My 2¢ on the s54
  • digger
    • Nov 2005
    • 6196
    hard to compare apples to apples but S52 seems to make a bunch more midrange than s54 when boosted
    • 328ijunkie
      • May 2007
      • 3961
      Improper tuning
      Check Us out on Facebook
      Full Product Line Tuning
      • Andrew325is
        • Jan 2008
        • 1212
        When you compare it to previous generations I assume you mean the previous Euro S50s (S50b30 & S50b32)?
        Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
        • digger
          • Nov 2005
          • 6196
          I meant s52, to be fair the engine turns atleast an extra 1000rpm so torque wont come on as early.
          • varg
            Florida Turbo Man
            • May 2014
            • 3429
            John can you weigh the S54 so there's a (complete) weight to compare with the available info vorshlag put out there for the M20 and M42? It's not that I have any interest in an S54 swap, but I am curious to see what the engine weighs and the resulting changes to an E30's weight distribution.
            IG @turbovarg
            '91 318is, M20 turbo
            • ForcedFirebird
              • Feb 2007
              • 8300
              Updated post #5
              Originally posted by 2mAn
              Tell me more about this b28 combo, you can PM me so I dont derail this thread
              back on topic, what is your overall impression of the S54?
              I notched the pistons to clear bob weights on one of our 2.8 builds. The s54 pistons have notches to clear with it's low rod/stroke ratio. (139mm/91mm = 1.527:1).
              My Impression so far, it appears exactly the way it is: "let's stuff as much displacement as we can in this previously existing exterior shell".
              Never dug this deep into a Euro Spec engine.
              I feel the m20 is like a first generation baby six, the 24v was a second generation, m/s54 is third. Parts from one generation don't necessarily bolt to others, yet they do inside a generation, with the overall design remaining very similar (internal measurements, parts etc).
              Will see what I can do. Should be very similar to any iron 24v, though.
              john@m20guru.com
              Links:
              • ForcedFirebird
                • Feb 2007
                • 8300
                Update to post #8
                john@m20guru.com
                Links:
                • Echo30V
                  • Sep 2017
                  • 301
                  That’s great stuff. IMHO BMW hit its stride with the S54 sans the rod issues. If the crazy idea ever creeped into my beer bloated mind to do a swap, it would have to be the S54-NA Oof course. Keep the info coming Forced.
                  • wazzu70
                    • Jan 2005
                    • 1143
                    Is it possible to get a cutring gasket for the S54? Probably better sealing ability, especially with the low thickness between cylinders.
                    -Nick
                    M42 on VEMS
                    • diesekte
                      • Sep 2013
                      • 417
                      Yeah maximum PSI has them
                      • dude8383
                        • Jan 2005
                        • 10387
                        Yeh, JE makes a cutring. I can get em too :)
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          The tooling to o-ring the blocks is in house and already set up for baby sixes. At this point in the rebuild, it was a no-brainer. Copper wire extended .007" above deck, OEM steel head gasket, ARP studs should do the trick. Snoop around bimmerboost and there's a lot of discussion about cut rings and sealing issues for dailies (but then again, same with Cometic which I have had success using in combination of copper spray).
                          Speaking of studs, I was surprised it took BMW this long to go to 11mm head bolts.
                          john@m20guru.com
                          Links:
