Racing camshafts
  • hasa
    • May 2013
    • 306
    Racing camshafts
    Does someone have here experiences about M20 racing camshafts. I'd classify anything that goes beyond Schrick 304 as "racing".
    Motivation for the question is that I'd like to replace my Schrick 304 by something that delivers more in the 5000-7500 range in a 84mm stroke engine. RHD roller cam setup is of course the ultimate solution, but how about Cat Cams, dBilas or similar?
  • digger
    • Nov 2005
    • 6160
    what are the detail specs of your engine and what does the actual power curve look like?
    If a schrick 304 isn't running easily to 7500 there is it is reasonably likely something else in the system that's not spec'd appropriately for that rpm.
    for example with a 288 cam in a 2.8-3L will peak around 7000 with a RHD ITB setup
    • hasa
      • May 2013
      • 306
      Yes my current setup has restrictive parts, you are right. 40mm id/ 45mm od headers secondaries are first suspect. Stock 885 head and 2.5” single exhaust after that.
      But I’d still hear, if anyone here has used those hotter cams.
      • digger
        • Nov 2005
        • 6160
        Not sure what info you are looking for but finding good valve springs and getting rockers to live is the issue that I know people in these parts had with big catcams they used
        • moatilliatta
          • 6151
          I think metric mechanic now has their steel rockers released.
          @Zakspeed_US
          • digger
            • Nov 2005
            • 6160
            They have m30 ones not sure about m20 though.
            catcams do a steel rocker but pretty spendy
            • hasa
              • May 2013
              • 306
              So you say that it does not work with std rockers to go beyond Schrick 304? I can understand that, if the acceleration forces just become too high no matter which valve springs are there.
              My experiences with racing engines have always emphasized that the springs must be stiff enough so that valve float does not occur. Whenever the springs cannot control the valvetrain movements, many different evil things happen. Of course the spring stiffness may be too much for the components too.
              Cat Cams seems to suggest their 115kg springs to all the hottest cams
              dBilas promotes their "120kp" springs to all applications that require spring upgrade
              PPF on Sweden seem to sell some insane springs for the turbo applications
              http://server.pure-pf.com/webshop2/e...t-stage-3.html
              • digger
                • Nov 2005
                • 6160
                The OE rockers will physically work unless the cam is stated as not being compatible.I was referring to the HD rockers may not as the pad is different on some earlier versions. they may have addressed this but pad quality seems questionable.
                One issue is good quality springs without them going soft. PAC sell a beehive spring and retainer iirc that’s compatible, it’s from a ford 2v modular engine.
                With stuffer sorings then you rockers that can withstand the higher loads and surface speeds that are required.
                you can run what the cam companies recommend but it’s worth looking at alternatives
                • TobyB
                  • 5268
                  I usually only experience one evil thing- on throttle lift- off, an intake rocker breaks.
                  Yes, the stock rockers with the right springs will go to 7500 and sit there all day. IF they don't have
                  voids in them, and that's getting to be hard to prove (got x-ray?)
                  Yes, some cams are too aggressive for any rocker- as hasa implies, it's not the acceleration,
                  it's the deceleration that's the problem. If the lobe isn't too steep for the lash pad,
                  and doesn't drop away like a cliff, it can be made to work.
                  'How long will it last?' is always a valid question, too, as high spring pressures
                  put a lot of load on the lobes and pads.
                  One thing you do not discuss is intake- 40mm itbs would be the minimum for 7500,
                  and much above that, bigger would be better.
                  t
                  • digger
                    • Nov 2005
                    • 6160
                    t
                    I think in another thread he may have jenvey 45 throttles for some time already and now a ported head to go in at the same time as the cam.
                    • hasa
                      • May 2013
                      • 306
                      My particular engine combo is
                      84 crank
                      11.5cr forged bottom
                      195cfm ported AMC head
                      dbilas+jenvey 45mm intake side
                      semi-long generic headers
                      I consider purchasing dBilas 312 or anything similar from Cat Cams. I'll first check how much I have room for valve opening at TDC. I did it some time ago, but can't recall.
                      • Maximumtune30
                        • Apr 2021
                        • 15
                        A shop in Finland called Vp-motorsport sells steel rockers for the m20, 500€ for a 12x set. I'm not sure if they will ship them to you though.
                        Another shop called Futurez sells steel rockers made by ENEM 535€ for 12x set, but they only sell them if you buy a enem cam from them, i don't think they sell them seperately.
                        • digger
                          • Nov 2005
                          • 6160
                          i've got sample of the Enem ones and they dont look very good from pad geometric profile (will produce difference valve lift though haven't measured to quantify) and surface finish, they pale in comparison to the catcams sample i have but costs is alot different so.....
                          • AWDBOB
                            hooptie connoisseur
                            • Aug 2013
                            • 4487
                            I have a spare set of these I could be convinced to let go of if you're on the hunt, hasa.
                            Get top-quality crankshafts, connecting rods, and forged pistons at PPM Racing. Our cutting-edge technology, including CNC machining and computer-aided solid modelling, ensures maximum strength and weight savings. Choose from 2618 or 4032 grade aluminium alloy, with hand de-burred pistons and precision-milled ring grooves for low-drag, lightweight performance. Experience the best in design and manufacturing with PPM Racing.
                            • hasa
                              • May 2013
                              • 306
                              https://www.pureperformancemotorspor...cker-arms.html
                              Thanks for the offer, but I'll try to get along with the OEM rockers.
                              I've understood that these HD rockers are all (except RHD) targeted for the turbo scene, where exhaust backpressure sets unique requirements for the rocker strength. I may be wrong... but anyway.
