M54 Madness, the remix
  • digger
    • Nov 2005
    • 6154
    #181
    i've seen 350whp and 250lb-ft from an M54, which is basically same as a FBO s54
    • Jaker
      • Oct 2013
      • 234
      #182
      Not an M54. 3.0 M52 aluminum single Vanos build:
      • craz azn
        • 746
        #183
        ^ Nice! What cams? Compression ratio? Standalone or stock ECU+tune?
        Rippin' Proper | Youtube | Vimeo |
        • Jaker
          • Oct 2013
          • 234
          #184
          Metric Mechanic Rally cams, 11.5:1 comp on 94 octane, Bosch 413 DME tweaked with TunerPro by Zack from www.22rpd.com.
          • craz azn
            • 746
            #185
            Man, that's friggin' amazing! I'll PM you to avoid cluttering up this thread.
            • hoveringuy
              • Dec 2005
              • 2728
              #186
              Amazing! That's one of the strongest NA three-liters I've ever seen. Probably 310 at the crank and a strong torque curve, too.
              Your build needs to be cloned. Props!
                • 34839
                #187
                Looks like MM is on to something with their cams - sweet!
                • CorvallisBMW
                  Long Schlong Longhammer
                  • 13039
                  #188
                  Wow that's an impressive dyno chart, well-built!
                  • Jaker
                    • Oct 2013
                    • 234
                    #189
                    I need one of your dual Vanos controller boards so I can do my conversion easily!!
                    • hoveringuy
                      • Dec 2005
                      • 2728
                      #190
                      I'll trade you for some of your 94 Octane...
                      • 2mAn
                        SeƱior Mod
                        • 20851
                        #191
                        Jaker, do you have a build thread?
                        Simon
                        Current Cars:
                        -1966 Lotus Elan
                        -1986 German Car
                        -2006 Volkswagen Jetta TDI
                        Make R3V Great Again -2020
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          #192
                          Nice Job Jaker.
                          Originally posted by nando
                          270whp and 240 ft/lbs of torque from an M54? I don't believe that, but I'd love to see the dyno sheets to prove me wrong. :)
                          People underrate the m54. Said it already in this thread, the Spec e46's are 225 with completely stock engines aside from DME flash, OBD2 m52 exhaust manifolds and Spec exhaust.
                          john@m20guru.com
                          Links:
                          • Jaker
                            • Oct 2013
                            • 234
                            #193
                            I don't have a build thread and I now feel like I'm hijacking Steve's thread in a big way.
                            • LJ851
                              • 7919
                              #194
                              Sounds like you need to post up a build thread here to redeem yourself.
                              Lorin
                              The M30 is God's engine.
                              • hoveringuy
                                • Dec 2005
                                • 2728
                                #195
                                No, it's cool. Any knowledge that advances the art is welcome.
