservoir now sits right off the engine mount arm. I actually quite like this setup as it hides the reservoir:
                Then to finalize the cooling system, I bought two of the NAPA 8484 hoses that are commonly used with these swaps, and they worked out perfectly. Was able to trim them up to fit just right, they look proper:
                The last big hurdle was exhaust. I have been searching for an E36 midpipe to graft onto the car (hoping to get this through CA BAR) but no luck. I did, however, cut up the pipes from that E34 parts car so I at least had something that would bolt to the manifolds. So, as a temporary solution, I ended up modifying the E34 pipes to route cleanly in the E30 and then ran them into the original E30 exhaust setup. It's not ideal as I'm sure it's restrictive, but it works for now and I will change it eventually.
                E34 pipes modified to fit:
                Grafted on to the E30 system. I also cut the o2 bung out of the E30 exhaust and relocated it further downstream in the collector:
                Gave it a quick and dirty high temp paint job:
                Bolted right up.
                At this point, the car was ready to drive. Had a successful maiden voyage of 30-40 miles, coolant temp and oil pressure was solid the whole time, no fluid leaks anywhere. The car actually sounds really healthy and pulls strong, definitely a nice little bump in power over the M20. The one thing bothering me though is the "rev hang" I'm experiencing. The RPM's drop slowly when you let off the throttle and researching it leads me a bit confused as the info is all over the place but seems like a common M5x thing. The thing that makes the most sense to me out of everything right now is the fact that I'm using the 413 ECU from the automatic 525i E34, and that rev hang is supposedly programmed into those ECU's and can be programmed out. I'll get it sorted eventually but the car as it sits is totally driveable and I'm going to put more miles on it today. I'm happy to be in the E30 again.
                • Panici
                  • Dec 2009
                  • 2506
                  #128
                  Gave it a quick and dirty high temp paint job.
                  the car as it sits is totally driveable and I'm going to put more miles on it today! I'm happy to be in the E30 again.
                  I did something similar with my power steering res. Keeps it tucked away, and a nice step towards a semi-shaved engine bay.
                  What kind of high temp paint did you use for the exhaust? I've tried a few kinds before but haven't found one I'm happy with yet.
                  Happy you got it on the road! Enjoy the drive
                  • CubbyChowder
                    • Mar 2012
                    • 1488
                    #129
                    Panici Thanks! So far I'm happy with the swap. As for paint, I've only used the VHT header paint from Autozone and have had decent results, but I also haven't gone through the proper steps like using VHT primer first and all that, I usually just clean a bit and then spray away. It lasted pretty good on my M20 exhaust manifolds but it certainly has it's limitations. Looks better than rust.
                    • CubbyChowder
                      • Mar 2012
                      • 1488
                      #130
                      Have put about 200 trouble free miles on the swap so far. I had a CEL which was a good opportunity to see if a stomp test works (which it did) - code 1263 for EVAP purge valve. I didn't have one hooked up yet but I finally found a used one for sale and it showed up today, so that took care of the CEL. I also have a Turner chipped 413 ECU from a manual car on the way, so hopefully that takes care of my rev hang "issue".
                      Still have a bit of tidying up to do but I'd pretty much consider this swap complete and daily driveable! Gave it the beans on some backroads this evening and the car feels happy.
                      • CubbyChowder
                        • Mar 2012
                        • 1488
                        #131
                        More dreams came true today. Didn't think it would happen nearly this fast, but today I scored a low mile S50! Pulled from a 1995 M3 with only 109k on the clock (was able to confirm through VIN numbers and recent smog certificates/maintenance records). I'm pumped. I just couldn't pass it up. Honestly in the decade that I've been an E30 enthusiast, I've regarded an S5x swapped E30 as the pinnacle. Obviously there are better and wilder swaps out there, but it's been a dream of mine for years and I am really happy. It's gonna be a little bit before it makes it's way into the car but when that time comes, it'll be an easy swap.
                        Came with the full harness and DME so that was nice. I think I got a really fair deal too, considering where prices are at for everything these days.
                        All I want to do is dive right into this swap and get it all dialed but I have to hold off for a little, nice test of patience.
                        • moatilliatta
                          • 6151
                          #132
                          Nice score, any plans for it?
                          Id look at getting an engine stand with 2 front wheels.
                          @Zakspeed_US
                          • CubbyChowder
                            • Mar 2012
                            • 1488
                            #133
                            moatilliatta - Just planning on cleaning it up, replacing seals/gaskets and dropping it in. I'm going to try to get this through CA BAR so want to keep it as stock as possible for now. Any recommendations on worthwhile modifications? I'd be open to changing some stuff up once it's passed BAR.
                            • moatilliatta
                              • 6151
                              #134
                              Id replace the valve springs and retainers, Maybe supertech / Epic if you plan on going with upgraded cams later.
                              95 motors are common to drop a valve due to broken valve spring retainers.
                              It seems like most motors going in for me get WPC rod bearing and vanos rebuild ontop of being resealed. Just one less thing to think about and one more thing is a known good.
                              Did you do a baffle in the E34 oil pan?
                              Oil wire tie Oil pump nut, Maybe upgraded shaft, esp if your heal toe downshift are still a bit rough.
                              @Zakspeed_US
                              • CubbyChowder
                                • Mar 2012
                                • 1488
                                #135
                                moatilliatta - dang, I was unaware of the valve spring retainer issue... That's an expense and a job I was not anticipating on taking on right now. Gonna have to think on that one a bit. Thank you for bringing that to my attention though.
