New 15x8 wheel coming!
I got the word from somebody who contacted TR that despite having a lot of room in its perimeter, the wheel has a glitch in the center, near the hub. The spokes, near the hub are seem to be portruding and touching calipers from a 15" BBK. I asked to get a profile from the 15" x 8" wheel(s), and check by myself.
LeeBrake harder. Go faster. No shit.
massivebrakes.com
225/50/15 should fit fine and should be in the 23.5-23.9in range, and I know they will fit with slightly rolling the fenders on lowered e30's.Comment
Yep, you're right on the rolling diameters. I was going from memory. At any rate, the difference was almost 2"
Lee- I'm using stock calipers with Brembo blanks for now. Shouldn't be a problem, right? I know I'll need bigger wheels for bigger brakes.
I'm hoping 225s will fit with no fender modication with -3 deg camber and coilovers. I can already fit almost 3 fingers between the tire and the fender with 205s...sigpic
Mike
'91 325i track car. Mostly...Comment
massivebrakes.com
Where are you seeing this data? most any 225/50-15 will be 24" or less diameter.Build : Das Drehmoment UngeheuerComment
225mm at 50 ratio is 112.5mm per shoulder x 2 = 225mm of shoulder (top and bottom).
If 25.4mm = 1" ---ยป then 225mm = 8.86"
Therefore a 225.50.15 tire will have the theorical height of 15" + 8.86" = 23.86"
Following the same calculus, a 225.45.15 tire is 22.97" tallBrake harder. Go faster. No shit.
massivebrakes.com
I was wondering when some1 would post this...figures it would be Lee!!!!
Ive met many many dudes that "know" cars...and could never do this math.I love sitting down and just driving!Comment
always check manufacturer spec as there are many variances even with in the same brand across models. Width & diameter varies quite a bitBuild : Das Drehmoment UngeheuerComment
It all depends what the manufacturer considers "usable tread". I guess Kumho thinks the sidewalls are part of the tread, and Hoosier thinks the tread stops 1/2" before the edge of the tire...Comment
I've not kept up with checking on these as it's been so long. I believe they are soon to be available though, I received a pic of a real wheel that has arrived but not sure on how many and what sizes might be available. Tire Rack site says 12/24, best bet is to call them. You can ask for Bernie if you don't have a contact.
They will not be available in gold. Unless something changes I'm pretty sure they are only coming in the carbon gray.
Cheers.Comment
