just got all my parts ready for this project to fuck me somehow in someway
The Detailed E30 R-134a Conversion Thread/DIY
anyone found a cheaper source for the condenser? I found one on ebay for only 78 bux shipped...but I'm hesitant as there is no manufacturer specified.1991 318is --- currently not road worthy
1991 318i ---- 308K - retired
Does the improved combinated refrigernat pressure switch (P/N: 64 53 8 390 971) always have to be fitted during a R12-to-R134 retrofit?
Will the dual switch setup work properly with R134?
My system has the original dual switch setup. Hi-pressure and low-pressure refrigerant pressure switches. After the conversion the A/C worked fine for 4 days, and now the compressor will activate in 3 sec intervals. Not normal cycling.
Originally posted by jrobie79 View Postanyone found a cheaper source for the condenser? I found one on ebay for only 78 bux shipped...but I'm hesitant as there is no manufacturer specified.
Originally posted by Davidov View PostDoes the improved combinated refrigernat pressure switch (P/N: 64 53 8 390 971) always have to be fitted during a R12-to-R134 retrofit?
My friend had the same setup on his 88. We ended up keeping both as we went with a rebuild compressor of his old one. You might be able to just by pass the second switch going to the compressor and wire in for it to function off of one. This is how it is in later style E30s.
As for it kicking on and off that quick 3 things come to mind:
1: Pressures are off
2: Something is plugged up in the switch or is just faulty
3: Clutch on the compressor is bad
ok. i just did the drier and switch and the soft high pressure line. Then the hood fell and destroyed the rigid high pressure line. Luckily a quick run to my e30 parts source found out that a 318 high pressure line relocates the high pressure port outta harms way of the hinge. score!! the question is what are the pressure switches levels?? high and low??? I found one site that side like 28psi and 426!!!! i had to convert to psi from metric english something or other.
You guys say your putin in like 28oz???? thats gotta be volume right?? the label in the my car specs 2.10 lbs r-12 so 2.1X75%=1.61lbs r134. I put in 1.55 and the high pressue gauge goes over 300psi!!!!!! when the heck does that switch shut off????!!! Dang sure i didnt over fill cuz one of the pdf referenced here specs 1.98lbs r134. input plzNow with 2.7i power!!!
Nice write-up. 12/86 325iC: retrofit in progressLast edited by cabriodster87; 08-22-2012, 07:17 AM.sigpic
Reich und Roll!
it totally missed that pdf somehow.... Hmm.. thanks... I'll have to do some more diag on the actual car car and those pressure numbers. it was crankin hot and stupid humid when I checked it last. I doubt there was residual freon. It was empty to start w and i evac'd it like 3 times for 15-20 mn each time. It could be to much oil, maybe. I'll check it against that chart though. THANK YOU for pointing out the one pdf i didnt read:) good suggestion.
And guy postin above: just run it till it dies then buy new if needed. I think you can rebuild w the proper seals though. I'm runnin a 134a non compliant compressor till it dies. check older posts in this thread, im know others have commented on it too.Now with 2.7i power!!!
I just have a quick Q, is this a good electric fan option?
http://www.jegs.com/webapp/wcs/store...OrderCalculate
Thanks
