PNW Chit Chat thread
  • djjerme
    • 5082
    #32821
    Hmmm.. It's not impossible that an injector harness fails. I have seen it from every manufacture, and considering it's usually wire that is right in the middle of all the heat and moisture..etc of the engine, they do corrode over time.
    You could try building a ghetto injector test light with an LED and a resister in series (I think it's 680 ohms you'll want) or pick up a Node Light at Napa. I haven't had to do this test in a while, so don't have one, but I do have a fuel pressure tester if you need to use it..
    Honestly, it does sound like just little things that happen - I say take a step back for a while and work on something else. Let your brain rest. I have to do that sometimes with projects. It keeps wrench from being thrown through breakable objects down to a minimum.
    2016 Ford Flex
    • ahrensNW
      • Mar 2015
      • 1716
      #32822
      E30's have gone up in value, but it still disgusts me to see that a decent e30 is the same price as a clapped out pos mid 90s Honda.
      Hank Ahrens
      1984 Alpine Coupe
      1978 911sc
      • ncsubowen
        • Nov 2013
        • 1012
        #32823
        Originally posted by ahrensNW
        Anyone have an m20b27 they want get rid of?
        e30josh has one from my old car in Anacortes. Low miles (108k) and ran great. I'd PM him if you're interested.
        4 doors.. so much room for activities!
        IG @bluebombr
        Transaction Feedback:
        http://www.r3vlimited.com/board/showthread.php?t=323622
        • kid325e
          • Sep 2007
          • 6422
          #32824
          Don't rule anything out, Seth. Have you checked if your fuel pressure is within spec? I kind of went through the same shit with my M20 02. Literally scratching my head forever, checked all the basics and the last thing that I hadn't REALLY tested yet were the injectors. I had a noid light set so I knew the injectors were getting power and at the right times.
          The fuel injectors that were in the engine (whilst sitting for about a year or two but ran amazing before I pulled it back out of my E30.) went bad while sitting. Literally was missing like crazy as if only running on 2 cylinders. After verifying I had spark, proper fuel pressure, and knew that the injectors were at least getting the proper signal at the right time. I came to the conclusion that the injectors were probably at fault. Pulled the rail and low and behold 4 out of 6 of the pintle caps were missing (didn't make me feel like I instantly found out the issue but gave me a little bit of something to chew on as far as "getting somewhere") - New injectors and she fired right up. The injectors I replaced were M50 injectors for what it's worth.
          My best advice is take your time when going for that "first start" - I started feeling like when I couldn't get it going and started searching that it would be WAY TOO EASY to overlook something as "good". Stay level headed, you're close brother.
          clutchCTRL!
          Move with a purpose.
          - 1991 325iX 4dr/5spd
          - 2000 323i AT
          2016 Mazda CX3 Sport AWD
          • Pdxseth
            • May 2012
            • 3124
            #32825
            Well austin came over today and checked it out, I have no fuel and no spark for sure. I'm thinking it maybe something to with the e34 obc immobilizer. It seemed like it wanted to fire when I cut the wire out of pin 7 at the x20 but I ran out of battery and had to go to work. Hoping tomorow it fired up with a fresh charge
            ^ I believe this chart to be wrong, it's what I used and every other diagram says what's wired to pin 7 at the x20 should actually go to pin 11. I just cut it for now because I don't really care about my service lights right now
            • spiDmang
              • 3941
              #32826
              patience. itll all pay off. i love M20's myself, but 24v's are seriously the way to go. I loved my S50 swap, and plan on going with another 24v down the line here (hopefully before i move out of my house, so i can utilize my garage haha)
              91' 318iS - S54/6MT Swapped
              08' E90 M3 6MT - Daily
              Originally posted by IronJoe
              Originally posted by 2mAn
              • Pdxseth
                • May 2012
                • 3124
                #32827
                It's not gonna pay off much it's a non vanos m50
                • 5Toes
                  • 9836
                  #32828
                  yeah the NV isnt that big of an upgrade, in my eyes... but what do I know.
                  24V is nice to work on, dont get me wrong. a waterpump sure is easier!! but m20 vs m50... as far as maintenance goes is not that big of a difference. there are ups and downs to both. the cost of 24V can hop up an m20 nicely
                  • spiDmang
                    • 3941
                    #32829
                    Well what was in the car prior to it? Eta? It'll definitely be an upgrade from that.
                    At least it'll be easier for you to drop in an s50/52 later on down the road :up:
                    • Pdxseth
                      • May 2012
                      • 3124
                      #32830
                      It was an eta, my sedan is an m20b25 w/ 40k on the motor so it may be comparable to that....wich is slow. I'm just gonna blow up the m50 and drop on an m30
                      • ahrensNW
                        • Mar 2015
                        • 1716
                        #32831
                        WHY?
                        Why don't you just axe your m50 and go m30 now?
                        Hank Ahrens
                        1984 Alpine Coupe
                        1978 911sc
                        • 5Toes
                          • 9836
                          #32832
                          my brother's e28 looking fly
                          • iansane
                            • 1342
                            #32833
                            I don't think 7 goes to 11. 11 Doesn't have anything. If you're still stuck on it, I can yank the adapter I made and check when all I connected. When I made mine I'm sure I used this picture for the square c101 connector info;
                            and then the etm for a '90 525 verifying color against my harness.
                            84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
                            • Pdxseth
                              • May 2012
                              • 3124
                              #32834
                              WHY?
                              Because I originally planned on having this done by Halloween last year and it would take me another year to collect all the parts.
                              • Pdxseth
                                • May 2012
                                • 3124
                                #32835
                                Batteries charging up we'll see if it starts this weekend, it attempted to start and then I had to go, it may just fire up.......hopefully
