200whp with stock N/A rotating assy?
  • ForcedFirebird
    • Feb 2007
    • 8300
    Title says it all. How close do you think we can get to 200whp N/A with only exhaust, head work, induction and a good factory bottom end?
    john@m20guru.com
    Links:
  • Van Westervelt
    • 9365
    I think you would need pretty healthy amount of head work, bigger than stock bottom, and eliminate the afm and full exhaust.
    Purely speculation on my part, but from my reading. And those are all in my plans currently.
    • digger
      • Nov 2005
      • 6198
      i think its certainly possible when done correctly. add a proper set of headers, headwork and proper induction system to a 155whp SPEC motor.....
      cubic inch wont make a hell of a difference to peak hp when an engine is built right... torque numbers on the other hand...
      • ForcedFirebird
        • Feb 2007
        • 8300
        Yes TQ will suffer, just curious as to what someone has done with bone stock high mileage used bottom end has received
        john@m20guru.com
        Links:
        • digger
          • Nov 2005
          • 6198
          local m20b25 racers are 195whp on fresh bottom end (euro piston 9.7:1 ) thats with basically stock induction and cam but the rest as per your list i.e headwork, exhaust, etc. a bit of tricky is used during the test though
          • SkiFree
            • Jun 2011
            • 2766
            They aren't somehow sourcing new oem cast 9.7;1 pistons are they?
            ADAMS Autosport
            • digger
              • Nov 2005
              • 6198
              JE make an exact replica of them (+0.5mm) as they are NLA. morerevsm3 would know he was involved in this
              • SkiFree
                • Jun 2011
                • 2766
                Ah, I was hoping for cast mahle's, but yes forged versions would be easy enough to do.
                And forcedfirebird, I've had a couple Swiss guys get into the 180-185 on stock bottom ends and extrude-honed intakes (along with other bits). I'm guessing a proper set of ITB's would bump that up a bit.
                ADAMS Autosport
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  Now that I'm sporting an SSSQUID chip and 19s, I'm hooked.
                  Subscribed !!
                  Alice the Time Capsule
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    ...I've had a couple Swiss guys get into the 180-185 on stock bottom ends....
                    With the higher compression Euro motors?
                    Yes, plan is cam, over-sized valves, porting, ITB's, mid length headers with an x and dual exhaust.
                    Digger, what says PipeMax about the placement of the x pipe? I have Dynomation, and have been meaning to get PipeMax just to help with exhaust.
                    john@m20guru.com
                    Links:
                    • digger
                      • Nov 2005
                      • 6198
                      from memory it is 60", but 30" might net better topend hp.
                      with the head you dont need a bigger exhaust valve it can flow >160cfm+ with a 36mm exhaust valve with the right shape, go +1 or +2 inlet only IMO. dont focus too much on CFM there is already enough CFM for 200WHP
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        Here is the subject:
                        john@m20guru.com
                        Links:
                        • squidmaster
                          • Aug 2011
                          • 2666
                          (duncan bonar)
                          But thats with high comp built. Not sure how you could get the same out of stock pistons
                          • digger
                            • Nov 2005
                            • 6198
                            Originally posted by squidmaster
                            (duncan bonar)
                            build specs?
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              (duncan bonar)
                              Not going to stop the effort ;)
                              Rama saw 178whp with ITB's on a stock high mileage engine. Oh yeah, since this is a stock Spec e30, gonna throw your tune on it for back to back comparisons. :-)>
                              No lying, non biased, facts are facts kinda gig. Same day, same dyno, same car. Let's just see what squid has to offer! I'm going to say minimum 5whp from chip alone....
                              john@m20guru.com
                              Links:
