M20 fan clutch (defective from the box?)
  • zaq123
    • Jul 2016
    • 1570
    I need help to figure out what's happening with my overheating issue. New built, coolant was vacuum bled so I don't think air pockets is the issue, I think...
    45F outside temperature. When driving, coolant is around 190-195F, middle position of the gauge. When stopped, it climbes to 207F-210 based on my ECU (about between middle and the next line on the gauge). I'm yet to let it got past 210F so I'm not sure where it would actually stop. Temp. goes back to normal when the car is in motion.
    My first clutch was new Sach , manuf. date 2018. When engine was hot, I was able to stop it with a piece of cardboard and could hold it with my hand after that. Figured bad clutch. Maybe was stored in the wrong position? I saw a little oil around the pin, where the thermoplate is. Ok, replaced it with new Meyle (china made these days). No signs of oil. The same overheating issues. And I'm able to stop the clutch with the cardboard and hold it with my hand just like Sach.
    Two bad clutched out of the box?? What's your thoughts.
  • digger
    • Nov 2005
    • 6206
    wouldnt be the first time they have been bad out of the box
    the clutch fan essentially has no idea the temp of the coolant, the temperature of the clutch itself (metallic strip)matters. Presumably the radiator has hot coolant flowing? i am wondering if you get it to 210F and shut off the engine how hot is the actual clutch? with 45F there might be a decent lag between coolant temp and the temp of the clutch. Also can put a heat gun on it and periodically monitor the the temp with a infrared laser thermometer to see if it starts to lock up kind of bench test
    you can also add more silicone
    • McGyver
      • 4636
      Any chance the coolant pipes are plumbed backwards somewhere?
      • reelizmpro
        • 9558
        I wouldn't doubt it nowadays. If it fails the newspaper test, then it's not effective. Before replacing it again though, you want to check to see if the system is holding pressure.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • zaq123
          • Jul 2016
          • 1570
          no everything is as it should
          • zaq123
            • Jul 2016
            • 1570
            system is holding pressure and vacuum, totally vacuum bled with no air when filled (vacuum filled back up with the coolant) and then pressurized thru coolant tank cap (with the heater core valve open) to insure that only coolant comes out from the top of the radiator (thin hose).
            • zaq123
              • Jul 2016
              • 1570
              So I let her run past 207F. Also I'm using BMW 80° C Thermostat - Mahle Behr 11531713040. Looked at the receipt to remind myself.
              My observation reading temps thru Haltech ECU (new OEM NTC bosch sensor is correctly calibrated for Haltech btw):
              cold 56F start. Fan blades can't be stopped by the cardboard. Warm up to about 90F - clutch fan disengages and can be stopped. Not sure if it takes time for the clutch to disengage/displace silicone oil hence the result??? Temp climbes to 207-208F, clutch engages/fan can't be stopped by the cardboard. Temp drops to 197-198F - clutch disengages.
              I witnessed a consistent repeat of the above about 3-4 times, same temp range, same results.
              Could it be that Meyle is using a temperature plate that has a properties for a modern-ish car? Those numbers would be perfect for like e46 spec for example (coolant temp 194-230F) when m20 is like 175-200. Basicaly my dash gauge is at half mark when moving and it's like half way to 3/4 mark when idling. Which I think is a little high for M20.
              Sach clutch I had which I thought was defective is 2018 manuf date. I never played with it and just replaced it. I found another Sach fan clutch which is new and was manuf in 2002. I'll give it a shot I guess. Luckily I can still return that Myele Chinese unit
              • digger
                • Nov 2005
                • 6206
                that might actually be normal (or close to it) due to the inherent higher temp at the blue sensor and that the rad temp switch is like 99c/210F (some are dual 91/99) so it may not be designed / intended to maintain something like 80-85C as it would need to kick in at a lower temp than the coolant. Noting that the fan clutch is mostly heated by the air coming through the radiator which is always lower than the coolant temp in t-stat/head so there should be some delta/difference to what the t-stat housing sees .
                Admittedly though the 3/4 mark does seem high but more so for that sub 100C registering as 3/4, as mine has never quite seen 3/4 even on a very hot day with A/C cranking stuck in heavy traffic where it got to 105 once as depicted by the ecu sensor in the T-stat housing so would expect 3/4 gauge to be more like 105-110C but there could be some variability among vehicles based on ground offsets or new vs old sensors.
                • zaq123
                  • Jul 2016
                  • 1570
                  I'm yet to see 3/4 mark but it looks like 208F (the highest I see) is like half way between the middle mark and 3/4. Im gonna change the clutch to Sach since it's a simple enough to do just to see what happens.
                  • varg
                    Florida Turbo Man
                    • May 2014
                    • 3436
                    Having seen the internals of fan clutches, I don't believe in the "they have to be stored vertically like they are in the engine bay". Maybe they shouldn't be stored water pump flange down in case the shaft seal leaks, but I don't see how being stored face down could cause a problem, or even flange down if the seal isn't leaking, once it's installed and spun up the oil is going to migrate to where it should be. That said, I've had a bad out of the box fan clutch before, CRP brand from FCP euro. It seemed to just freewheel and I shut the car off before the temp got above 215°F because I know that's not normal and I'm not tempting my M20 heads. I replaced it with a Mahle brand which cost 4x as much but worked and still does almost 8 years later.
                    IG @turbovarg
                    '91 318is, M20 turbo
                    • zaq123
                      • Jul 2016
                      • 1570
                      I installed new 2002 manuf date haha Sach I got but yet to run it. I did noticed that all of them, including Mayle I just removed have TB 1577 A-GE marked thermoplate on them. Researched shows that this plate starts deflecting around 95C/203F. So in theory, clutch won't engage till that temp (air from the radiator). I guess 207-208F engagement point ( I observed with Merle) is a normal operation as digger noted.
