PNW Chit Chat thread
  • hankolerd
    • Oct 2012
    • 280
    #36931
    Originally posted by ahrensNW
    Partout?
    Yes I need to get the part out.
    No I am not parting out the car, just redoing the front suspension.
    Daniel
    1990 M3 - http://www.r3vlimited.com/board/showthread.php?t=376104
    2011 328i Sport Wagon - 6sp Manual, RWD, Sport
    • EN318isPDX
      • Oct 2007
      • 4373
      #36932
      Heat it up the strut housing and hopefully you can yank it out..
      • ahrensNW
        • Mar 2015
        • 1716
        #36933
        Strut housing in fucked, only option is to part it out lol
        Hank Ahrens
        1984 Alpine Coupe
        1978 911sc
        • spiDmang
          • 3941
          #36934
          this^^...and a shit ton of PB blaster. If you can, let the strut housing sit with the pb blaster in it for like a week. Keep spraying the area down every day.
          91' 318iS - S54/6MT Swapped
          08' E90 M3 6MT - Daily
          Originally posted by IronJoe
          Originally posted by 2mAn
          • 2mAn
            Señior Mod
            • 21037
            #36935
            Originally posted by Pdxseth
            My cars running on 4 cylinders again. I see an m20 going back in this winter.
            I see a neverending project in your future. I think it would be easier to fix your issues on the current motor than swapping it again...
            Anyone ever removed a strut insert from a strut tower and had the sleeve for the strut insert stay in the tower? If so, any hints on removing it? And how long did it take?
            This is what came out of the strut tower:
            This is what I expected:
            The entire yellow sleeve for the strut insert is still jammed inside my strut tower.
            Can you see the insert in there?
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            Make R3V Great Again -2020
            • hankolerd
              • Oct 2012
              • 280
              #36936
              Yes - Though my mechanic has them right now. Originally I pulled the strut insert out, and realized there was a 1" collar that I was not able to get out, so I took it to Prova to have them pull out. I also was not able to remove the driver side insert at all, so took it to them to remove that one as well. I thought these were Bilstein struts, so was surprised the passenger side insert did not have any yellow sleeve or any markings on them - it all makes more sense now.
              It was after he got the 1" collar out, and the driver side insert out that it became clear the passenger side actually was still retaining the entire insert. Which you can see in this photo - the 1" tall collar has nested inside the yellow Bilstein sleeve, which you can just barely see at the end of the threads.
              I gave Prova a call this morning and asked them to take off the tie-rod mount to see if there is a hole in the bottom of the strut housing - hoping they will be able to stick a rod through it to try to hammer out the insert. Anyone know off the top of your head if the strut housing is drilled at the bottom?
              Short of that, I asked him to try bending a portion of the insert with a chisel enough to get a pair of vice grips on it, but it being up against the threads is a bit worrying.
              Also, these things are packed full of dirt/mud - I don't even know how that happens. No wonder this car felt like the struts were locked solid, they probably were.
              Daniel
              • TobyB
                • 5296
                #36937
                yeah, the bottom of the strut fills with water. It's a 'feature' of the reverse strut design...
                t
                • djjerme
                  • 5082
                  #36938
                  Let me know if you really do want to go that route. I've probably got all the stuff to do it, and we could make work a deal out. I'd be interested possibly in the 24v stuff for the new project I am working on this winter.
                  2016 Ford Flex
                  • kid325e
                    • Sep 2007
                    • 6422
                    #36939
                    They always come back to the M20.. ;)
                    Sent from my Nexus 5 using Tapatalk
                    clutchCTRL!
                    Move with a purpose.
                    - 1991 325iX 4dr/5spd
                    - 2000 323i AT
                    2016 Mazda CX3 Sport AWD
                    • Pdxseth
                      • May 2012
                      • 3124
                      #36940
                      I've got a nice 90,000 mile m20 all maintenance done 10k ago. Austin's getting all my 24v junk for the use of him and his shop. I'm sure he'll be selling the stuff off.
                      • Pdxseth
                        • May 2012
                        • 3124
                        #36941
                        Should have never gone 24v. Its dumb.
                        • EN318isPDX
                          • Oct 2007
                          • 4373
                          #36942
                          No one likes a quitter
                          • e30austin
                            • 15382
                            #36943
                            Should have never gone M50nv. Its dumb.
                            Fixed
                            • IronJoe
                              • 2275
                              #36944
                              Cutting out my rusty battery tray this weekend. Anyone here replace one before?
                              '89 Schwarz E30 M3 Cabriolet Build
                              • Matt-B
                                The Waffler
                                • 3856
                                #36945
                                Wishno87 had his dad fix one on. A friend's car. He may have insight
