200whp with stock N/A rotating assy?
  • dirtie30
    • Jun 2013
    • 28
    #151
    Standalone >
    • ForcedFirebird
      • Feb 2007
      • 8300
      #152
      Originally posted by LJ851
      Interesting. I will be looking forward to seeing the Alpha-n map quality and driveability of a standalone vs what you were able to achieve with the Motronic 3.x ECU.
      Me too. The M3.x runs and drives like stock.
      john@m20guru.com
      Links:
      • e21jps
        • Aug 2011
        • 44
        #153
        Hi John, that is a bit disappointing, thanks for sharing your efforts, there were a couple people waiting on these results to see if it could be done, but looks a little more complicated that one might think!. like you say the later model ecu's might have a much better chance of coping with the change.
        Personally i have never tried to play with any std ecu on any car i have modified, stand alone is always the first thing then the world is your oyster!!!
        still left us hanging now with the engine results!!
        I sell ITB's and performance parts www.racehead.com.au
        e21 race car m20 power! 293Whp atmo 2.9
        details here http://e21jps.webs.com
        drive by video http://www.youtube.com/watch?v=kOdPbErYlho
        incar race http://www.youtube.com/watch?v=sbr0ZCmjsYM
        incar video http://www.youtube.com/watch?v=aQyvDR-B00A
        drag racing http://www.youtube.com/watch?v=7XmznH6PND4
        • LJ851
          • 7919
          #154
          Originally posted by ForcedFirebird
          Changed them, got it to pull a couple times, but could never get over 135whp, and after each run, there was a dead cylinder from a fouled plug ...
          Lorin
          The M30 is God's engine.
          • ForcedFirebird
            • Feb 2007
            • 8300
            #155
            Thanks to Whodwho. Car is running great, needs more tweaking, but the MS is like playing Xbox compared to the Atari of Motronic 1.3, even without the IAT, MAP, or IAC.
            This thing hauls some serious dirt. Can't wait to re-visit the dyno :)
            john@m20guru.com
            Links:
            • LJ851
              • 7919
              #156
              Can't wait for results!
              Why aren't you utilizing IAT? All of the Motorcycles i work on that are Alpha-n use IAT even if it is just a sensor near the throttle bodies.
              Lorin
              • ForcedFirebird
                • Feb 2007
                • 8300
                #157
                Just leave it dangling, or reading one cyl?
                john@m20guru.com
                Links:
                • LJ851
                  • 7919
                  #158
                  Most are mounted in an airbox but race bikes with open stacks can use one mounted near the mouth of the stacks to generally measure the temp of incoming air. I'm not suggesting you should necessarily do this, just curious of your reasoning. Most MC engines are a lot more compact compared to an inline 6 with butterflies 2 feet away from each other.
                  Lorin
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    #159
                    Not going to change the method of madness going on, just curious ;)
                    Who else would try Alpha-N on a an outdated 8-bit software. Not this guy.....OK so I tried hehe.
                    john@m20guru.com
                    Links:
                    • digger
                      • Nov 2005
                      • 6173
                      #160
                      i let mine dangle nearby when running socks drove it for months in summer on 100+F days, not ideal but works temporarily
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        #161
                        Didn't hit 200, but it's healthy. Before and after.
                        john@m20guru.com
                        Links:
                        • digger
                          • Nov 2005
                          • 6173
                          #162
                          good result, was this with the spacers or without?
                          i expect than M50 junkyard swaps into an E30 will cease from this point forward;)
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            #163
                            With spacers. Wanted to try with them and hood closed, then without hood closed, but already over stayed the welcome on the dyno as it was. First few pulls, it was breaking up over 4500rpm, had to adjust the CPS closer to the wheel. Whodoo was kind enough to answer the phone and gave the tip. Figured it may be failing, but guess the MS is more sensitive than the stock ECU.
                            john@m20guru.com
                            Links:
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              #164
                              To add, judging by the graph, I feel a larger cam would have kept pulling and not drop the lower end power by much, or maybe adjust timing instead but we used a stock fixed gear on this build.
                              john@m20guru.com
                              Links:
                              • whodwho
                                • Jun 2008
                                • 1547
                                #165
                                Glad that helped and you ended up with a successful session 8^)
                                Dyno graph looks nice!
                                My M20 Frankenbuild(s)
                                4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
