Markert Motor Works Dyno Thread (many inside)
  • 328ijunkie
    • May 2007
    • 3961
    #106
    Some cool new updates
    Check Us out on Facebook
    Full Product Line Tuning
    • ForcedFirebird
      • Feb 2007
      • 8300
      #107
      Since when is OBD1 tuning a cool update? :p
      john@m20guru.com
      Links:
      • 328ijunkie
        • May 2007
        • 3961
        #108
        Tuned another MCoupe!
        • 328ijunkie
          • May 2007
          • 3961
          #109
          Added another swapped E30, 2 SpecE46s and 2 335s
          • 328ijunkie
            • May 2007
            • 3961
            #110
            Tuned an S54 yesterday. Got 20whp out of it which is extremely rare.....
            • 328ijunkie
              • May 2007
              • 3961
              #111
              344whp!!!!
              Highest HP M3 ever on our Dyno
              E46 M3, BW headers and Race Exhaust, Intake and stock airbox:
              Car came in with a mildly modded by TRM stock tune and put down the baseline numbers which are the highest baseline weve ever seen. After tuning we ended up at 344whp!! Insanity!!!
              • mpowerful
                • Jul 2013
                • 1273
                #112
                Damn. Did it have some sneaky throttle bodies or something hahaha?
                • frankenbeemer
                  • Sep 2009
                  • 2260
                  #113
                  Originally posted by 328ijunkie
                  344whp!!!!
                  How did you do that!?
                  Don't buy an e30
                  They're stupid
                  1989 325is Raged on then sold.
                  1988 325 SETA 2DR Beaten to death, then parted.
                  1988 325 SETA 4DR Parted.
                  1990 325i Cabrio Daily'd, then stored 2 yrs ago.
                  • 328ijunkie
                    • May 2007
                    • 3961
                    #114
                    Mainly vanos changes. Slight increase in Ing advance and major changes to AFR.
                    • 328ijunkie
                      • May 2007
                      • 3961
                      #115
                      Tuned another S54 today, this time it was in an E30 and a R3v Members!
                      Stock airbox, some crazy 3.5" exhaust, also let some oil out on dyno as it was overfilled slightly. Nando Euro Tune vs Dyno tune.
                      And yet another E36 M52. M50 Manifold, S52 cams, OBD2 headers, OBD1 midpipe
                      Stock US tune vs Full tune
                      • LJ851
                        • 7919
                        #116
                        Can't wait to drive this one again now that it's tuned.
                        30whp gain, nice work man!
                        Lorin
                        The M30 is God's engine.
                          • 34844
                          #117
                          Kinda funny how the stock Euro tune kills low end torque!
                          • e30polak
                            • 6136
                            #118
                            The 3.5" exhaust does that, the graph is still shows MUCH lower torque below 3.5k than a stock e46 m3. A stock e46, or an s54 with a proper dual exhaust should make at least 200wtq by 2k rpms. Unless it's a track car, dual 2.5" performs better on most S54s, below 7k rpms. Single exhaust on an S54 ruin low end torque, as the Vanos relies so heavily on scavenging. The same happened when we put a generic X-pipe too close to the headers in my dual 2.5" exhaust on my S54 E30 M3. When we removed the x-pipe I gained 18wtq from 1700 - 3.5k rpms.
                            IMO the 10whp gained up top with the single 3.5" up top and slightly better torque to redline, is not worth the low-end and early mid-range torque. Plus the single 3.5" is obnoxiously loud!
                            INSTAGRAM: @UNDR8D_EMPIRE
                            • 328ijunkie
                              • May 2007
                              • 3961
                              #119
                              For comparison polak
                              Another random S54 E46 i tuned with a mostly stock exhaust setup vs the E30S54
                              • digger
                                • Nov 2005
                                • 6191
                                #120
                                if you put the y-pipe that merges to 3.5" in the right spot you dont lose the bottom end anywhere near as much. seems to be more about length than size in this area of the exhaust.
                                just maintain the twin secondaries (collector) far enough before using a Y or X and you'll be sweet
