The Detailed E30 R-134a Conversion Thread/DIY
  • 95///M3
    • Mar 2005
    • 181
    #46
    Thanks for the write-up.
    Finished all fo the o-rings, drier, and expansion valve. Waiting on the condenser and fan.
    What 134 fittings are recommended for the converted system?
    Jim
    • immajackuup
      • Dec 2010
      • 1132
      #47
      Jim
      http://www.pelicanparts.com/cgi-bin/...abel%2C%20Each
      • McGyver
        • 4633
        #48
        holy shit that a great write up. i just drained the R12 and refilled with 134a, and i can say that it has to be going 40mph to get the air flow over the condenser to work enough to tell.
        i'll follow this when i have the cash to do it properly. thanks!
        • Dirtboy
          • 458
          #49
          Very good write up! Just what I've been looking for.
          I plan on retrofitting AC into my non-AC euro car when it gets here. I'm thinking the hardest part of the retrofit is gonna be the wiring. Got any tips on that?
          Nürburgring info
          • glucklich21
            • 1912
            #50
            What year E30?
            You will need the HVAC unit out of an AC E30 though, but I bet you know that. ;)
            Most of your wiring for your AC system will be on the unit itself except for the part in the body harness that goes to the compressor and pressure switch. On mine there was a wide white connector on the right side of the steering column that went to the HVAC box under the dash. If you're lucky BMW included that in all of the harnesses, if not it's only 3 wires to run.
            • immajackuup
              • Dec 2010
              • 1132
              #51
              freon pounds gluck??
              • glucklich21
                • 1912
                #52
                Mini update on my system.
                So I blew one of my compressor hoses on the way back from Dallas a few weeks ago. Looked like this:
                So after I replaced the line with a new one, I went and had it recharged. The mechanic let me watch the pressures as he was charging. We ended up at exactly 28oz of freon and 51 psi on the low and 170 psi on the high for the pressures, not far off from the nominal pressures. Today it was 94 outside and my vent temp was exactly 40 degrees. It was quite nice. :)
                • glucklich21
                  • 1912
                  #53
                  See above, 28oz.
                  • jrobie79
                    • Mar 2006
                    • 2526
                    #54
                    Originally posted by glucklich21
                    See above, 28oz.
                    m42 cars have the same size system?
                    1991 318i ---- 308K - retired
                    • glucklich21
                      • 1912
                      #55
                      Yes. The volume in the compressor and different lines is negligible to the point BMW makes no note of it even in the official conversion document.
                      My E30 is a M42 powered car. ;)
                      • immajackuup
                        • Dec 2010
                        • 1132
                        #56
                        See above, 28oz.
                        thx gluck!
                        • MaksV
                          • 1042
                          #57
                          We did a M20 powered car in the garage the other day. Janky ass rebuild ebay compressor was the worst of it. If anyone has a source for new M20 compressors posting here would be good.
                          CHEAP REBUILT INJECTORS
                          Need Quality Brakes? BimmerBrakes has it!
                          For anything Else go with BluntTech!
                          • cholyoke
                            • Feb 2006
                            • 186
                            #58
                            Thanks for writing this conversion up. I've got an eta and am replacing all of the lines. Does anyone know the difference between the evaporator to reciever/dryer line in the early cars vs late cars? The one for the early cars (64-53-1-380-094) is NLA. Is the location of the reciever/dryer in a different location?
                            • glucklich21
                              • 1912
                              #59
                              Doubt it. I imagine it has something to do with the charge fittings used.
                              • Dirtboy
                                • 458
                                #60
                                What year E30?
                                Mines an 89 325i. I'll be scouring the junkyards looking for a HVAC unit out of a car with AC. I'm not too sure about the connector by the steering column. I'll have to check when I get the car back. I also noticed that I'll have to cut a hole in the engine compartment where the AC lines go into the cabin. There are no punch out holes there.
                                Nürburgring info
