200whp with stock N/A rotating assy?
  • ForcedFirebird
    • Feb 2007
    • 8300
    #181
    Originally posted by digger
    looks a little soft for an s52 with forged slugs, cams and headwork??
    This graph was posted for people who are buying "off the shelf components". This was a baseline pull with the TRM chip prior to custom dyno tuning. While yes, the peak didn't change much, but under the curve was well complimented, and wtq was amplified :)
    john@m20guru.com
    Links:
    • ForcedFirebird
      • Feb 2007
      • 8300
      #182
      Sounds!!!
      john@m20guru.com
      Links:
      • Bimmerman325i
        • 6854
        #183
        That is amazing!!!!
        You have me debating between doing ITBs on my E36 and buying an E30 and building a wild M20 car, leaning heavily towards the M20.
        2017 Chevrolet SS, 6MT
        95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
        98 M3/4/5 (stock)
        • Reichart12
          • Aug 2012
          • 2165
          #184
          Oh man Im so jealous. I might have to vacation down to Florida to have you work some tune magic on my engine.
          Instagram: Reichart12
            • 34844
            #185
            dang, 211whp is pretty impressive for only 2.8l! Junkyard M50s indeed..
            What trumpets to the RHD kits use? I'm looking for trumpets on my N52 but I haven't really settled on anything.
            • SkiFree
              • Jun 2011
              • 2766
              #186
              Awesome work John. M20 has been underrated for too long.
              ADAMS Autosport
              • ForcedFirebird
                • Feb 2007
                • 8300
                #187
                It's not over yet ;) Injector DC was 100% by ~5k. You can see the AFR's go lean after there, at 7k they were at 126.6%. Not sure I want to try 24lb and all the 33 and 36's we have didn't pass a flow test.
                Thanks! It sounds so amazing, video does it no justice. This is the customer referred to us by IE :)
                john@m20guru.com
                Links:
                • Good & Tight
                  • Apr 2004
                  • 2057
                  #188
                  Impressive #'s Johns..!!!! Sounds incredible in person. I have a set of 850cc injectors if you need.
                  Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                  ____________________________
                  E-mail Panayiotisx2@gmail.com
                  Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                  • whodwho
                    • Jun 2008
                    • 1547
                    #189
                    Very nice! The video doesn't do justice to the sounds of ITBs
                    You still have cam timing and trumpet lengths you can play with?
                    My M20 Frankenbuild(s)
                    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      #190
                      Probably could use an adjustable gear with the block and head being shaved, but it doesn't have one. Probably just going to keep it simple, put larger injectors in and call it a day.
                      john@m20guru.com
                      Links:
                      • whodwho
                        • Jun 2008
                        • 1547
                        #191
                        Doesn't look like it needs much more than that! 8^)
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          #192
                          It does. 100% duty at 5500 and you can see the graph go lean after. :(
                          john@m20guru.com
                          Links:
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            #193
                            Thinking about 36lb to give some room, 850c would be a bit overkill lol.
                            24's might do it, but want to leave some margin.
                            john@m20guru.com
                            Links:
                            • digger
                              • Nov 2005
                              • 6173
                              #194
                              I'd get 30lb it didn't go any leaner than 14 so probably doesnt need the 126% pulse width duty that was used/requested in the tune.
                              The only reason for higher would be to ensure the injection event happens entirely within a window on the intake stroke when doing injection timing in relation to cam duration
                              • ForcedFirebird
                                • Feb 2007
                                • 8300
                                #195
                                It did go over 14 a few instances. Looking through the logs now. Was wondering why we got a stutter a couple times at high RPM. We only did about 7 pulls and a couple of them weren't full. There's a couple places the duty was much higher and the AFR's spike as if the injector just stopped firing.
                                EDIT: Found one log to be at 146.2% DC lol
                                john@m20guru.com
                                Links:
