PNW Chit Chat thread
  • delamaize
    • Nov 2013
    • 1463
    #28726
    So this happened today:
    I picked this up for $20 from a clapped out 88 vert in a junk yard south of Centralia, it was filthy, and the leather covering was shot. the stitching was shot, leather dried out and split, also molded. I pulled the old cover, and cleaned it up good. Cheap-o steering wheel cover for now.
    anyone know anyone in the Olympia area that recovers steering wheels?
    Dumpster Fire Pilot
    • Wschnitz
      • 8089
      #28727
      Dont waste your money recovering that, find someones thrashed Mtech 1 for $45 and clean it up and have it recovered, will look way better.
      willschnitz
      • delamaize
        • Nov 2013
        • 1463
        #28728
        I wonder if I could recover it myself, I was able to get the old covering off in one piece, so I got a pattern.
        I want a a Mtech 1, but for $20, and $10 cover, it was a good, factory, option to get rid of the bent H-wheel I had....
        Dumpster Fire Pilot
        • Pdxseth
          • May 2012
          • 3124
          #28729
          I've given away minty wheels like that, I'm with will get a trashed mt1 and rock that until then.
          • Pdxseth
            • May 2012
            • 3124
            #28730
            So I have subframe risers I was going to put in. I almost totaled my car over the weekend, and now I'm thinking that may not correct enough of the camber I hit a bump going 75-80ish around a bend on i5 and the back end swung out, I went sideways for 2-300ft at full lock some how it brought it back but I don't ever want to experience that again should I just go with an adjustable subframe?
            • Pdxseth
              • May 2012
              • 3124
              #28731
              Here's a pic for reference I'm not sure what my camber specs are ATM but it's TOO MUCH!
              • Wschnitz
                • 8089
                #28732
                That camber isnt even that bad, are you sure you dont have a bigger issue like a bad diff or loose subframe? The amount of camber shouldnt cause lack of traction like that, especially in an eta ;)
                willschnitz
                • Pdxseth
                  • May 2012
                  • 3124
                  #28733
                  It was wet I'm also running 12k rear springs and I feel like the roads in Seattle/Tacoma are slicker I was yokin it everywhere In Portland I have a lot of trouble kicking it sideways
                  • EN318isPDX
                    • Oct 2007
                    • 4373
                    #28734
                    Sounds like someone needs bigger sway bars
                    • Wschnitz
                      • 8089
                      #28735
                      Don't you still have the stock eta open diff? That could also be the problem :/
                      willschnitz
                      • EN318isPDX
                        • Oct 2007
                        • 4373
                        #28736
                        Stance + Open Diff = Spin out
                        • Pdxseth
                          • May 2012
                          • 3124
                          #28737
                          So that's another thing would LSD have provided more traction or kicked it out more, I was trying to explain to my friend(that was in the car) why I thought an LSD would have prevented the situation but he thought I was crazy.
                          • Wschnitz
                            • 8089
                            #28738
                            Its called "Limited Slip Differential" last time i checked.
                            willschnitz
                            • EN318isPDX
                              • Oct 2007
                              • 4373
                              #28739
                              its a form of Antriebsschlupfregelung
                              • kye
                                • Dec 2013
                                • 217
                                #28740
                                That sounds really scary glad you didn't total it! Or hurt anyone that's my biggest fear when I'm driving.
