M54 Madness, the remix
  • TheAxiom
    • Sep 2015
    • 59
    #211
    Bump.
    E92 Msport
    • hoveringuy
      • Dec 2005
      • 2754
      #212
      I'm still sorting some little stuff before I commit to another dyno. I've put together a 3.5" MAF using a generic housing and an HFM5 series Bosch MAF sensor.
      The older euro 803 that I was using worked Ok but I think it was too susceptible to reverse flow error. The HFM5 series is more modern and should make it run a little better, although I'm not expecting more power with it. The actual sensor is Bosch 0280217007 which is used in Boxsters and Carerras.
      Also, I've sent my throttle body off to Maxbore to be machined from 64mm to 68mm. The stock size for the M54 is 68mm so that only makes sense. The stock MAF on the M54 is also 3.5".
      • Jaker
        • Oct 2013
        • 234
        #213
        That's really cool! I'm very curious to hear how that works out. I'm planning something very similar, but the tube it'll be incorporated into will be CFD designed and optimized for that awful 90 degree turn into the TB, built with CF layup and include the run to the filter down by the headlight.
        • hoveringuy
          • Dec 2005
          • 2754
          #214
          I want...
          • mike25
            • Jan 2014
            • 27
            #215
            Are you planning a rubber concertina section to absorb engine movement?
            Photos of the finished article would be good too.
            • hoveringuy
              • Dec 2005
              • 2754
              #216
              My throttle body is back from Maxbore, $150 to bore it from 64mm-->68mm.
              The stock M54 has a 68mm TB so it makes sense to me that I should go to that size.
              Between the bigger TB, a silicone intake boot, and the the 3.5" MAF with the HFM5 sensor, it'f running great. I need to spend some time tweaking the tune for the changed configuration, and then to the dyno!
              • 2mAn
                Señior Mod
                • 21083
                #217
                That's not a bad price to do that!
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • hoveringuy
                  • Dec 2005
                  • 2754
                  #218
                  They did nice work. 3 day turnaround.
                  I figure 68mm is what BMW thought was the best size on the stock M54. By my maths, the extra 4mm is at least a 14% increase in area.
                  All 3.0 liter motors should probably have this size.
                  • Jaker
                    • Oct 2013
                    • 234
                    #219
                    I currently have a 68mm from Riot Racing on my build. I'm sincerely hoping it's holding back my top end power because I'm about to bolt on a 75mm VAC with opened up IM and hope its worth the effort!
                    • Sh3rpak!ng
                      • Jan 2014
                      • 2667
                      #220
                      Curious to know what both of you find with the larger TBs.
                      I've been hesitant to go larger myself because as I understand, an effect of the larger TB is increased throttle response and my throttle response is already very sensitive with the very lightweight flywheel.
                      Shadetree30
                      • Jaker
                        • Oct 2013
                        • 234
                        #221
                        Can you elaborate? I have the UUC 8lb flywheel, my crank is 12lbs lighter than stock and I have lightweight pistons and rods. I am ecstatic with the throttle response.
                        • Sh3rpak!ng
                          • Jan 2014
                          • 2667
                          #222
                          Well, I read a bunch of reviews a while ago regarding larger TBs increasing "throttle response" and throttle sensitivity (some of those people didn't like it). But now that I think about it, that probably doesn't pertain to someone like you or I who actively search for ways to make our throttle an on/off switch :)
                          Sounds like you probably have a much lighter rotating mass than I do anyway. I am running a twin disc setup from clutchmasters which is a very light rotating mass, and also smaller diameter, though I don't have the extreme weight cutting like you have from the crank etc. The throttle response is fantastic with the super lightweight clutch setup but its also very grabby and tricky to modulate at low speeds. I drive the car a lot on the street still so I don't want it to be impossible to drive in traffic.
                          I am very interested to see how/if this effects the top end though
                          Shadetree30
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            #223
                            There's a local company that makes large TB's that have a progressive linkage on them, mechanically making the throttle open less at tip-in, then opening more rapid as it nears WOT. Think it might be a Wilson Manifolds product.
                            john@m20guru.com
                            Links:
                            • Jaker
                              • Oct 2013
                              • 234
                              #224
                              Dyno, dyno, dyno. We demand Dyno!!!
                              • hoveringuy
                                • Dec 2005
                                • 2754
                                #225
                                Getting closer, I promise! I have a fresh WB O2 sensor coming today to make sure my A/F is accurate.
                                I think my MAF curve is dialed-in for 14.7 everywhere, now I need to update the enrichment for higher fuel loads.
                                Car is running friggin' awesome!
