Fully refurbished OEM BMW Alpine CM5907 and CM5908 slider radios, Trunk Amps
  • bradnic
    • Jul 2012
    • 3550
    #91
    gotcha ddm-j
    HOWTOs:
    DB vert plastic bumpers
    OEM Keys
    MTech1 docs
    88 ix Lach/Card
    91 ic Calypso 3.1
    86 Cosmo 2.7
    OEM+ or bust!
    • bradnic
      • Jul 2012
      • 3550
      #92
      I have built up an inventory of 9 rebuilt Blaupunkt trunk amps. Just sold 1 of these, please contact me if you're interested.
      All major caps replaced with OEM grade parts
      All power amp ICs tested and replaced where needed with the exact same automotive grade components
      All wires between the main and connector boards are replaced. The insulation on the original wires turns hard and is extremely fragile.
      2 year no BS warranty.
      Price is $175 WITH CORE. I only accept orders I can fill from stock. The core unit must be unmodified and corrosion free.
      NOTE ON TRUNK AMP MOUNTING HARDWARE: I do not supply the mounting bracket or hardware with the refurbished amp. If your core amp has the hardware I will transfer it to your refurbished amp for you no charge. The bracket has been NLA for a long time now.
      HOWTOs:
      OEM Keys
      MTech1 docs
      88 ix Lach/Card
      91 ic Calypso 3.1
      86 Cosmo 2.7
      OEM+ or bust!
      • Mike36
        • 1077
        #93
        Are you taking in spare trunk amps for repair credit?
        • Vincenze
          • Apr 2019
          • 914
          #94
          The amplifier PCB is in front of me. I don't see any power transistors.
          It uses only +12V without any transformation, so the output of each bridged TDA2003 circuit is 14 Watts or less.
          • bradnic
            • Jul 2012
            • 3550
            #95
            Hey Mike - drop me an email.
            you're right I'm referring to the TDA2003s. You're also right they're not just a classic / old school power transistor. The correct term is power amp IC.
            HOWTOs:
            OEM Keys
            MTech1 docs
            88 ix Lach/Card
            91 ic Calypso 3.1
            86 Cosmo 2.7
            OEM+ or bust!
            • Staszek
              • 2533
              #96
              Hmm I may need one of these. I have to look at my amp.
              • aryncarz
                • May 2021
                • 1
                #97
                My 5908 Slide radio is starting to fail looking for new one. Can you help. I also have truck CD systems not using any longer if intersted.
                • bradnic
                  • Jul 2012
                  • 3550
                  #98
                  I've updated the first post to clarify that the refurbished amplifiers DO NOT include the mounting hardware. If your core trunk amp has the mounting hardware included I will transfer it to your refurbished amp no charge. If you do not have the required hardware to mount the trunk amp at all then you will need to procure it separately. There are several auctions on ebay live right now for the trunk amps, and some of those include hardware. I have also seen auctions for the mounting bracket itself.
                  HOWTOs:
                  OEM Keys
                  MTech1 docs
                  88 ix Lach/Card
                  91 ic Calypso 3.1
                  86 Cosmo 2.7
                  OEM+ or bust!
                  • bradnic
                    • Jul 2012
                    • 3550
                    #99
                    4 amps sold. I have another 10 in stock.
                    HOWTOs:
                    OEM Keys
                    MTech1 docs
                    88 ix Lach/Card
                    91 ic Calypso 3.1
                    86 Cosmo 2.7
                    OEM+ or bust!
                    • bradnic
                      • Jul 2012
                      • 3550
                      #100
                      Another amp going to Staszek. Several more available.
                      For those of you looking for a fully rebuilt 5908, bmwman91 has one up for sale on eBay. I source some parts for him, know him to be knowledgeable from his audio/electronics posts on this forum.
                      https://www.ebay.com/itm/BMW-E30-Alp...d/334060297594
                      work done per his listing
                      • Replaced ALL capacitors on the audio amplifier/output board. The originals were bloated and leaking, causing really bad audio output. The sound coming from it now is nice and clean. New caps are Nichicon & Panasonic automotive-rated audio parts.
                      • Replaced both LCD backlight bulbs.
                      • Replaced the amplifier ICs' thermal paste with high performance Arctic Silver
                      • Replaced the cassette transport drive belt.
                      • Replaced the cassette transport with one that is in better working condition. It still has a couple of quirks, but it will insert/eject and play a tape. I went through 3 transports to find the best working one.
                      • Changed the CODE jumpers. What this means is that the code no longer matches the serial number, but considering that dealers are not really helpful anymore, it's a moot point (and dealers' lack of help is why I changed it in the first place).
                      I'm not a fan of changing radio codes, but most people wouldn't care unless you have the original radio code cards, or want to make sure your radio stays with the same code the dealer has on file,
                      UPDATE: bmwman91 has his radio listed for $400 here on r3v! lots of great pictures. He also got the original radio code from the dealer and put the radio back to stock configuration.
                      https://www.r3vlimited.com/board/for...08-w-code-pics
                      HOWTOs:
                      OEM Keys
                      MTech1 docs
                      88 ix Lach/Card
                      91 ic Calypso 3.1
                      86 Cosmo 2.7
                      OEM+ or bust!
                        • 34827
                        #101
                        I saw that one. I also got sniped on a new in box Pioneer KE83ZBM.
                        Still looking for one, I can rebuild it myself if need be. I didn't know you could change the code jumpers? If that's true, then I can expand my search to radios with missing codes (or more importantly, radios where the serial number sticker is long gone).
                        • bradnic
                          • Jul 2012
                          • 3550
                          #102
                          I promised to publish some DIY guides on radio repair back in 2019. Probably time to get that going. The biggest challenge most folks will have are around the tools. A really good desoldering tool is pricey, but essential. It's also about 4-5 times out of 10 alot more involved then just swapping some parts out.
                          nando I have zero doubt you'd be able to handle it.
                          As to re-coding radios, what most people can do is inspect a radio with a known code and replicate / transfer that setup to a different one. Hard hacking the code on a specific radio is definitely not a DIY thing.
                          HOWTOs:
                          OEM Keys
                          MTech1 docs
                          88 ix Lach/Card
                          91 ic Calypso 3.1
                          86 Cosmo 2.7
                          OEM+ or bust!
                          • bradnic
                            • Jul 2012
                            • 3550
                            #103
                            Absolutely. email me bradnic at oemhifi dot com
                            HOWTOs:
                            OEM Keys
                            MTech1 docs
                            88 ix Lach/Card
                            91 ic Calypso 3.1
                            86 Cosmo 2.7
                            OEM+ or bust!
                            • bradnic
                              • Jul 2012
                              • 3550
                              #104
                              jaysterling has some exciting news coming from Canteloupe Radio.
                              HOWTOs:
                              OEM Keys
                              MTech1 docs
                              88 ix Lach/Card
                              91 ic Calypso 3.1
                              86 Cosmo 2.7
                              OEM+ or bust!
                              • Tzantushka
                                • Nov 2018
                                • 389
                                #105
                                You can't leave us hanging like that?!?!?
                                I've been putting up with my CM5907 waiting for updates.
                                E30 320i vert
                                But daily drive is Volvo V60 Polestar
