Colorado general chat...
This is a sticky topic.
  • Eric
    • 5142
    #8731
    Originally posted by Roland H
    Eric, while you're at it, just throw some high compression pistons in it. ;)
    buy my white BBS RC's and I'll gladly do that :puppy:
    I was actually thinking of a set of catcams, carbon airbox, bigger exhaust, tune & E85 would be some good fun.
    • Roland H
      • 4480
      #8732
      Then some pistons would be a drop in the bucket at that point. ;)
      • Eric
        • 5142
        #8733
        nah, because if I take the head off then that means B32 valves, port/polish, head rebuild, lighter rods, custom 3.5L crank, dry sump, etc.
        A slippery slope that I don't want to go down for as long as possible.
        • fsmtnbiker
          • Feb 2011
          • 617
          #8734
          Nice! can you burn a chip on the dyno? do you guys have a dyno at SCR?
          Yes and, not exactly. We use a dynojet that is located about 20 minutes from the shop, in Fort Collins.
          Let me confirm with Karl that he can tune your ECU (I am 99% certain he can.)
          If you make it up, you'll have to check out our shop and engine building department. We are doing around 1 built motor a week on average, and they are turning out great. I'm really enjoying it (and sliding headlong into building a shortblock with 12.5:1 compression to go along with my pimpy new head/cams.)
          Chris
          97 M3
          01 325
          Weston Auto Gallery
          • Eric
            • 5142
            #8735
            That'd be great, plus I think it's a dynojet that I have to use for classification for NASA TT since I have a swapped car.
            I'm running a red label 075 ecu btw.
            • Roland H
              • 4480
              #8736
              • lambo
                Captain Scene Points
                • 10953
                #8737
                Time to pool money together?
                • iamsam
                  • Jun 2008
                  • 176
                  #8738
                  interesting thing to collect, that's for sure. I wonder if he drove a different one to work every day.
                  • lambo
                    • 10953
                    #8739
                    I'd drive that Can-Am Spyder all day errday...
                    • hyperE30
                      • Sep 2009
                      • 2202
                      #8740
                      Just saw a black 1 M Coupe at 112th... sexy looking car!!
                      @Lambo-.... those are some super sweet rides!!
                      HyperWerkz
                      89 mtech2, s50, AR Kit, borgwarner s362, e-85, 15psi... 592whp
                      " enjoy the show "
                      • fsmtnbiker
                        • Feb 2011
                        • 617
                        #8741
                        Dyno results for my car...
                        Current mods:
                        3.5" intake, HFM, TB Boot
                        75mm VAC Throttle Body
                        M50 Manifold
                        24lb Injectors
                        Metric Mechanic Cams
                        Riceland Headers
                        Active 3" Exhaust
                        Fan Delete
                        UDPs
                        Active custom tune
                        Red line: All above bolt-ons, stock cams and TB.
                        Green Line: Same as above, stock TB
                        Blue Line: All of the above
                        Chris
                        97 M3
                        01 325
                        Weston Auto Gallery
                        • iamsam
                          • Jun 2008
                          • 176
                          #8742
                          So with 15% drivetrain loss you are well over 300bhp. Well done!!!
                          Now make my M60 do that.
                          EDIT: assuming you have EXACTLY 15% drivetrain loss, that is 314.86 bhp.
                          • Bimmerman325i
                            • 6854
                            #8743
                            Easily done:
                            remove M60, install LS3.
                            2017 Chevrolet SS, 6MT
                            95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
                            98 M3/4/5 (stock)
                            • iamsam
                              • Jun 2008
                              • 176
                              #8744
                              Originally posted by Bimmerman325i
                              Easily done:
                              heh. Not so easily. Or cheaply. I have read that you can crack 300 bhp w/ some tuning on an M60B40. I hope that is true.
                              • Bimmerman325i
                                • 6854
                                #8745
                                It's what, 286 stock?
                                Put headers that are known to flow, run a 3" exhaust, and you'd probably crack 300 crank.
                                I'd just supercharge it. Much better power per dollar.
                                98 M3/4/5 (stock)
