M54. Let the foolishness begin.
  • Danny
    • 14216
    #346
    Originally posted by SoEm0
    I am wondering how I can get this to smog in Cali. I would so love to run a M54 instead of traditional swaps.
    Easy way? Try to pass it off as an M50.
    Hard way? Bend over.
    • SoEm0
      • 449
      #347
      Hmm I am going to have to find out a little more about the bar process. Try and find a way to make this work.
      CCW- when every second counts... The police are just minutes away!
      • Wanganstyle
        • 2828
        #348
        CAli BAR + M54b30 in an e30?
        sure, can be done.
        give me complete M54b30 car, and about 2 months...... it would NOT be cheap.
        CAli bar requirements requires the replacement engine to be used with its factory DME and full emissions control ; complete OBD2 with its full evap system would need to be installed.
        S52 converted to OBD1 is NOT cali smog legal. Most definately not bar legal at all
        if you want to "pass" smog, there are ways to "pass".
        • SoEm0
          • 449
          #349
          The m50 and m54 look similar.... guess its time to start searching.
          • Wanganstyle
            • 2828
            #350
            similar yes, but BAR legal - NO.
            no engine can be swapped and pass bar legitimately unless its original DME and full emissions system is also installed with it.
            Legitimate pass and "pass" are different things, I would prefer to be 100% by the rules if playing that game.
            if goal is bar legal, stuff in entire M50. easier to tweak for top end power as well- better for boosting....etc
            • e30polak
              • 6136
              #351
              Just run an m50 intake manifold on it, and the person doing the bar test will have no clue. Pass it off as an M50 by switching to an OBD1 valve cover. :p
              INSTAGRAM: @UNDR8D_EMPIRE
              • Wanganstyle
                • 2828
                #352
                I dont think its bolt on though....
                word on the street is that Single vanos can be bolted on to the m54 head, and it might actually work - this would be an interesting way to get an ALU motor;l
                get M54b30 +S52 valvetrain and single vanos+headers+ some hybrid intake manifold and m44 CPS and OBD1 everything.....
                but you would loose dual vanos.
                • e30polak
                  • 6136
                  #353
                  Both the m50 and m52 intake manifolds can physically bolt-on to the m54, as well as the headers for either motor.
                  • DRTSRFR
                    • May 2008
                    • 1836
                    #354
                    Ryan G just got done with an S54 swap in his M3...very impressive...
                    But it'll never pass Cali Smog:hitler:
                    http://forum.norcale30.com/showthread.php?t=11433
                    Suspension tips here...
                    http://www.r3vlimited.com/board/album.php?albumid=757
                    • SoEm0
                      • 449
                      #355
                      Even the intake mani's between the M50 and 54 look similar. I am guessing swapping to a single vanos head wouldn't matter too much since I think Hovering isn't controlling his exhaust vanos. I wouldn't boost an M50 either since that wouldn't pass smog anyways.
                      • SpecM
                        • Oct 2005
                        • 4531
                        #356
                        that's so stupid that you have to have full OBD II everything on a Cali car
                        even an OBD I m54 is WAY cleaner than an m20, or even m50
                        isn't that the goal? clean?
                        1989 cirrisblau-metallic 325i
                        • SoEm0
                          • 449
                          #357
                          LOL I fully agree with you Spec. My friend and I had this discussion the other day. I was plotting on his M54b30 and the topic came up.
                          • Wanganstyle
                            • 2828
                            #358
                            wow;
                            so then I can just buy a M54b30 and bolt on S52 cams and towers and headers and intake and have cheap plentiful ALU motor. damm
                            cps sensor bolts on as well, is there a place for the crank position sensor to also go on m54 head? im guessing yes? or no port there for it-
                            • hoveringuy
                              • Dec 2005
                              • 2727
                              #359
                              wow;
                              Here's what my actual emission looked like with OBD2 cats:
                              ............. HC (ppm).. .....CO(%).. CO+CO2(%)........ O2(%)
                              limit............ 150........... 1................ 6................ n/a
                              cruise...........54......... .08 ............14.88............. .25
                              limit............. 220......... 1.2............... 6................ n/a
                              idle.............. 64 ........ .01 ...... .... 13.81 ........... 1.58
                              A suprising amount of the m50 stuff bolts to the M54. I'm using S50B32 exhaust manifolds.
                              Don't know about S52 cams, but I doubt they would fit as the head is not interchangeable at all.
                              You can put the crank sensor on the head but it won't do much good...
                              • SoEm0
                                • 449
                                #360
                                so a head from a S50/2 can't make its way to the block?
