Its 2025 who is using there e30 for track days. Include a few words and Pictures.
  • moatilliatta
    • 6152
    #31
    Its been hibernating. Maybe some GLTC Time Trial next year..
    @Zakspeed_US
    • OSAH racing
      • Apr 2022
      • 244
      #32
      Love the Sound your motor is making. E30 Hibernating? Because the Cayman is too Good?
      • OSAH racing
        • Apr 2022
        • 244
        #33
        I have picked up a project to be the track car. It will be sitting till January in my Garage when I will have time to sort it out, add a 1/2 cage and some harnesses and go from there.
        • OSAH racing
          • Apr 2022
          • 244
          #34
          The exhaust will be the first item to see the dumpster. Then the BC coil overs.
          1995, 325IS M50 Schrick 264, euro 6 speed, M3 front and rear suspension.
          • Panici
            • Dec 2009
            • 2567
            #35
            Going to start a build thread?
            • Leebo
              • Nov 2021
              • 6
              #36
              Plenty of us in ChampCar and LeMons. Here’s my hot lap at the practice day at NHMS for the 2025 LeMons race there:
              Open to any and all feedback on my line, etc!!!
              Car spec is built to optimise ChampCar specs/points: SETA with a cam and “i” intake/throttle body; J-Stock springs/shocks; Conti ECF 245/40/R15; NLR wing and homemade splitter.
              Have had LOTS of help from many on this board getting it spec’d over the years.
              • 2mAn
                Señior Mod
                • 21016
                #37
                Can you share more of your car? Mind starting a separate thread rather than posting it here!
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • FredK
                  • 14762
                  #38
                  Looks good! I love seeing E30s out there mixing it up!
                  It's been a few years since I've done the chicane configuration, so my memory is a little foggy on the best way to enter T1. I think I would enter T1 later and wider to carry a little more speed to have a better entry angle into 1A, which would help with tracking out at 2 closer to the wall. I think you overslowed which is why you have a lot of directional control at the apex of 2 where you make a further steering input to move more left and the car willingly scoots over. I think you can brake harder and later at 3, especially because in the config with no cones the braking zone is smooth, and with no cones, you can be track left a car's width and it becomes a wider turn with a slightly higher min speed. I'd turn in later at 6. Great line through 9, it's a bit intimidating to try to pull speed out of, and you may be maxing out your ECFs which is why the track out for 10, you haven't been pushed track left with the speed of the car. Normally if you nail 9, you get pushed pretty wide at 10 and here, you had half a car's width to the dark patch of pavement they put in due to people tracking out into the dirt.
                  What diff ratio are you using? I feel like this car should accelerate a little harder, because it seems like it's bogging on the uphill after T3 and it should be shredding pavement with that 2.7 super eta bottom end.
                  • Leebo
                    • Nov 2021
                    • 6
                    #39
                    It's been a few years since I've done the chicane configuration, so my memory is a little foggy on the best way to enter T1. I think I would enter T1 later and wider….
                    and you may be maxing out your ECFs should be shredding pavement with that 2.7 super eta bottom end.
                    Hey - thanks for all that!
                    All great feedback! Agree on 3! Turn 6 still bugs me. Funny enuf, on turn 1, I was running that rounder line and the Garmin Catalyst liked the straighter line - speed around 1 was within 1mph but the distance was much shorter. But I take your point and wonder if the Catalyst is giving me min time at 1 but at the expense of 2a/2b.
                    The Conti ECF is a compromise but I’m getting 40+ hours out of them (which is probably why they’re a white-list tire for ChampCar.) Diff ratio is 3.73 and I think I may be a bit down on power…winter project!
                    • FredK
                      • 14762
                      #40
                      Right, with a lower powered car, it's often a tradeoff with distance and entry speed, and sometimes the shorter path is quicker. I hope you guys had a good race!
                      • DEV0 E30
                        • Oct 2004
                        • 8903
                        #41
                        Neither one is mine, but since I posted in another thread and I always misplace my bookmarks, these are two builds I've looked at a lot over the years and thought things like, "what if?" "can you imagine?" "wow!" and "I'd kill myself, and these guys are nuts."
                        Driftworks in the UK: https://www.driftworks.com/
                        S65 + E90/E92 DCT + reinforced, lots of changes, and custom bits etc. 400+ HP and around ~2200 lbs equals fast in the right hands.
                        Youtube Playlist: https://www.youtube.com/watch?v=lNAbPrn8Zcs&list=PL7Sa6Yg2JDv0JFB1yCB5Xa3Q 9wiKGV1De&index=50
                        Old Speedhunters article: https://www.speedhunters.com/2018/06...r-the-purists/
                        There's another super fast and widened E30 that is an M3 clone that has as an entire new M3 rear suspension (F80) grafted underneath. K24 turbo powered with DCT.
                        Saw a post on FB from this year:
                        F80 M3 rear end with Drexler diff
                        F80 M3 DKG/DCT transmission
                        700bhp Darton sleeved Honda K24 turbo
                        Group A DTM front end
                        Harjun Singh - instagram​
                        Speedhunters aritcle: https://www.speedhunters.com/2024/01/bmw-far-m3/
                        Youtube: https://www.youtube.com/@harjunlfs
