Interesting Rocker Discovery
  • ForcedFirebird
    • Feb 2007
    • 8300
    OK, well you are splitting hairs at $120 to NOT ruin a new cam :p
    ...and good choice on the rockers. We have been beating the crap out of them on the track ad they are holding so far. If one fails, Andrew and I will get reacquainted over the phone lol.
    john@m20guru.com
    Links:
    • digger
      • Nov 2005
      • 6031
      make sure you check the sweep pattern with HD as the older ones have issues when you talk very big cam lobes the lobe runs off the rocker pad (OEM no issue) due to the pad seemingly being designed/positioned for reground cams negating the use of o/s eccentrics.
      i think this has been rectified though
      another option is MM peened and inspected rockers. more $$$ though
      • TobyB
        • 5218
        10 years ago, oem and febi had identical void problems.
        I broke both, in identical ways.
        Resurfacing rockers works, too, if they are in decent shape.
        t
        • jeffnhiscars
          • Jun 2011
          • 6010
          This is another one of those discussions where every comment needs to include the disclaimer that "your experience may vary". Pros and cons to every option unless you spend big bucks which I've already said I'm not going to do, just for practical reasons.
          It's safe to say my OE rockers are not going to break since a)!they just don't seem to break and b) we are talking DD with auto trans (I can't repeat that often enough).
          The consensus is the only downside is possible premature wearing of the new cam which I'm prepared to live for a few reasons. One is if my old cam was not past its "best by" date I'd have reused it and I can't believe the new cam won't outlast a used cam regardless of the rockers. Second, I wonder how many people who follow the new cam new rocker policy also replace all their guides, valves and springs (which I did). Third, a worn cam is a worn cam...big deal...you fix it for about what a set of rockers cost. A broken rocker has a very different outcome.
          Last thought (for the moment) is whats the extent of the damage when a timing belt breaks and the rocker doesn't ?
          Alice the Time Capsule
          • TobyB
            • 5218
            But: if the cam wore out, then the rockers are worn in a mating pattern to the lobes.
            Getting a cam to bed to the rockers has become one of the harder things with old
            sliding- tappet engines now that the oil's "green" and lacks the sliding friction additives
            it had when these engines were new.
            Refacing seems like a good compromise- they'll bed, you'll spend $50, and life's good.
            Spend for the high- ZDDP break- in oil, too- it's cheap insurance.
            Honestly, too, take 10 minutes and check the springs. If they're good, you won't break a rocker.
            What I'd do (what I DO do) for a dd,
            t
            • digger
              • Nov 2005
              • 6031
              new or refurbed pads is a must with a new cam IMO its not worth the risk of damaging the cam, many people do it i'm sure but many people don't change timing belts either.
              Also running the cam in is a good idea, i dont think yo need anything special on this spec of engine its basically stock just whatever oil you current use at it should have enough zinc and so forth anyway but make sure you coat the rocker pad and cam faces with moly lube before start up and run it at 2000rpm or so to take some load off the nose of the cam and pads and get some more oil flow happening to the topend.
              • jeffnhiscars
                • Jun 2011
                • 6010
                I was not aware that pads could be refurbed so will check around for a shop that does it after i check the rockers for side play on th shafts. Good info
                I do use assembly lube and run Mobile 1 15-50'which has lots of zddp. I can always add some more for initial wear in if it matters.
                Are you suggesting to run it at 2000 just til the oil circulates or for xx minutes to bed the cam ?
                • jeffnhiscars
                  • Jun 2011
                  • 6010
                  Hah...EZPZ
                  And this is cool. Anyone know where to get one ?
                  A ROCKER ARM GRINDING ATTACHMENT FOR USE WITH A BENCH GRINDER OR LIKE GRINDER CONSISTING OF A BRACKET WHICH IS ADAPTED FOR ADJUSTABLE ATTACHMENT TO THE GUARD OF A GRINDING WHEEL. THE UPPER ARM OF THE BRACKET IS PROVIDED WITH AN ELONGATED SLOT TO SLIDABLY RECEIVE AN ARBOR AND WHICH MAY BE SET AT A DESIRED POSITION ALONG THE SLOT. THE ROCKER ARM IS PLACED ON THE ABOR AND ROTATED MANUALLY TO BRING ITS LIP TO BEAR AGAINST THE SIDE OF THE GRINDING WHEEL.
                  • Kershaw
                    • 11822
                    That doesn't look that hard to make. Put your bench grinder near your vise, 2 long bolts, a couple of washers, and a scrap piece of wood or metal with 2 holes drilled in it, and maybe you got it.
                    I'd definitely practice on a throwaway one first....
                    AWD > RWD
                    • jeffnhiscars
                      • Jun 2011
                      • 6010
                      You really..REALLY need th face to be square to the bore of the rocker so as simple as this is, it has to be precise or the pad will not sit flush on the cam lobe.
                      I'll see if my machinist has the jig or else will find someone who does. For the $50 or so this will cost, I'm in
                      • digger
                        • Nov 2005
                        • 6031
                        call a cam grinder, they should have equipment
                        • TobyB
                          • 5218
                          That's who has done mine- Delta Cam, in Tacoma.
                          And yeah, spend the $13 for the additive-
                          I've been bitten twice now, and it's just
                          not worth not doing it. Or use a break-in oil- it's actually
                          cheaper than the M1.
                          t
                          • jeffnhiscars
                            • Jun 2011
                            • 6010
                            We all agree on what the best practice is here and I think it's safe to say very rarely do we all follow those practices completely either cause we discount it, can't afford it or just don't feel like spending the time or money to make it "as new". The real question is what's the cost benefit equation as it relates to real world risk.
                            1) For those who have had premature wear on a new cam without replacing the rockers what was the driving style (i.e. Track, auto X, DD) and was the engine stock or "performance enhanced" ?
                            2) if you are supposed to replace your rockers when you replace the cam, why have I never seen anyone say you have to replace the cam when your broken timing belt takes out half your rockers and you replace those ? I mean don't new rockers with an old cam create the same wear inducing mismatch as a new cam with old rockers ? Surely someone has had half their cam lobes vaporize as a result of replacing half their rockers and leaving the old cam. No ??? Hmmmm
                            just food for thought...and comment.
                            Note...I pay $23 for a jug of M1. Dyno was $15 last I checked. Not significant
                              • 34839
                              the cam isn't supposed to be a wear surface, that's why.
                              • jeffnhiscars
                                • Jun 2011
                                • 6010
                                Not sure what you mean. Rockers are hardened all the way through whereas cams are surfaced hardened, yet they both wear out.
