PNW Chit Chat thread
  • ncsubowen
    • Nov 2013
    • 1012
    #35581
    What driveshaft are you using? It doesn't look like the one they have pictured at all. The flex disc comes in a couple of different sizes. Wasn't your car originally a 318? Also, that's not a 24v adapter, it's a stock replacement flex disc (78mm) for the e36/e46 non-M cars.
    78mm Flex Disc
    24v Swap Disc/Adapter
    Side by side with your installation
    4 doors.. so much room for activities!
    IG @bluebombr
    Transaction Feedback:
    http://www.r3vlimited.com/board/showthread.php?t=323622
    • Pdxseth
      • May 2012
      • 3124
      #35582
      Originally posted by Wschnitz
      Id rather have AKG then condor, condor always seems hit or miss.
      I'd rather not pay 200$ for a piece of plastic
      • Pdxseth
        • May 2012
        • 3124
        #35583
        My car was originally eta, my trans is from a euro 323, idk Austin supplied the driveshaft says it's an m20 shaft.
        • ncsubowen
          • Nov 2013
          • 1012
          #35584
          *Edit - wrong here.
          IG @bluebombr
          • Pdxseth
            • May 2012
            • 3124
            #35585
            Either way unless it was an e36/46 halfshaft you have the wrong revshift part in there. The swap disc has clearly elongated sides to be able to fit all of the hardware in there appropriately.
            E36 has a different bolt pattern i would not be able to install it if it was the wrong part.
            • ncsubowen
              • Nov 2013
              • 1012
              #35586
              Whoops they have two different 78mm flex discs. My B.
              IG @bluebombr
              • EN318isPDX
                • Oct 2007
                • 4373
                #35587
                This is point and case why you should run ZF320 instead of G260/240 IMHO.. Nothing but nightmares.. Nothing worse than constant drivetrain issues, more so when you don't have a lift. Although it seems like the E36 driveshaft is a nightmare to find also.. Pick your poison i guess
                • djjerme
                  • 5082
                  #35588
                  Anybody want to help me weld my mufflers on? I don't have a the means to do it and I'm sick of exhaust shops raping me
                  I have a welder but no lift..
                  You are welcome to drop by some time and we can see if we can ghetto-fab your exhaust in to quiet territory..
                  Just probably not this weekend. If the weather doesn't turn to garbage, I'll be up racing.
                  2016 Ford Flex
                  • Wschnitz
                    • 8089
                    #35589
                    Id rather pay $200 for "a piece of plastic" that will work the first time and last forever then pay $100 for ones that have a higher chance of being garbage.
                    willschnitz
                    • 2mAn
                      Señior Mod
                      • 21049
                      #35590
                      Many people have ran the 24v/G260 combo without issues. I chalk this up to operator error.
                      24v/G260 user here with almost 40k and no drivetrain issues. Of course I also bought "overpriced" pieces of plastic to hold my motor (AKG)
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      Make R3V Great Again -2020
                      • Pdxseth
                        • May 2012
                        • 3124
                        #35591
                        That would be great, I don't mind not having a lift the exhaust is currently off of the car so I can weld up the mufflers and then bolt it up. I would do it myself but I live in an apartment and my welder is just collecting dust in storage.
                        • EN318isPDX
                          • Oct 2007
                          • 4373
                          #35592
                          Exactly, almost everyone runs it without issue.. minus the super common noisy syncros
                          • djjerme
                            • 5082
                            #35593
                            Well, heck, if it's already off, even easier!
                            Bring it by with some beer, and we'll get it sorted out..
                            2016 Ford Flex
                            • Pdxseth
                              • May 2012
                              • 3124
                              #35594
                              Sounds good text me whenever time works for you
                              • spiDmang
                                • 3941
                                #35595
                                I too am an S52/G260/S3.73 guy. A bullet proof way to know a drivetrain will work together is to source it all from the same car.
                                if you want a G260, snag that driveshaft with it (from that same car). Simple. No headaches as you know it'll work as it came from an origianl M20 car.
                                91' 318iS - S54/6MT Swapped
                                08' E90 M3 6MT - Daily
