PNW Chit Chat thread
  • iansane
    • 1343
    #23461
    Originally posted by Austin!
    Is there a vin to look up on the head to verify production date? I would just connect whatever solid gray wire you have left over to your check engine light.
    If it's on the back of the head like a quick google search says it is, then I haven't a clue as I wasn't bright enough to locate it before I put the motor in. :D
    84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
    • e30austin
      • 15382
      #23462
      Well, that sucks. Connect the rest of your wires and if you have a solid gray hanging out, wire it up.
      • 318isbmw
        • Nov 2005
        • 2843
        #23463
        Yeah, they're all put on the back of the head. It's a sticker, not sure if there's any way you could peel it off.
        • 1craze30
          • 1224
          #23464
          Look with a mirror??
          Jon
          • camren123
            • Sep 2012
            • 217
            #23465
            rather ask you local guys first but anyone want to buy a memphis 8inch sub with a pioneer 760watt amp? it kicks pretty well
            86 blue 325e 4dr- Totaled :[
            89 red 535i 4dr- sold
            87 black 325e 2dr- DD
            84 black 533i 4dr- project
            • iansane
              • 1343
              #23466
              I can't catch a break. Fired off the m50 and it's BILLOWING white smoke. So much for trusting craigslist.
              • 1craze30
                • 1224
                #23467
                Anybody have a 410 LSD or 426lsd from a 91 auto vert? I need some tire burning ratio for my 6
                Jon
                • e30austin
                  • 15382
                  #23468
                  That's waffleswaffleswaffleswafflesed. Wow. How much did you pay for it? Compression check? How long did you let it run for?
                  • Ryann
                    • 3350
                    #23469
                    Sure it's smoke?
                    • e30austin
                      • 15382
                      #23470
                      FWIW, my S50 smoked for a bit on first start up. It stopped once the DME learned its tune and it had time to run for a while. No smoke now. It sat with no intake or exhaust manifolds for two years or so.
                      • iansane
                        • 1343
                        #23471
                        $400 intake to oilpan with harness/ecm/acc/etc. It was pulled when I got there but he told me the compression numbers he "supposedly" did before he yanked it. Said it ran well but trans was boned. I let it idle for ~5 minutes or so before I saw coolant pouring out of the exhaust.
                        • e30austin
                          • 15382
                          #23472
                          Well, disregard my last post then. I'm so sorry man. That's weak as shit.
                          • iansane
                            • 1343
                            #23473
                            Yup. Sucks. I've had just shit luck with motors for this thing lately. I guess I'm looking at minimum; HG and head surfacing. Anything I should be looking for when I tear this apart?
                            • e30austin
                              • 15382
                              #23474
                              Replace the timing chain tensioner with the S52 hydraulic unit while it's apart (not a hard job either way, but "while you're in there."
                              When you pull the head off, look for cracks around the cooling jackets, particularly the ones closest to the combustion chamber, since it was blowing coolant out of there. 24v motors are notorious for that.
                              • iansane
                                • 1343
                                #23475
                                Thanks for the insight.
                                For the tensioner, OE unit or are there aftermarket brands that are acceptable?
