PNW Chit Chat thread
  • Pdxseth
    • May 2012
    • 3124
    #40321
    Yes the battery is up front, are you referring too the green on the c104 or c101
    Sent from my iPhone using Tapatalk Pro
    • FireFight
      • Mar 2012
      • 1367
      #40322
      The green in the c104, I know in etas and m10 that if its unplugged it will turn over but not fire.
      You putting in a b25?
      If so the last b25 I had the same issue, I went though all the steps in the Bentley and found the ecu was fuckkkkkked
      WTB:m60b40 in PNW
      Zachary Ripley
      85 318i M50B25tu.
      92 525it 5 speed.
      80 244gl (m60 prepping).
      • FireFight
        • Mar 2012
        • 1367
        #40323
        If the ecu is good and the harness is all proper, crank postion would be my next guest. Either that or adapter harness(if you kept the m10 rectangle c101 and your doing a b25)
        Fused power and unfused power getting swapped I think can also give this problem
        WTB:m60b40 in PNW
        Zachary Ripley
        85 318i M50B25tu.
        92 525it 5 speed.
        • Pdxseth
          • May 2012
          • 3124
          #40324
          Yeah it's an 89 b25 the cps is good I tested it in my other car. What's the green wire for what do I hook it too
          • Habla
            • May 2004
            • 1470
            #40325
            I think green is econometer and black is tach. Neither should keep the car from starting... Do you have power at the coil on turnkey?
            -Peter
            318is slicktop | F15 35dM | F250 SD
            • FireFight
              • Mar 2012
              • 1367
              #40326
              White is econo, green is ignition, I don't think it comes in to play with a b25 although
              WTB:m60b40 in PNW
              Zachary Ripley
              85 318i M50B25tu.
              92 525it 5 speed.
              • Pdxseth
                • May 2012
                • 3124
                #40327
                That's what I thought and I'm not sure I'll be going back over there tomorow and I'll check on that
                • FireFight
                  • Mar 2012
                  • 1367
                  #40328
                  WTB:m60b40 in PNW
                  Zachary Ripley
                  85 318i M50B25tu.
                  92 525it 5 speed.
                  • FireFight
                    • Mar 2012
                    • 1367
                    #40329
                    I have the green still wired in my 85, but I might have used that for the VSS, I don't recall
                    WTB:m60b40 in PNW
                    Zachary Ripley
                    85 318i M50B25tu.
                    92 525it 5 speed.
                    • FireFight
                      • Mar 2012
                      • 1367
                      #40330
                      also check your main relay and its plug, make sure all sockets have the correct current
                      On your adapter harness make sure that pin 10 on the car side becomes pin 7 (unfused power) on the engine side and 6 is going in to pin 6 (fused)
                      If those are both good then the adapter harness won't be your problem.
                      WTB:m60b40 in PNW
                      Zachary Ripley
                      85 318i M50B25tu.
                      92 525it 5 speed.
                      • Pdxseth
                        • May 2012
                        • 3124
                        #40331
                        Figured it out, one of the wires that goes to the battery/distribution block, was grounded.
                        • george graves
                          • 19992
                          #40332
                          Also - turn and cough, and make sure you don't have TB.
                          Originally posted by Matt-B
                          • Habla
                            • May 2004
                            • 1470
                            #40333
                            Classic
                            -Peter
                            • e30austin
                              • 15382
                              #40334
                              Atodaso, a fuckin atodaso!
                              Finished up the 5-speed conversion/replacement ETA motor on my '86 coupe this morning. Fired up on the first try. Always makes a guy happy. Enjoy your Sunday, everyone.
                              • ZekeTheSneak
                                • 1562
                                #40335
                                Did you use my tranny? I miss that thing. Just did the shift pin service on a zf and fuck me that sucked.
