M42 turbo dyno results
  • Reap3r
    • 596
    #61
    Originally posted by wazzu70
    Not in English, but here you go: http://www.pure-pf.com/phpBB2/viewto...ht=318is+turbo
    Brush up on your Svensk :)
    Highlights:
    Dyno:
    Am I reading this right or does that build thread say that it makes 615hp on 1.6 bar of boost :crazy:
    Turbo M42 Build thread:
    http://www.r3vlimited.com/board/showthread.php?t=169672
    • e30guydownunder
      • Jul 2008
      • 874
      #62
      It is a 2L with a big free flowing head, intake, exhaust and turbo. It is quite probable, that is 23psi. Can't be bothered to read and check that figure was on 1.6bar though
      - Chris
      Project M42 - 255 @ 19 psi
      • Dj Buttchug
        • Jun 2010
        • 7678
        #63
        does anyone know who makes that fuel rail?
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • e30pq
          • Apr 2006
          • 579
          #64
          Yes, it's a company call Nuke Performance.
          Nuke Performance has designed and manufactured premium, long-lasting, durable, high-performance fuel accessories and other high end products for the serious racer since 2004.
          • e304me
            • Feb 2006
            • 1374
            #65
            what fuel does that car use? 110 or maybe even methane im guessing!
            EDIT: wow e85? nice!
            • SpoolnDaapex
              • Jan 2010
              • 150
              #66
              That thing is glorious. Thanks wazzu.
              Its gotta be either a high reading dyno or more boost than 23psi.
              And that is the A/C compressor im seeing, yes?
              I couldnt find any programs that translate svensk:(
              M42: Because 110 feels like 140 :finger:
              • Dj Buttchug
                • Jun 2010
                • 7678
                #67
                http://www.nukeperformance.com/
                thank you. I may need to go with a rail like this in the future.
                very nice setup imo
                Ig:ryno_pzk
                • e30guydownunder
                  • Jul 2008
                  • 874
                  #68
                  Methane is a gas (technically could be used as a fuel) not a fuel. You would be referring to Methanol.
                  Try using Swedish and google :)
                  http://translate.google.com/translat...D318is%2Bturbo
                  - Chris
                  • SpoolnDaapex
                    • Jan 2010
                    • 150
                    #69
                    :bow:
                    • e30guydownunder
                      • Jul 2008
                      • 874
                      #70
                      I've done some more diggin into this.
                      615hk -> 606 hp
                      Now the turbo is quite large, on par with a GT3582. Without spending ages trying to find the correct compressor maps here is a GT3582
                      At 1.6 bar or a Pressure Ratio of 2.6 the turbo is pretty well spot on efficiency wise and pumping about 50lbs/min. Using a rough conversion of 10.5hp to every lbs/min (as suggested by the garrett site) you get 525hp.
                      Now consider that the engine should be quite efficient at 7500rpm thanks to all the head work he has done. Say conservatively it is operating at 115% efficiency (VE).
                      This just scrapes through at the 600hp mark (603.75). So either their dyno is full of shit or the engine is operating somewhere around 130-140 VE.
                      eh, whats it matter, the thing is making great power and would be freaking fast!
                      - Chris
                      • Dj Buttchug
                        • Jun 2010
                        • 7678
                        #71
                        yea thats insane. do want
                        Ig:ryno_pzk
                        • wazzu70
                          • Jan 2005
                          • 1143
                          #72
                          That engine is wicked. Those are big numbers for an M42. That's a very nice build.
                          That engine is very wicked. Although, built for a different purpose. Obviously it wouldn't work out so hot for GT racing :) Still very cool though to see what an engine is capable of.
                          I believe he was using E85 for that run, but its been a while since I read through everything.
                          That run was also on the old setup, the bottom mount Neuken style turbo manifold and the Precision SC6169e A/R .58.
                          I don't believe the HX40 topmount setup has been dynoed.
                          www.e30.se has some more information and also another M42 build.
                          Lots of the parts the Swedish guys use can be purchased from www.pure-pf.com
                          The M42 has a lot more potential than people give it credit for
                          -Nick
                          M42 on VEMS
                          • e30pq
                            • Apr 2006
                            • 579
                            #73
                            We tested a Chuckwalla last weekend.
                            Check out this video. This session ended with a bang.
                            • e30guydownunder
                              • Jul 2008
                              • 874
                              #74
                              That's a bummer. Is it a gearbox / diff failure? I'm only saying that because the noise was consistent while you were rolling in neutral.
                              - Chris
                              • Blendercloud
                                • Jan 2011
                                • 236
                                #75
                                Coming from an American V8 background with big displacement/big power (a Nova in the high 9's) seeing this makes me all sorts of giddy! I have to say I'm really excited to see big power coming out of small packages these days. Thanks for sharing!
                                Chris
                                '83 320i - Crashed :(
                                '71 Nova - (9.71 @ 172mph) - Sold
                                '83 320i - Taking Offers
                                '01 325i - Sold
                                '07 Mazdaspeed6 - Sold
                                '89 325iX - Rust Free, 2 Door, 5 Speed
                                '06 M5 - Interlagos Blue SMG
