The r3v motorcycle thread
  • Northern
    I like cupcakes & sh!tboxes
    • 5284
    #1336
    My friend's GPz is sadly not in the best shape, we resealed the forks and cleaned the carbs but it's still a pain to start and keep idling while it warms up. We're probably tearing into the carbs again with a rebuild kit and doing some engine refresh over the winter. Also maybe trying to figure out the whole anti-dive system and seeing if it's actually working.
    Originally posted by econti
    Sounds like a cheap bike is turning expensive
    Definitely going to sink $500 into this bike to get it driveable and not a dumpster fire, but still ends up being pretty cheap.
    I bought a full F4i trans last night for $80. I couldn't see 2nd gear dogs from the photos, but every other set of dogs looked pristine so I'm hoping it works out. Some gears are common between the two, so I'm really hoping the main/countershaft still have the same spacing.
    Originally posted by priapism
    Originally posted by shameson
    • tim88325is
      • Jul 2008
      • 201
      #1337
      My GPZ550 carbs were kind of a mess, the needles didn't match. I ended up getting a Dynojet kit and a rebuild kit to just replace everything and rejet to the aftermarket pipe that was on the bike. These small bike jets are so tiny, hard to tell if they are clean or not. The new jetting is fairly rich on the needle with a smaller than recommended main jet since the airbox is stock, starts and idles great with excellent throttle response and revs freely too.
      I just replaced the seals and used new fluid, bike seems to handle as well as anything from that era. I added 8psi to the front forks too per manual.
      • Northern
        • 5284
        #1338
        My buddy has two snapped off/ seized jets in his GPz, can't remember which. We didn't want to do any more damage at the time, but he's ordering a jet kit for this winter. Also his float bowl drains are all sorts of messed up, so I don't know what his plans are there.
        The F4i gear set showed up. It looks pretty good and has the same spacing as the F4 so it'll fit. Edit: Apparently it doesn't have the same spacing...
        I'm going to pull it apart to clean/oil it before I throw it all back together, also will check the shift forks for any kind of bends/wear.
        Pretty pumped to put it back in the bike and not have bike parts all over the place, then it might end up in the shed before snow falls.
        • LateFan
          • May 2013
          • 4436
          #1339
          Hasty Flaming Buffalo
Name:	Hasty Flaming Buffalo.jpg
ID:	9886341 Click image for larger version
          • LateFan
            • May 2013
            • 4436
            #1340
            At the Peterson Museum...
            • LateFan
              • May 2013
              • 4436
              #1341
              OK, you knowledgable bike guys, explain this to me - why is the seat so damn high? is it current style, is it front-rear weight balance, is it handling...? The rider seems to be really high and farther forward. Don't you want your center of gravity as low as possible?
              Click image for larger version  Name:	kc20lyfoxdwaxlzqraka.jpg Views:	0 Size:	102.0 KB ID:	9912025
              • econti
                • May 2014
                • 1152
                #1342
                Being forwards makes them easier to slide (weight on the front wheel to keep it gripping as much as possible) and height makes it easier to flick into corners. At least that's what I find.
                • tim88325is
                  • Jul 2008
                  • 201
                  #1343
                  I think that model is meant to have an upright riding position. Not a sports bike crouch or a cruiser recline, see the new Ducati Scrambler line or any "standard" Japanese motorcycle from the 70s, CB750, CB550, etc.
                  • varg
                    Florida Turbo Man
                    • May 2014
                    • 3430
                    #1344
                    It's more complex than that. It makes little difference at speed in a straight line where stability depends on suspension/steering geometry and its interaction with the gyroscopic effects, and going slowly it just changes the technique required. Bikes with a very high center of gravity like supermotos are incredible at cornering, it just requires a different technique to do so than on a supersport.
                    IG @turbovarg
                    '91 318is, M20 turbo
                    • LateFan
                      • May 2013
                      • 4436
                      #1345
                      Thanks. It just seems like you'd have to throw your weight side to side a lot more to lean it over. And it just looks a bit goofy to me.
                      • varg
                        Florida Turbo Man
                        • May 2014
                        • 3430
                        #1346
                        Nah, wouldn't be that bad. The weight of it (527lbs wet per Indian's website) would make more of a difference than how tall it is. It is actually very similar in specs to my ZRX, which is not at all effortful to transition and corner with. Riding position on the ZRX is a little more feet forward and leaned forward, seat height (with flipped eccentrics like mine) is almost the same.
                        Man do I miss riding my bike, but the carburetors have been giving me such a fit. I get busy and can't ride it for a little while and if I forget to run it a couple of times per week I wind up having to pull them off and clean them because they gum up so fast. Swapped carbs for a set that do not have a broken casting like the ones that came on my bike and I just can't get it to run right.The 'new' carbs came with drilled slides and non-stock needles which might be contributing to the transition issues so I might have to put my stock slides back. One of them has a pinhole sealed with rtv which is what prompted me to swap them in the first place. I had it running nicely at one point with the shimmed stock needles and larger main jets so I want to just get back to that point. It needs a valve adjustment too and it uses those damn fiddly little shims
                        IG @turbovarg
                        • Northern
                          • 5284
                          #1347
                          What do you run for fuel? Do you think it's ethanol that's gumming up the carbs? Any chance it's debris in the tank?
                          • varg
                            Florida Turbo Man
                            • May 2014
                            • 3430
                            #1348
                            I'm fairly certain it's the shitty Ewhatever fuel I have no choice but to purchase here
                            I've never actually tested the ethanol content but it certainly behaves like it's more than 10% by how fast it goes bad sitting in my garage. No chance it's debris from the tank, I have a fuel filter inline and never find anything other than the white crud and varnish in the bowls. The bike runs on regular 87 and there is no evidence the 91 or 93 in these parts has less ethanol so I just buy 87.
                            IG @turbovarg
                            • Northern
                              • 5284
                              #1349
                              Ah I see, my local gas has ethanol in 87/89 but 91 is "ethanol free" so I just run 91 in bikes/snowblower/etc and haven't had a problem.
                              • DatUtahGuy
                                • Jan 2007
                                • 3146
                                #1350
                                Here is my dirty girl, I ride her hard and put her away wet every time :) Click image for larger version
Name:	Baby Blu low res.jpg
                                YOUTUBE: AR Perez
                                If lucky, the E36 will die peacefully, in its natural habitat, and be given the prestigious honor of donating its parts to an E30
