The Detailed E30 R-134a Conversion Thread/DIY
  • ParsedOut
    • Sep 2005
    • 1437
    #241
    Originally posted by glucklich21
    ...but it's your car do what you please, just do it in another thread.
    I seriously appreciate what you've done here in this thread and talking about a different refrigerant takes nothing away from it. Everything still applies except the R134a. Your attitude on the matter is immature, I guess I'll take my ball and go home.
    • cavpilot
      • Dec 2013
      • 112
      #242
      Finally got around to getting my a/c charged after doing the retrofit as described here. Works great! Thanks glucklich21 for the DIY!
      • Luke_M
        • Aug 2011
        • 275
        #243
        He guys. What would cause the system to freeze up? Either the exp valve or evaporator.
        Here's my setup:
        - '89 325i, 24v swap
        - new compressor, new pf condenser and 16" fan, new suction hose and dryer
        - replaced all o-rings with the exception of the two on the bottom of the Exp Valve
        - kept the old exp valve and pressure switch and all other lines are original
        - just added tar like tape to the expansion valve last week.
        - It's recently gotten very hot & muggy out
        - Confirmed that the fan is working. 16" pusher and 12" puller
        - Just checked low side pressure at 60psi at idle, 45psi when revving.
        - I see a steady stream of white in the sight glass and the occasional small bubble. I'm told this is normal from an hvac friend of mine.
        It was working great for about a month (about 30 below ambient, could use lower but I'm not complaining) but I've recently noticed that it will stop blowing cold after driving for a while. Oddly it will sometimes work fine on the way to a destination and then not work at all when I leave. I'm talking 30 minute drives and an hour or so wait. If I'm doing a lot of sporadic driving around town it will work off and on, mostly off.
        I've turned it off once for about 15 minutes, still driving. It came back just fine hence the frozen part suspicion.
        Would the tape cause it to freeze over? Or am I leaking freon causing it to freeze over when it gets low?
        Picture of the exp valve tape: https://www.dropbox.com/s/4v09nbubv1...613_105125.jpg
        Euro S50 Daily Driver: http://www.r3vlimited.com/board/showthread.php?t=279195
        • Luke_M
          • Aug 2011
          • 275
          #244
          I just remembered that I've been hearing a hiss sound from the dash area for the last few weeks. I'm starting to strongly suspect I'm low on freon.
          • jeffnhiscars
            • Jun 2011
            • 6011
            #245
            30 below ambient is excellent for a car. You should check for the probe that goes in to the evaporator from just above the gas pedal. Its designed to cut the compressor off when the evap temp gets to 37 to avoid icing. You also should use a 134 exp valve but I wouldnt open an otherwise funcitoning system just to change that
            Alice the Time Capsule
            • clint-o-matic
              • 36
              #246
              Thanks for this DIY. I ordered all the parts today and will attempt the conversion next weekend.
              • Luke_M
                • Aug 2011
                • 275
                #247
                I think I have a freezing expansion valve. The most likely reason for this is I used a janky venturi style vacuum pump instead of a traditional vacuum pump. It didn't get a full 29hg, maybe 27-28hg, and after looking at some charts I didn't get close to boiling off the moisture. Most likely the major heat and humidity is causing excess moisture in the system and it freezes up after approx 30 minutes.
                • ParsedOut
                  • Sep 2005
                  • 1437
                  #248
                  30 below ambient sucks if it's hot out. With 110 ambient, if my A/C blew 80 degrees at me I'd not be happy. My E32 blows 47 degrees while moving and about 55 while idling in 110 ambient. I'd expect the same from a properly converted E30.
                  Speaking of, my E30 conversion is done but I haven't driven the car since the idle is so rough without tapping into the ECU for idle bump. Don't have the time to dick with it right now and the 735il is more than sufficient right now.
                  • jrobie79
                    • Mar 2006
                    • 2526
                    #249
                    I'm going to be recharging with r12 (grandfather has a boatload in his shed)...however the system was in pieces, will the new pressure switch and dryer still work with r12? i believe the new green o-rings are backwards compatible correct?
                    also I have to buy a new condensor? would the parallel flow people are finding on amazon or carpart kings not be good if i was keeping r12?
                    1991 318i ---- 308K - retired
                    • adjmcloon
                      • Apr 2012
                      • 446
                      #250
                      For those of you getting a new compressor, is anybody getting a Sanden? If so, what are you using to mount it?
                      • jd_e30
                        • Mar 2014
                        • 171
                        #251
                        I'd go with the 4 seasons compressor which I think bolts right in. I can get part number later...
                        1990 325i
                        • Luke_M
                          • Aug 2011
                          • 275
                          #252
                          Update on my small problem. Turned out to be a loose electrical connection on the compressor. Duh. Always check the simple things I guess.
                          • e30 gangsta
                            • 3877
                            #253
                            seltec compressor all day.
                            • jeffnhiscars
                              • Jun 2011
                              • 6011
                              #254
                              I've had a slow leak since I did my system upgrade and in 2 minutes I found it with this.
                              $26 at Amazon
                              • 510man
                                • May 2013
                                • 17
                                #255
                                I used the Sanden. I had a bracket kit that came with the car when I bought. My point, somebody makes this kit so you don't have to figure it all out.
