N52 Swap Discussion
  • Caperix
    • Feb 2018
    • 186
    #466
    Originally posted by nando
    The water pump is not anywhere near the tensioner, and it's not connected to the belt either, not sure how it's related if true. But that would be interesting to know, although the N54 pump is plastic and known to crack, so probably not an upgrade though.
    Sorry about that, I was not very clear. The larger water pump installs below the compressor so I was thinking that was the reason for moving it, though looking into it deeper, an adapter plate is installed on the pump not the compressor as I had thought. This will not effect using the tensioner for a/c delete but it does mean that the compressor length difference is in the pulley not moving the compressor, so the v12 compressor will still be the best route for and.
    While it must flow more I agree that the n54/55 pump would not be a good upgrade due to the common leaks between the plastic & metal parts of the housing, or worse through the connector that can short the dme.
    • hoveringuy
      • Dec 2005
      • 2715
      #467
      This is hopefully the last post from me on the belt tensioners.
      One niggling issue I had when I installed the N54 tensioner is that the belt doesn't appear centered on the pulley, there's a solid 7mm space between the belt and the end of the pulley that makes it look like the belt isn't centered, and that made me concerned that there was a difference in backspacing between the N54 and the X5 tensioners.
      Click image for larger version  Name:	Capture.JPG Views:	0 Size:	72.8 KB ID:	9974797
      So, I did the rational thing and ordered a genuine X5 tensioner, P/N 11-28-7-565-225. The only differences between the N54 tensioner, P/N 11-28-7-563-927 and the X5 one is that the former comes with a steel bolt and the latter an aluminum bolt. Also, it seems that all instances of N52 tensioners have silver tension springs instead of black. Different steel composition or just paint... I dunno. Otherwise, everything else between them was identical.
      E70 X5 on the left and N54 on the right
      Click image for larger version  Name:	Capture2.JPG Views:	0 Size:	71.1 KB ID:	9974796
      I also discovered why my belt looked so cattywampus on the N54 tensioner: the pulley is physically thicker. The N54-style tensioner has a 30mm thick pulley whereas the normal N52 one is only 26mm AND any N54 or N52 with that style tensioner has a 7 rib K07 belt instead of a 6 rib K06 belt!
      I tried mounting a set of 26mm pulleys on the N54 tensioner but that legitimately screws things up because it changes the pulley centerline.
      Notice that the backs of the pulleys are perfectly aligned.
      Click image for larger version  Name:	Capture3.JPG Views:	0 Size:	113.8 KB ID:	9974795
      Bottom line.
      The N54-style tensioner works just fine. You can either order the cheaper N54 tensioner ($65) and then order the aluminum M11x99 bolt that goes with it separately ($15) or just order the X5 tensioner for around $140.
      Sorted.
      • hubcapboy
        • Oct 2017
        • 292
        #468
        While I'm thinking about it and because there's no better place to put it (although I'm sure I've rambled about this... it only became relevant right now)
        There are two kinds of N52 oil pan bolts. The one on the left is for the aluminum (thick flange) automatic pan. The one on the right is for the steel (thin flange) manual pan. The bolts are identical length, but the steel pan bolt has a captive spacer so the bolt "behaves" the same way when tensioned. The challenge here is that the auto pan "kit" has some longer bolts for... whatever the auto pan looks like.
        To get enough of the no-spacer bolts, we ended up buying two auto kits each.
        The reason this is important? If you order bolts for a manual transmission because you have a manual transmission, you’ll probably pull the threads out of the bottom of the block because your bolts won’t have enough embedment.
        Click image for larger version  Name:	File_005.jpeg Views:	0 Size:	59.0 KB ID:	9974814
        • Habla
          • May 2004
          • 1470
          #469
          Well I decided it was time to join the fun and get serious with my slicktop project. Step 1: take out the trash:
          I bought a parts car, an e91 328xi/6mt
          Well damn, that one is too nice and makes a great babymobile. Ok, buy another 6spd e9x! A smashy 330i.
          It also came with bonus interior goodies for the new touring, like heated sport seats and not-ugly wood!
          I'm really enjoying the progress in here!
          -Peter
          -Peter
          318is slicktop | F15 35dM | F250 SD
          • Trevbot
            • Sep 2011
            • 6
            #470
            When progress slows the ongoing joke has been sending him 330i coupes on Craigslist. “You know you can get this drivetrain already in a BMW.”
            • hubcapboy
              • Oct 2017
              • 292
              #471
              *IF ANYONE KNOWS HOW TO GET IN TOUCH WITH AN ADMIN OR MODERATOR WHO CAN ADD A SUB-FORUM FOR THIS ENGINE... I'D LIKE TO PRESENT MY CASE*
              The second post in this thread bought this up, but it seemed like a big ask at the time. We're approaching the number of posts in the S38 sub-forum *just in this post* and I'd LOVE to start getting this stuff sorted out into stickies for each system (Cooling, wiring, mounting, intakes, etc).
              We could also start to break out build threads for the (at least) four cars that are going, because I bet this is getting confusing if you don't know everyone.
              I'm crazy jealous of that e91... Trevbot kindly forgot to remind everyone that I sold this engine already in a BMW once already.
              That being said, here are the random things I've learned in the last 24 hours.
              Magnesium and plastic valve covers have exclusive ignition/injection wiring harnesses. The magnesium valve cover has a long tray that fits nicely:
              In this harness, the umbilical from the DME enters between cyl 4&5, and then the injection wiring is routed around the back of the engine to the injector rail. The plastic valve cover harness management is shorter, and doesn't fit around the bosses on the mag:
              This is a screenshot from a plastic to mag cover conversion video here: https://www.youtube.com/watch?v=5uedpKybBEw&t=1835s and please ignore that the cover is black... he painted it black. that's magnesium. the other thing you notice here is that the wiring crosses over the top of the valve cover instead of looping around the back, and the umbilical *enters* from the back corner. There may be more permutations resulting in even more harness detailing, because the exit location of the umbilical is tied to the side of the car that the DME is on, and several cars came with both plastic and mag cover engines. I think to do this right I'm going to be cracking open the ignition tray and installing the longer (X3 in my case) harness into it, and then using the rear port for the exit. There's no reason for the injector side wiring to pass through that tray any more, which means I can run that harness separately and route it to the DME. I probably don't even have to use my x3 injector harness in that case.
              Last night's project after the kids were asleep was rebuilding the intake manifold and PCV:
              I'm pretty sure my large DISA flap is shot, so I'm working on that, but luckily it's the easy one to swap so it's not critical path. I learned while doing this that there are two version of the 3-stage manifold. one of them has the single pcv port you can see in the center of the "big tube" above. The other has two ports which immediately Y together (discussion here: https://www.e90post.com/forums/showt...php?t=997384):
              Why are they different? who knows. I didn't track down which was earlier or later, or which models, had which one, but it's completely internal to the engine so it was some kind of design revision. If I had to guess I'd say having the port immediately opposite the throttle body caused vacuum issues for the PCV, and a single offset port wasn't ideal, but also didn't warrant a second heater (the difference between the big and small port is the larger one gets a heating element). I ended up with the Y hose in my order, but re-used my single hose. Maybe my intake wasn't original to the engine?
              My goal with Habla for the time being is to delay him as long as possible to probe him for detailed pictures of factory installations... he's already done me one favor by posting that underhood shot and reminding me that the wiring tray goes RIGHT over the middle of the engine. I was scratching my head last night trying to figure out how the factory routing worked behind the engine... and this morning I realized that it DIDN'T, which leaves me with that unsightly braid-covered PCV hose hanging over the top of the intake (it connects to the boot just in front of the butterfly valve. It's hidden under the cowl of the e90, but I'm going to have to find a replacement and snake it somewhere else.
              • Caperix
                • Feb 2018
                • 186
                #472
                Make sure to replace the pcv elbow on the intake, they are under a recall for melting. I have seen some bad enough to damage the intake manifold.
                With the swap parts being developed is everything based around the early n52? I know the differences are minimal but things like the different pcv setup on the latter n52k could make oil pan development easier as it no longer needs the drain. Is the ews delete tune only for msv70 or will it work on msv80 as well?
                • Nowayman
                  • Feb 2012
                  • 193
                  #473
                  I’ll be joining this thread/starting my own shortly. We definitely need a sub forum for this engine! It’s going in my vert👍
                  • hubcapboy
                    • Oct 2017
                    • 292
                    #474
                    Help me nail down which part you mean by the PCV elbow. The small heating element that’s opposite the butterfly? I cleaned and inspected mine before reassembling and it looked new, but I’ll take a closer look if that’s the one you’re talking about.
                    Hoveringuy has a late/plastic, I have an early/magnesium. The drain was definitely another step for my oil pan, but I just drilled a hole and plumbed it into roughly the same location. The late works much better for anyone switching to the n54 intake because they won’t have anywhere to *put* the early PCV system.
                    • Caperix
                      • Feb 2018
                      • 186
                      #475
                      Yes the small 90 degree elbow with a heater plug held on with 2 torx screws on the back of the intake. How long have you had your engine for, the recall came out a few years ago so it may have been replaced before you got it.
                      • hubcapboy
                        • Oct 2017
                        • 292
                        #476
                        It’s a 2006. I’ve only had it for... I don’t want to talk about it but I think it’s two years now lololololol.
                        I’m fairly confident someone has had the intake manifold off before I did. Usually on the recalls they’ll change the part number so I’ll check it the next time I have the intake manifold off (probably to lift the engine in). Thanks for the heads up.
                        • hoveringuy
                          • Dec 2005
                          • 2715
                          #477
                          I thought I was going to be Mr. Awesome by mounting my hardline and putting the radiator back in with MILES of clearance, except the radiator outlet hose elbow wants to be right where my short, direct connection between the thermostat and the hardline is...
                          No amount of fiddling with different hoses worked, so I need to go back to the original thermostat with the different outlet, the original hose for the 330, and then cut the pipe outlet and rotate it 120 degrees, then it will clear fine.
                          I suppose that's still progress because now I know how NOT to do it...
                          • Habla
                            • May 2004
                            • 1470
                            #478
                            The newest BMW I ever had before this was my 92 525it/5. These e9x's are sweet cars! But we all want to find out what they can do with half a ton shaved off...So why not both? haha
                            I can ask the R3V HMIC to look over our case. I'm sure the Kswap nerds have made a similar request by now.
                            Its quite a ride! I will let you know when the e91 gets too small for us, kid, stroller, and 2 dogs. Who knows, it could be tomorrow! Sure beats a damn mk5 jetta though, Byeeee
                            You owned an e9x, but it was weighed down by 50 airbags, 500lb seats, and 11 speakers. You didnt see the potential then.
                            LOL I have no problem being delayed by you, remodel projects, or constantly keeping my 9 month old son from crawling to the fireplace while screaming eagle calls. Not to worry. And I have 2 specimens I can photograph. One early, one late. But I wont be taking the wagon apart unless I have to...install a 3 stage manifold :)
                            -Peter
                            • Trevbot
                              • Sep 2011
                              • 6
                              #479
                              [B]I’m crazy jealous of that e91... Trevbot kindly forgot to remind everyone that I sold this engine already in a BMW once already.
                              That didn’t count as a BMW, it was an automatic.
                              • hoveringuy
                                • Dec 2005
                                • 2715
                                #480
                                Rotated the outlet so it points down and back, clears the radiator outlet like a champ now.
                                Remember, the original rubber hose did clear and the hardline is NOT necessary for an N52 swap. It does make more room for a 50mm radiator and it looks better.
