Colorado general chat...
This is a sticky topic.
  • Roland H
    • 4480
    #11626
    I've seen better, but I've also seen a lot worse. I'd drive the shit out of it.
    • Eric
      • 5142
      #11627
      Originally posted by Roland H
      They also put the "E36 M3 Mirrors" on the 850CSi as well.
      & E34 M5!
      OE mirrors found I found in a junkyard:crazy:
      • germanrob82
        • 109
        #11628
        How much for that exhaust and will he guarantee that it will pass inspections? ie full refund or payment after passing inspection
        My tags good till january 2014, so there's no rush or need to drop alot on an exhaust I'm only gonna use when inspection is due.
        • Roland H
          • 4480
          #11629
          Originally posted by Eric
          & E34 M5!
          Of course, how did I forget. :(
          I need some, in alpine preferably, but will take any color, for my E34 M5. Got any friends with the hookup?
          • blefevre
            • Dec 2008
            • 4287
            #11630
            They don't require helmets on the 'ring?
            - E30, DSM, Golf R, Mazda 3 Skyactiv
            • Roland H
              • 4480
              #11631
              public (toll) road, essentially. There are all sorts of tour busses on the ring too.
              • Cloudbase
                • 1795
                #11632
                M Coupe at the F1 track in Austin.
                JOY IS AN E30...
                • Cloudbase
                  • 1795
                  #11633
                  Can anyone guess what's going on here:
                  JOY IS AN E30...
                  • Roland H
                    • 4480
                    #11634
                    you're trying to remove all the gas from your tank?
                    • iamsam
                      • Jun 2008
                      • 176
                      #11635
                      that thar must be a breaker bar.
                      • iamsam
                        • Jun 2008
                        • 176
                        #11636
                        If so, it's a lot easier to use the drain plug on the gas tank.
                        • Roland H
                          • 4480
                          #11637
                          that doesn't clear the lines though.
                          • iamsam
                            • Jun 2008
                            • 176
                            #11638
                            ^^ true.
                            But if it's not the gas, then I bet you are trying to remove the fuel pressure regulator, but I'm here to tell you
                            • Cloudbase
                              • 1795
                              #11639
                              Fuel pump test. 875ml in 30 sec. It's good.
                              My car hasn't started since the cold spell came in last week.
                              It'll crank and sputter, but not start.
                              I push-started it with another vehicle and it took about 100 yards with the engine turning over in 2nd gear before it started.
                              Cal thinks my plugs are iced. I'm going to pull them tomorrow and inspect. I'm hoping once the temp warms up it'll come back to life.
                              JOY IS AN E30...
                              • downforce22
                                • Aug 2009
                                • 3192
                                #11640
                                My battery is going out, it had some trouble last week and didn't want to start this week. This morning was terrible. Don't think it can provide enough CCA anymore. Ive not changed it over 3.5 years since I got the car...
