PNW Chit Chat thread
  • EN318isPDX
    • Oct 2007
    • 4373
    #37291
    Originally posted by 5Toes
    you people are sexy and fly as fuck
    • e30austin
      • 15382
      #37292
      New sig. Thanks!
      • EN318isPDX
        • Oct 2007
        • 4373
        #37293
        Originally posted by Austin!
        New sig. Thanks!
        This one is less drama causing!
        • car_gal_jenni
          • Aug 2015
          • 319
          #37294
          So!! My bf and I (mainly my bf) just bought an '01 325i 5sp. Anything we should know about these cars? Tips or tricks? Concerns? Looking to learn!
          Sent from my XT1254 using Tapatalk
          Current daily: 2003 Mitsubishi Evo (Isabelle)
          Gone, but never forgotten: 2017 VW Golf R 6sp (Maria, sold)
          1989 325i 5sp (Lorelei, sold)
          1991 BMW 318is 5sp (Michaela; totaled)
          2000 Mitsubishi Eclipse GS 5sp (Selena, parted out)
          IG: mitsugal_jenni
          • Matt-B
            The Waffler
            • 3856
            #37295
            replace entire cooling system
            • car_gal_jenni
              • Aug 2015
              • 319
              #37296
              We have service records of that entire job being done very recently.
              IG: mitsugal_jenni
              • IronJoe
                • 2275
                #37297
                Working on firing up the S14 today. So far, it cranks but no firing. Plugs are wet, spark is weak and erratic. Going to double check the grounds and throw some fresh gas in, will report back when she's up and running.
                '89 Schwarz E30 M3 Cabriolet Build
                • e30austin
                  • 15382
                  #37298
                  Any luck? How's the battery? A questionable battery will do all sorts of strange things...
                  • djjerme
                    • 5082
                    #37299
                    How old is the gas in it? If it's not pure gas and over 6 months old, it may have pulled enough moisture to make it worthless.
                    Stupid corn fuel.
                    2016 Ford Flex
                    • Matt-B
                      The Waffler
                      • 3856
                      #37300
                      id go with aluminum rad,alu over flow, etc, silicone hoses etc, i hear the entire system is shit
                      • dereliiict
                        • Jun 2013
                        • 748
                        #37301
                        I would check to see if the subframe has been reinforced at some point. R used to be a TSB that they would fix for free, I got a then new e90 to drive across country for two weeks, but have since begun paying for only half the repair IIRC.
                        I drove my '00 328i for 3 years with no cooling issues.
                        Though, that time period was plagued with it across multiple manufacturers so I may have been lucky.
                        Sent from my iPhone using Tapatalk Pro
                        Derek-
                        • car_gal_jenni
                          • Aug 2015
                          • 319
                          #37302
                          We checked the rear subframe out, and currently it is fine. However, doing all of the reinforcements is high on our to-do list in the near future. Don't want any of those issues happening, ever.
                          IG: mitsugal_jenni
                          • IronJoe
                            • 2275
                            #37303
                            Got it running! (Sort of). Cyl 4 isn't popping, so it's running on three cylinders, not sure why yet. Compression test tomorrow to rule out anything serious.
                            Stupid corn fuel.
                            Gas was absolutely useless. Drained it all and put in some fresh :)
                            • TobyB
                              • 5297
                              #37304
                              '01 325i 5sp
                              OE cooling system parts only.
                              Change fluids regularly.
                              330 front brake parts.
                              Carry a spare coil- change all 6 if you're paranoid.
                              Carry a scanner- BMW Scan140 for me, but it should be BMW specific.
                              Fuel pump every 100k
                              Secondary air pump
                              stuff like that.
                              They're good cars, if you can work on them yourself.
                              Make no sense at all if they're autotragic OR you have to pay someone
                              to do the work.
                              t
                              • Rennsport
                                • 2139
                                #37305
                                Oil seperator/cyclone. The plastic flap will break and get sucked into the motor.
                                m106 1990 e30
                                e36 daily
                                e32 cruiser
