PNW Chit Chat thread
  • Metallated
    • Dec 2016
    • 1074
    #38191
    North Seattle by Greenlake, I'd really like an extra hand, the axel is super stuck :(
    Originally posted by RainRider
    Where you at? I can help. Been seeing your posts for days and I finally have some time.
    • e30austin
      • 15382
      #38192
      Have you tried using a giant punch? One that's bigger than the diameter of that center triangle? I had one really stuck a few days ago, had to use a giant chisel (all I had around at the moment) and an 8 lb sledge and it barely came out. You really need to have something almost as big as the diameter of the shaft to hit on, though.
      • Pdxseth
        • May 2012
        • 3124
        #38193
        Originally posted by djjerme
        Actually, I need that shell. If it's rust free. Or at least close enough.
        That thing has been passed around, it has a damaged c pillar.
        Sent from my iPhone using Tapatalk Pro
        • Savagefurai
          • Apr 2011
          • 970
          #38194
          Guys I'm in need of some help, I'm trying to remove my rear left axel from the hub to get at my wheel bearing and have been unable to.
          Thanks guys, replies and advice very much appreciated.
          I just went through this. I used an old deep socket and a big sledge. It took a few good solid whacks but it finally moved. The real fun comes when you try to get that hub out of there. If I weren't loaned the correct tools for the job, I would still be pounding on that peice of crap. Use a bearing separator, like this to get the hub out. Then, use this Fwd bearing kit to get the bearings pushed out and back in.
          Currently without an e30. Will probably die soon.
          • RainRider
            • Aug 2014
            • 362
            #38195
            Used a large 2 jaw puller. Came off as fast as you can turn the bolt. No hammers needed.
            +1 on that harbor freight fwd bearing set for the rest of the job.
            • Metallated
              • Dec 2016
              • 1074
              #38196
              Huge thanks to RainRider this evening, he was extremely generous and happily loaned out his time and tools to get the job done right; putting it back together from here should be a breeze.
              • Savagefurai
                • Apr 2011
                • 970
                #38197
                Rad. I'm glad to hear it went smoothly. Sure made a hell of a difference with my car once it was all said and done.
                Sent from my Z981 using Tapatalk
                • Metallated
                  • Dec 2016
                  • 1074
                  #38198
                  The only odd thing was when Rainrider and I felt the hub it felt solid, like the bearing was good.
                  The noise was when turning right though so I thought it would be the left bearing, fingers crossed I guess?
                  • 4tDX
                    • Jul 2014
                    • 509
                    #38199
                    Anyone got some early MY fog light connectors (chassis side) or know of any other BMW cars that had them?
                    The markings on some that I have say - cut the wiring too short so I can't reuse them:
                    BMW 1 373 197
                    AMP 926172
                    I can't find them in realoem, but from what I found they are also in e34s.
                    • djjerme
                      • 5082
                      #38200
                      How damaged. Mind you, I have replaced every piece of sheet metal now in the back of my racecar. So the C-pillar doesn't bother me that much.
                      2016 Ford Flex
                      • djjerme
                        • 5082
                        #38201
                        BMW 1 373 197
                        AMP 926172
                        I may have a pair in storage. It's take me a little bit to get some free time to look for them, but I should be able to look by next week.
                        2016 Ford Flex
                        • delamaize
                          • Nov 2013
                          • 1455
                          #38202
                          This
                          I ended up building a tool for myself, I used a 2' section of square stock, with 3 holes drilled in it. first hole was near the end, 2nd one was 100mm on center from the first. the center hole was 50mm from the first hole, on center....See where this is going? All it took then was 2 bolts that would thread into the lug bolt holes, then I used a steering wheel puller for the center, to actually do the work. Made quick work of my stuck axle.
                          Dumpster Fire Pilot
                          • Matt-B
                            The Waffler
                            • 3856
                            #38203
                            I need an e30 for porn
                            • Matt-B
                              The Waffler
                              • 3856
                              #38204
                              Also who has a nice car for a photo shoot?
                              • IronJoe
                                • 2275
                                #38205
                                Roman's is the first car I think of. Or Christian's.
                                '89 Schwarz E30 M3 Cabriolet Build
