PNW Chit Chat thread
  • spiDmang
    • 3941
    #33796
    Originally posted by hankolerd
    Why would you want to drill a hole in your thermostat? Surely that will just cause you more headaches down the road. You want your engine to warm up to operating temperature as quickly as possible, because when it is cold (or really hot) is when you get the most wear+tear on your engine.
    I remember on my e36 after doing the thermostat it immediately shot up into the red when I started driving. In my case I also had air in the system, but just jacking up the front end and loosening the bleed screw on the top of the radiator, then starting the car and running with the heater on seemed to get rid of all the air. I am not familiar enough with your set-up yet, but I imagine the process should be pretty similar.
    It could just be that your gauge is not calibrated right. If you know anyone with a temperature gun you could check your hose temperatures to get an idea of your operating temp when your gauge shows 3/4.
    And I can't recall now, but isn't the top hose the return hose (gets hot first), and the bottom hose is the feed hose (stays cold longer)? If that is the case the top hose should get warm when your thermostat opens up, and the bottom hose should get warm a short while later, after all of the fluid has circulated through the radiator. Though maybe I have the flow direction backwards.
    On some thermostat's, they come with pre-drilled holes to help elevate the air pockets that get stuck, making bleeding the system a helluvah lot easier. This hole is tiny, but helps fluid and air get by if need be.
    My set up (S52 with M20 late model radiator, late model coolant res) doesn't have a bleeder screw...but I may just add one now....We will see.
    91' 318iS - S54/6MT Swapped
    08' E90 M3 6MT - Daily
    Originally posted by IronJoe
    Originally posted by 2mAn
    • RainRider
      • Aug 2014
      • 362
      #33797
      Originally posted by spiDmang
      My initial thought was a stuck closed t-stat, so I said eff it and pulled it. Tested it out, and it opened right up at 195+- degrees (88c)...wtf is going on? could my gauge be reading way wrong? is my 3/4 mark half?! I am so god damn confused on this thing.
      I may be a little more paranoid of these cooling systems than you. I went with a 80C thermostat and a new radiator. I should run an 88C now I know for sure the whole system works.
      • DER E30
        • Sep 2013
        • 2349
        #33798
        My m42 has a little passage, like a 3mm notch in the thermostat hole so it can bleed easier, seems like a little hole in the t stat couldn't really hurt much...
        -Christian
        • hankolerd
          • Oct 2012
          • 280
          #33799
          Word. I hadn't heard of that before, but I am relatively new to the e30 platform :up:
          So I swapped the distributor cap + rotor and engine coolant sensors. Everything is nice and smooth when cold, but didn't seem to fix my warm engine idle issue. I suspect the AFM at this point. Maybe I need to send it off to BavRest, or start saving for a Miller MAF.
          Any thoughts?
          Cold: https://youtu.be/7F1peZwmLPc
          Warm: https://youtu.be/HREDSS-yX8k
          Daniel
          1990 M3 - http://www.r3vlimited.com/board/showthread.php?t=376104
          2011 328i Sport Wagon - 6sp Manual, RWD, Sport
          • ahrensNW
            • Mar 2015
            • 1716
            #33800
            Does anyone around here play rugby?
            Hank Ahrens
            1984 Alpine Coupe
            1978 911sc
            • RainRider
              • Aug 2014
              • 362
              #33801
              Not rugby but I did start playing disc golf last summer.
              • 2mAn
                Señior Mod
                • 20977
                #33802
                Any thoughts?
                The Miller setup is a nice upgrade for the S14, especially since I think they have figured out how to go Alpha N, so you wouldnt have to upgrade again down the road if thats another planned upgrade
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • ncsubowen
                  • Nov 2013
                  • 1012
                  #33803
                  This is hilariously opposite of one another. Disc golf might be the least contact sport I know outside of golf.
                  I don't play rugby but a couple of people at my gym do. One of them was on the US National team a few years back and plays on the weekends up at Marymoor.
                  4 doors.. so much room for activities!
                  IG @bluebombr
                  Transaction Feedback:
                  http://www.r3vlimited.com/board/showthread.php?t=323622
                  • 4tDX
                    • Jul 2014
                    • 509
                    #33804
                    Then you're playing it wrong! You do know you're only suppose to play when inebriated?
                    • Pdxseth
                      • May 2012
                      • 3124
                      #33805
                      Mounted my new wheel today, I love this thing.
                      • 5Toes
                        • 9836
                        #33806
                        haha thats right
                        Seth, love the new wheel too - never seen one myself. the speed holes definitely look old school!!
                        • kid325e
                          • Sep 2007
                          • 6422
                          #33807
                          Looking good! Speedholes? Lol
                          Sent from my Nexus 4 using Tapatalk
                          clutchCTRL!
                          Move with a purpose.
                          - 1991 325iX 4dr/5spd
                          - 2000 323i AT
                          2016 Mazda CX3 Sport AWD
                          • spiDmang
                            • 3941
                            #33808
                            You know...when you go fast. And stuff
                            • ahrensNW
                              • Mar 2015
                              • 1716
                              #33809
                              they add 15hp, no shit
                              Hank Ahrens
                              1984 Alpine Coupe
                              1978 911sc
                              • ahrensNW
                                • Mar 2015
                                • 1716
                                #33810
                                Go Hawks
                                Hank Ahrens
                                1984 Alpine Coupe
                                1978 911sc
