24V AWD Swap Knowledge Base
This is a sticky topic.
  • stonea
    • 2892
    #931
    Originally posted by nando
    the input shaft is further from the diff so it should clear just fine. It didn't clear the E34 diff in the E34 pan, but that's because the E34 diff is a couple inches further forward than the E30. The E34 diff wouldn't clear the E30 rack either, at least not without modifications to the oil pan or pushing the engine further back.
    Maybe thats what I was thinking of. I need to read up on all of this stuff again.
    My Garage
    Feedback
    Instagram: Stone.Hopkins
    • Nisse Järnet
      • Aug 2013
      • 1221
      #932
      Thanks, interesting !
      E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
      E30 M50 6 spd 764whp @ 24psi.
      E30 M20 6 spd 675whp.
      • The Dark Side of Will
        • Jun 2010
        • 2796
        #933
        Originally posted by stonea
        Does anyone happen to know if the internals of a e30 M3 rack fit in a ix rack? I'm sure no one does and I kind of doubt it would work. If it did, I know the cost vs benefit wouldn't equal out, but I've just been thinking about it recently.
        Won't work - they are completely different.
        Have you looked at the guts for each? Is the iX rack a different length or has the input in a different place than (I @$$ume) the E36 rack?
        We know the housings and mounts are different, just wondering about the rack gear and pinion itself.
          • 34844
          #934
          Input is in the wrong place.
          • Sebbe
            • Feb 2016
            • 17
            #935
            Does anyone know if the 525ix outer cv joint just pulls off the axle, or if there is a c-clip or anything?
            • nomansland92
              • 1657
              #936
              They just pull off
              IX being restored here
              Ix turbo build here
              • Nisse Järnet
                • Aug 2013
                • 1221
                #937
                Originally posted by nomansland92
                They just pull off
                Yep, thats right!
                • flyboyx
                  • 8371
                  #938
                  the inner pulls off as i recall. it has those three little bearing wheels. i think i remember the outer having a circlip that goes the opposite way the e30's axle does?
                  Gigitty Gigitty!!!!
                  • Nisse Järnet
                    • Aug 2013
                    • 1221
                    #939
                    No the outers just pulls of, but don't break anything :) On the inners you have to bend the locking thing around the whole CV. You will understand when you take the boot off.
                    • Sebbe
                      • Feb 2016
                      • 17
                      #940
                      Thanks! After some gentle hammering it popped right off.
                      • Sebbe
                        • Feb 2016
                        • 17
                        #941
                        Does anyone know if the E30 outer ball joint will fit the E34? They look very similar and the locking nut is m14x1.5 on both cars. One of the outer ball joints on my 525ix is bad, and i really dont want to spend 300$ on a replacement control arm.
                        • Nisse Järnet
                          • Aug 2013
                          • 1221
                          #942
                          Hmm i tried some parts between E34 and E30 but i dont remember everything...but i think the "cone" was different, or i just mixed that up with the tie rod ball joint :P
                          • flyboyx
                            • 8371
                            #943
                            lol. i think the best thing to do would be to consult realoem. if the part numbers match, the part fits. if not, you should probably just buy the part that fits. mmmm-kay?
                            more than likely, an e34 rwd or e36 ball joint would be more correct than an e30's.
                            Gigitty Gigitty!!!!
                              • 34844
                              #944
                              that's true, but remember, on newer cars BMW broke out individual part #s for less and less assemblies. A good example would be the differentials. You could (before it all went NLA) get every nut, bolt, washer and bearing individually for an E30 diff, but on a newer car, you can only order the entire diff. on the E34 ix, BMW didn't break down the transfercase, so the individual parts are not replaceable.
                              • Sebbe
                                • Feb 2016
                                • 17
                                #945
                                There is no OEM replacement ball joints for either the E30 or E34, only the whole control arm, a couple of aftermarket companies sell ball joints for the E30, but not E34. E36 ball joints doesnt fit, they are M12, RWD E34 ball joints are M14 so they might fit, but i can only find complete control arms.
                                I dont think BMW made a special ball joint for the 8000 or so 525ix's they sold. So in guessing its either a 325ix ball joint or RWD E34.
