Off Road / Rally / Other non-pavement E30s - Post Your Setup / Class / Goals
  • DEV0 E30
    • Oct 2004
    • 8892
    As the topic says.
    Post your rally / off road E30 specs.
    Do you race in a class / organization? Or is it just for fun to explore forest roads etc?
    Post your setups along with at least one picture.
    Yeah, I might be brainstorming... known a few people who did this stuff for fun and would love to see who is still doing this and those who got a little more serious with it too.
    Some inspiration:
    https://www.speedhunters.com/2016/10...-m3-rally-car/
    Kevin O’Donoghue’s Class 14 BMW E30
    BONUS VIDEO:
    https://www.youtube.com/watch?v=xbx3EpiQR9w
    Engine:
    Motor Design Sweden Volvo 2,995cc 16-valve Evolution race engine, lightweight block, custom cylinder head, AT Power injectors (x8), TDP modified shaft-less throttle bodies converted to fly-by-wire with TDP bespoke VDO motor kit, Simpson 4-2-1 custom exhaust manifold, Owen dry-sump kit with Aviaid oil pump, MoTeC M1, M150 ECU running custom TDP.ie rally firmware with control systems for fly-by-wire throttle, advanced launch control strategies, full time adjustable traction control, 250MB high speed logging
    Drivetrain:
    Tractive 5-speed gearbox, Motor Designs differential, fully adjustable & light weight beam axle with GRP4 Fabrications modified wheel bearings, gear actuation via KAPS hydraulic paddle shift controlled by TDP MoTeC M1 rally package, integrated closed-loop paddle shift system, optional stick shift with flat shift available to driver
    Suspension/Brakes
    Bespoke Proflex Jumbo dampers, Prodrive-designed Group A front suspension uprights, arms, hubs & track control arms, custom front & rear adjustable anti-roll bars, adjustable front roll centre with adjustable custom toe & camber, MDS rear axle, AP Racing 6-piston front brakes with 360mm discs, AP Racing 4-piston rear brakes with 315mm discs
    Wheels/Tires:
    Team Dynamics 18×8-inch with variety of motorsport tyres depending on conditions
    Exterior:
    Dunne Motorsport Engineering custom E30 shell fabricated to original M3 specification using genuine BMW panels, full international specification weld-in multi-point cage with front triangulation, 2-piece door bars & A-pillar support, custom front/rear tubs & suspension turrets, custom front arches with bespoke Kevlar tube liners front & rear, DTM adjustable carbon rear spoiler, DTM carbon mirrors, Skoda S2000 carbon roof vent, custom vented bonnet, painted in 2015 BMW M4 Marina Blue
    Interior:
    MoTeC C127 display with three custom modes for road, stage & setup, Cartech power distribution panel, Cartech remote steering wheel button setup, Tilton 600 pedal box with drive-by-wire, custom carbon lightweight dash, Cobra carbon wrap-around seats, OMP Hans-compliant 6-point harnesses, Zero 360 fire extinguisher
    https://racemarket.net/rally/rally-c...-e30-2-0-i6293
    Click image for larger version  Name:	91501.jpg Views:	0 Size:	192.2 KB ID:	10147086
    In the last months an extensive revision and work was done on the car, including:
    – interior and underbody painting
    – replacement of all hubs, all studs, all ball joints, all PU bushings
    – complete rebuild of rear brake
    – new rear brake lines and brake bias adjuster (Wilwood)
    – revision of gearbox
    – new seats
    The car received a complete exterior repaint a 1 year ago with new side fenders, fiberglass bumpers, trunk lid and bonnet. It has polycarbonate side windows.
    Please find some of the specification below:
    Engine: M50B20 with reworked cylinder head, 2.5 cams and ITB setup with carbon fiber trumpets – 350SS km since complete rebuild
    Car is optionally available with a M50B25 2.5 liter engine.
    ECU: MaxxEcu Sport (with bluetooth, through the app all live data is available, startup / shutdown and other actions are also possible wireless within the current setup.) Launch control available with built in handbrake button.
    Gearbox: Beckert 6 speed sequential gearbox, with gear indicator
    Differential: BMW Typ188 LSD – BMW Motorsport 4.67 Ratio
    Suspension: current setup has custom adjustable coilovers at front (ideal for track and smooth asphalt) custom bilsteins rear, adjustable front camber and rear subframe. IRP adjustable strut bar. 90SH poly and aluminium bushings.
    (different setup is available)
    Brakes: Wilwood hydraulic handbrake, VMAXX 290mm front brakes (TÜV available). 325i rear brakes. Both front and rear runs Carbone Lorraine RC6 brake pads. The setup is in good condition, above 90%.
    Interior:
    – Bimarco Cobra Pro seats valid until end of 2030.
    – Sabelt 6 point HANS harnesses valid until end of 2028.
    – RRS Electrical extinguishing system, valid until January 2027.
    – Motorsport wiring harness
    – Electric kill switch system
    – Fiberglass flocked dash
    – OMP “Rally” 350mm steering wheel
    – Stilo WRC 03 intercom
    Fuel system: Car has a GRP4 MK2 Escort tank built in the trunk with dry break fuel fitting. (Price includes a pair of female fittings for refueling.)
    https://collectingcars.com/for-sale/1990-bmw-e30-m3-1Click image for larger version  Name:	24-ww-6.jpg Views:	0 Size:	236.4 KB ID:	10147087
    • This genuine E30-generation BMW M3 is a stunning Clubman Group A rally car conversion of the marque’s iconic modern classic performance saloon.
    • Under the bonnet is the correct 2.3-litre S14 inline-four, which has been modified with steel rods, crank and forged pistons,Schrick camshafts and larger valves, and drives the rear wheels via a five-speed Getrag 265/5 ‘dog-leg’ manual transmission and an upgraded limited-slip differential.
    • The car is believed to have covered somewhere in the region of 68,000 miles and the engine has been freshly rebuilt some 350 km ago. The transmission has only test km on the unit since being rebuilt.
    EQUIPMENT AND FEATURES
    • This M3 is finished in a red and white Motul/Bastos livery, peppered with period-correct supplier logos, including those for Prodrive, Serpico and Pirelli.
    • The car rides on a set of 17-inch gold Compomotive alloy wheels shod in Michelin tyres on the rear axle and Dunlop tyres on the front axle.
    • Inside, the cabin is painted white with a full welded in roll cage which extend to the turrets front and rear, and features two black Sparco race seats with six-point red Sabelt harnesses, a carbon-fibre trimmed dashboard, an OMP BMW steering wheel, lightweight door cards, a fire extinguisher, a short-shift gear lever and new hydraulic handbrake, real time air/fuel ratio displays, as well as the standard item just below.
    • Other modifications include AP Racing brakes and Bilstein fully adjustable suspension with adjustable alloy top mounts, and an uprated limited-slip differential and drive shafts.
    • The car comes with its Spanish road registration documents and competition logbook, a document detailing its suspension settings, the car’s engine mapping software and cables, an engine build sheet, a dynamometer power readout, tyre compound details and a selection of spares including rare and expensive magnesium OZ Racing wheels, a full set of wet wheels and tyres, suspension arms and a cylinder head.
    Other Cars / Articles / Builds:
    1. https://racemarket.net/rally/rally-c...ally-car-i6281
    2. https://racemarket.net/rally/rally-c...30-rally-i5616
    3. https://racemarket.net/rally/rally-c...-i-a-htp-i5943
    4. https://racemarket.net/rally/rally-c...oric-fia-i4675
    5. https://www.iconicauctioneers.com/1986-bmw-m3-rec09409-1-0220
    6. https://www.fastcar.co.uk/cars/bmw-e...e-right-stuff/
    7. https://www.rallyanarchy.com/phorum/read.php?7,113730
    8. https://www.condorspeedshop.com/blogs/sponsored-drivers/crenshaw-rally-team-2023-season-update
    9. https://bringatrailer.com/listing/1988-bmw-325ix-2/
    10. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/just-another-awd-turbo-rallyhillclimb-car-1988-e30-bmw-325ix/259404/page1/
    11. https://www.proxibid.com/lotinformat...-rally-car-fia
    Caswell, obviously:
    https://www.jalopnik.com/500-craigslist-rally-car-goes-to-the-baja-1000-5674807/
    More Media:
    Click image for larger version  Name:	w6an407.jpg Views:	0 Size:	270.3 KB ID:	10147088
    Click image for larger version  Name:	Dvw23Re.jpg Views:	0 Size:	260.0 KB ID:	10147089
    Click image for larger version  Name:	96f3aa09a8311e535769c464c8afe37e.jpg Views:	0 Size:	61.7 KB ID:	10147090
    Video Inspiration:
    1. https://www.bmwcca.org/news/video-30-year-old-e30-conquers-road-challenge
    2. https://www.youtube.com/watch?v=RrEkFxXgYis
    3. https://www.youtube.com/watch?v=ZC-O9PYyofU
    4. https://www.youtube.com/watch?v=oMmeyieDpGY
    5. https://www.youtube.com/watch?v=5CWTs8O7pz4
    6. https://www.youtube.com/watch?v=m7j7OAMETZU
    7. https://vimeo.com/20817334
    8. https://www.youtube.com/watch?v=ywnMoW-Rq0o
    9. https://www.youtube.com/watch?v=LlDu8EOF-lM
    10. .
    11. .
    12. .
    Here on R3v:
    1. https://www.r3vlimited.com/board/for...uspension-lift
    2. https://www.r3vlimited.com/board/forum/general-forums/members-rides/385521-my-off-road-e30
    3. https://www.r3vlimited.com/board/for...32-offroad-e30
    4. https://www.r3vlimited.com/board/for...stuff?t=224191
    5. .
    6. .
    7. .
    8. .
    9. .
    10. .
  • 2mAn
    Señior Mod
    • 20851
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
    • strickland
      • Sep 2018
      • 249
      not mine but i also dream of an off road setup. RallyX which is like autocross but on dirt.
      Credit: Rodnoc Racing.
      Click image for larger version  Name:	pexels-leif-bergerson-9843281-full.webp Views:	0 Size:	35.4 KB ID:	10147085
      1989 325is ✨
      • iansane
        • 1342
        Just put 31s on my girlfriends truck. Still trimming the rear to fit. No purpose other than to fit her personality and give her something she can bomb around her work. Coil overs front and rear, e46 control arms
        84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
        • 808ETA
          • Nov 2018
          • 436
          That thing is fuck'n awesome! I love the single wiper. What kind Bad Ass chick drives a truck like that?
          sigpic84 325e
          • DEV0 E30
            • Oct 2004
            • 8892
            Great stuff!
            keep it going guys
            • iamsam
              • Jun 2008
              • 174
              I did this years ago (for fun, nothing organized), let me go back and find those old threads...
              • DEV0 E30
                • Oct 2004
                • 8892
                Hell yes.
                • amarino
                  • Oct 2013
                  • 90
                  I would like to humbly submit my E30 as its still in progress:
                  Shocks / Struts: E30 Bilstein HD from a 2014 suspension refresh (Front: 34-001363 / Rear: 24-020282)
                  Front Springs: E34 525i (Lesjofors PN: 4008412). Brand new so they weren’t saggy at all.
                  Rear Springs: E46 wagon (Lesjofors PN: 4208445) heavy duty rear springs. Also used thicker spring pads.
                  Tires: 27x8.50 R14 GENERAL GRABBER A/TX
                  • DEV0 E30
                    • Oct 2004
                    • 8892
                    Love it.
                    • Panici
                      • Dec 2009
                      • 2500
                      Looks good out there on the trails!
                      Impressed how much tire you can stuff in the rear
