PNW Chit Chat thread
  • BraveUlysses
    • Jun 2007
    • 3781
    #35566
    Originally posted by Pdxseth
    Maybe 1 mile on this quality built American made product
    Pretty obvious it's not the guilbo's fault in this series of errors.
    • car_gal_jenni
      • Aug 2015
      • 319
      #35567
      Originally posted by ncsubowen
      Because I know you all love giving your opinion - looking for feedback on paint options.
      http://www.r3vlimited.com/board/showthread.php?t=383972
      Stated there too, but here as well: avus
      Current daily: 2003 Mitsubishi Evo (Isabelle)
      Gone, but never forgotten: 2017 VW Golf R 6sp (Maria, sold)
      1989 325i 5sp (Lorelei, sold)
      1991 BMW 318is 5sp (Michaela; totaled)
      2000 Mitsubishi Eclipse GS 5sp (Selena, parted out)
      IG: mitsugal_jenni
      • Wschnitz
        • 8089
        #35568
        Fixed it for you seth.
        willschnitz
        • Pdxseth
          • May 2012
          • 3124
          #35569
          Originally posted by hankolerd
          Drive shaft too short?
          Engine was in the wrong position, the shitty euro parts giubo I had lasted 6 months running this way. I put the engine where it goes yesterday and just picked up another uro parts giubo from Halsey. I'm not going to waste money on a nicer one until I know for sure I've solved the problem
          • ncsubowen
            • Nov 2013
            • 1012
            #35570
            Wait you put the Revshift thing on with your engine mounted wrong? How can you blame them for that failure then? Not trying to defend the product but that is pretty clearly way off if you have ~.75" clearance on some bolts that are supposed to be flush with the piece...
            4 doors.. so much room for activities!
            IG @bluebombr
            Transaction Feedback:
            http://www.r3vlimited.com/board/showthread.php?t=323622
            • Pdxseth
              • May 2012
              • 3124
              #35571
              I'm not blaming them for failure I'm just pointing out the 28$ uroparts guibo lasted 6 months, the revshift one almost made it around the block twice .
              • delamaize
                • Nov 2013
                • 1453
                #35572
                Looks like you might have a vertical misalignment also man, It might just be me, and the picture also.....
                Dumpster Fire Pilot
                • Pdxseth
                  • May 2012
                  • 3124
                  #35573
                  May just be because the trans is tilted 10*
                  • ncsubowen
                    • Nov 2013
                    • 1012
                    #35574
                    Yea not surprising if the engine mounts are on wrong that the height would be off too. From what I recall, his engine isn't at the correct angle due to the incorrect mounts.
                    I'm not surprised that a 'performance part' made specifically to have less flex and tighter tolerances got eaten up faster than a cheaper rubber disc.
                    IG @bluebombr
                    • Pdxseth
                      • May 2012
                      • 3124
                      #35575
                      The bolts shouldn't have ripped out like that, the giubo came with washers that go behind those rear nuts but they were to big and would have to be shaved to actually fit, if revshift provided proper hardware this may have lasted a couple days but there was no way to get those washers to fit and my car was broken so I had no way to go anywhere and buy new washers
                      • EN318isPDX
                        • Oct 2007
                        • 4373
                        #35576
                        Tilting it 10 degrees doesn't change the alignment. Almost everyone runs G260 with 24v and have no issues. Get the AKG mounts and be done with your issues.
                        • Pdxseth
                          • May 2012
                          • 3124
                          #35577
                          I think the condor mounts are fine, I just had them in wrong, my car has taken a few beatings involving boulders and the undercarriage. when I initially installed the mounts I could not get them to go in the way they are supposed too bassically one was flipped, I was able to get in right with a little massaging so it should be ok now.
                          • Pdxseth
                            • May 2012
                            • 3124
                            #35578
                            Anybody want to help me weld my mufflers on? I don't have a the means to do it and I'm sick of exhaust shops raping me
                            • Wschnitz
                              • 8089
                              #35579
                              Id rather have AKG then condor, condor always seems hit or miss.
                              willschnitz
                              • EN318isPDX
                                • Oct 2007
                                • 4373
                                #35580
                                Ah ok, condor 24v mounts should be fine also
