PNW Chit Chat thread
  • bmwm42
    • 6300
    #33436
    toes are you sure you have compression. no being a dick but your known for destroying shit. you either a fucked up your timing you have a fucked ecu thats really it if you have fuel and have air and spark there isnt much left.
    Originally posted by bmwm42
    PNW vulture pm me for parts
    Strategic nw e30 command
    • 5Toes
      • 9836
      #33437
      haha I know. No I am sure because I put a gauge on it and checked all four. the ignition coil mounting bracket, the one corner of coil #1 I didnt have bolted down but now it is. the bracket is tweaked a bit because I used a grinder on it to make the new bosch coils fit better.
      all 4 coils/wires give a orange spark with a hint of blue... I have checked the order a zillion times. Im 100% confident the ignition system is hooked up properly.
      ECU is good, how else would I have spark + fuel...
      also I checked engine ground g103, which is bolted to the edge of the battery tray. its on there tight and I havent touched it at all. the engine ground strap looks solid and not even that cracked. I made sure everything is tight.
      I have 12.2volts at battery and 12.1 at the ignition coils with ignition on, good sign.
      • RainRider
        • Aug 2014
        • 362
        #33438
        I'd go back to stock injectors. I don't know... have no real argument for that.
        • bmwm42
          • 6300
          #33439
          I bet you have those fuckers in the wrong order
          • 5Toes
            • 9836
            #33440
            maybe I need to take a video of me doing the continuity tests and shit, but I have checked them many times and Im be highly suprised if they are somehow mixed up. Im thinking the orange spark is the problem. maybe just shitty half-way fouled plugs. im buying new ngk plugs and wires next week so guess the car is gonna sit till then.
            • george graves
              • 19996
              #33441
              Remember that e30 you used homedepo lamp cord on to extend the injectors?
              Originally posted by Matt-B
              • bmwm42
                • 6300
                #33442
                lol hoes has fuckups for days
                • 5Toes
                  • 9836
                  #33443
                  oh well, I learn from my mistakes. I pulled the fuel pump fuse and plugs and evacuated the engine of all gas. took a quick comp. reading - tested good. threw new plugs in and gave it a try.
                  its close to starting but not yet... sigh. I also checked my ignition system yet again and its all in order. new plugs def. helped.
                  • DER E30
                    • Sep 2013
                    • 2347
                    #33444
                    Orange spark? That doesn't sound right...
                    Well if it has compression and fuel, are you sure you don't have the ign trigger wheel backwards or something dumb?
                    -Christian
                    • 5Toes
                      • 9836
                      #33445
                      the spark is hard to see now that its sunny out. battery is on charger, it was getting low from cranking.
                      Im busy DJing and smoking while it charges haha
                      • 5Toes
                        • 9836
                        #33446
                        okay everybody call me a dumbass. put the coils back to the order they were in before and it fired up first turn of the key... this car hates me.
                        • e30austin
                          • 15382
                          #33447
                          I told you to put them back at least 20 times. You didn't want to listen...
                          Living up to your "for3ver n00b" title, for sure.
                          • 5Toes
                            • 9836
                            #33448
                            fwiw I shut the car off and pinned out the DME yet again, even counted twice which pin # I was probing exactly.
                            still have 1+3 and 4+2 mixed up according to these pinouts. would appreciate it if somebody else with m42 could run those tests real quick. you should have continuity between pin #25 on DME harness connector and pin 1 of your ignition coil for cylinder #1 as seen in the diagram below. either car runs good so something here is very fishy.
                            on my car, pin 24 of the DME seems to cylinder 1
                            • bmwm42
                              • 6300
                              #33449
                              hoes you are a fucktard lol
                              • 5Toes
                                • 9836
                                #33450
                                phil it would be cool if you can report your findings about my post above.
