What oil do you use?
  • jeffnhiscars
    • Jun 2011
    • 6011
    #91
    I stopped by Autozone today and they have 5 qts if Mobil 1 15-50 for $33 including a Bosch filter. Killer deal good thru 9/23
    Alice the Time Capsule
    • squidmaster
      • Aug 2011
      • 2666
      #92
      Advance Auto also has rotella 15w-40 for $13 per 5 quarts
      • 3vilE30
        • Jan 2013
        • 344
        #93
        Mobil Delvac 15w40 Diesel Oil
        Better than regular, thicker than synthetic
        Has ZDDP additives that our worn out cams need, rated close to what m20s seem to like running (15w50+)
        Don't worry about it being diesel oil; I know modded Supra guys that run it and swear by the stuff
        +1waffles
        wafflesI was shocked when I asked my uncle what he uses in his recently rebuilt mkiv been pushing 700+hp on mobil delvac 15w-40
        I myself have been switching brands, castrol is baseline ran well Dino 20w-50, vr1 ran really well excellent for hotter months Dino 20w-40, diesel oil is good for all around currently on valveoline premium blue Dino 15w-40. I'll definitely stick with diesel oils, be cautious for hotter months I had this stuff in 100+ weather temp gauge sat way higher then with 20-50 vr1. It stuck around half a tad below it, a little scary. I did notice valve tick was at a minimum with vr1, but did turn black rather quick approx. 1500 I switched it out for premium blue.
          • 34844
          #94
          the irony is a 15w40 is probably too thin for an M20, especially when it gets hot.
          Bogging etc. is unlikely to be related to the oil you used.
          meanwhile, I'll continue to trust the oil that has worked in an M20 for 1,000,000 miles, and in my own since it was 300 miles old. :p
          • digger
            • Nov 2005
            • 6194
            #95
            it probably depends where it is driven and how hard. on a hot day at the track for sure 40 would be most likely a bit too thin. i wonder if just looking at oil temp and pressure on a VDO gauge or similar is a good method to tell you if you are running a suitable weight?
            • illest318i
              • 1472
              #96
              I currently have Castrol Gtx 20w-50
              So far so good!
              IG: @_j.wn
              • NJ2.5rser
                • May 2013
                • 527
                #97
                I use a high mileage 5w30 or high mileage 10w30 depending on the time of year. I feel unless your boosted or use it for track purposes you will never reap the benefits of synthetic oil.
                I tried synthetic but the same thing would happen that did to you, tiny oil spots would appear on the driveway but with regular there would be nothing.
                I like the high mileage oil for these motors, or anything above 100k for that matter. The properties in the high mileage oils is made to swell up any deteriorating seals. Nothing major at all but makes just enough difference.
                I usually use valvoline, castrol or shell. Mostly bc you can almost always get a good deal on 5 qts and a filter at pep boys or autozone haha gotta save where you can.
                P.S. Would not recommend royal purple.
                • Northern
                  I like cupcakes & sh!tboxes
                  • 5283
                  #98
                  I run Castrol GTX 10w40 in the winter, 20w50 in the summer, for the same reasons as everyone else.
                  The iX is getting Shell Rotella T6 5w40 this winter, since I would rather run a synthetic with the turbo, and while it probably isn't a real synthetic, it is hopefully close enough
                  Originally posted by priapism
                  Originally posted by shameson
                  • mpowerful
                    • Jul 2013
                    • 1273
                    #99
                    Motul synergie 15w-50 synthetic and napa gold filters. Went 6000 miles on last change including 3000 mile road trip. Did not burn a single drop. Stick still had just over full day i changed it. No leaks on syn either. Cars got 131xxx now.
                    Edit: it may have been 300v the last time. Cant remember which was on the shelf. We stock it at shop but im pretty much only person that uses it.
                    Edit edit: i have used both with same result btw.
                    • studawg
                      • Nov 2013
                      • 39
                      #100
                      I just put Castrol 20w-50 in mine. But Im thinking of going to Mobil 1 full synth. The Mobil 1 site recommends the 0w-40 Euro for my 88 325i, (which it also recommends and is what I put in my '03 540iT), but everyone here says to run the 15w-50. Is Mobil 1 wrong?
                      1988 325i 4dr/5sp Lachssilber Metallic/Black Leather
                      2003 540iT M Sport, Black Sapphire/Black
                        • 34844
                        #101
                        only if you don't love your camshaft.
                        • studawg
                          • Nov 2013
                          • 39
                          #102
                          Im sorry, I dont follow you...
                          • studawg
                            • Nov 2013
                            • 39
                            #103
                            So if we want to use M1, should we use the 0W-40, which is what M1 recommends for the M20, or 15W-50?? And why?
                            • mpowerful
                              • Jul 2013
                              • 1273
                              #104
                              Whats your climate? Generally speaking that oil is to thing unless you live in north dakota or alaska and then only use that during winter. Our cars call for 20w-50. Many synths come in 15w-50 which is acceptable.
                                • 34844
                                #105
                                ZDDP in the 0w40 is too low for an M20. low ZDDP = trashed cam lobes.
                                the next closest thing would be 5w40 turbodiesel truck, which likely has enough ZDDP, but it's not cheap.
                                BMW now recommends the same oil no matter what engine you have, pretty much. also, they suddenly started doing things like 15k oil changes and "lifetime" fluids. coincidently, at about the same time they started paying for all the maintenance on new cars. Think about it.
