M54 Madness, the remix
  • Jaker
    • Oct 2013
    • 234
    #271
    I'm just suggesting that the repair could be done by going to M7 without having to take apart the Vanos.
    • hoveringuy
      • Dec 2005
      • 2722
      #272
      I guess I'm not understanding the advantage of using M7 in place of M6.
      • digger
        • Nov 2005
        • 6145
        #273
        He is saying you can tap the thread from m6x1 to m7x1 with the vanos still attached.
        • hoveringuy
          • Dec 2005
          • 2722
          #274
          Couldn't I do that with M6 as well?
          Edit: Oh, he's saying tap for M7 directly without using a helicoil.
          • Jaker
            • Oct 2013
            • 234
            #275
            :up:
            • hoveringuy
              • Dec 2005
              • 2722
              #276
              Done.
              I pulled the radiator and hood for access, plus removed the VANOS unit.
              The exhaust stud wouldn't have worked because the stud is an M6x60 and the exhaust stud is M7x39. I think it's the longest studs that pulled because they're clamping the thickest section of Aluminum, hence the greatest extra force from thermal expansion.
              Seems fine now, anyway.
              Edit: I helicoiled to use the original stud
              • Jaker
                • Oct 2013
                • 234
                #277
                Mine was single Vanos stuff, and the studs I used were significantly longer than the ones that were stripped. I might have been using intake studs. Either way it's fixed and that's all that matters. What did you end up doing? Helicoil?
