Last thread - Schrick 288
  • apostate
    • Feb 2012
    • 148
    It is not my intention to bother anyone on this forum further than this thread as it happens to be my last one here.
    But since I won't be here for the next five years at least, there is a question for you all:
    Why would a Schrick cam need an adjustable cam gear?
    And the answer is? Fine Tuning?
    NO!
    Schrick have given all the parameters of the camshaft needed. And REMEMBER, the camshaft has only ONE CORRECT position. Period. Everything else is rubbish.
    So what is the adjustable gear for?
    Do not expect answers from me as I'll be gone for some time and use your brain.
    Cheers.
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5562
    Is this even real?
    • rturbo 930
      • Dec 2005
      • 2621
      Whisky Tango Foxtrot?
      • uturn
        • Dec 2010
        • 1004
        Originally posted by apostate
        Oversized valves
        Hi guys,
        Can somebody explain the benefit of having oversized valves in a M20 head?
        Thanks. Cheers.
        Just a troll too lazy to read or search... Or is it a fancy A.I. program. Hmmmm
        • rturbo 930
          • Dec 2005
          • 2621
          Did you read through the thread? He asks why bigger valves might be beneficial, several people tell him, and then he says they're wrong, larger valves are bad, apparently having known the answer the entire time.
          He's an idiot.
          • MrBurgundy
            R3V Degenerate
            • Mar 2012
            • 5562
            He was doubting one of the most knowledgeable people on this forum.
            This guy is just being an emo twat
            • digger
              • Nov 2005
              • 6147
              NO!
              Cheers.
              for people who stick around, here are some reasons:
              - if you change the distance between the crank centerline and cam centerline the cam timing changes because the timing belt is a fixed length so the cam can end up retarded or advanced and you have no way of putting it where it should. there are only two thickness OE headgaskets to potentially correct this with out use of a adjustable gear.
              - sometimes the hole in the end of the cam is not in the right spot (seen smashed valves from this on a alpina c2 2.7L and even schrick screw up sometimes)
              - the chances of some random off the shelf grind running best on your particular engine which could have a host of mods that schrick has NFI about when installed straight up vs a couple degrees advanced vs a couple degrees retarded is like flipping a coin. if you get a custom cam you might expect schrick to grind the cam so using the factory install marks it runs best but it isnt a custom ground cam for your engine.
              - what runs best is not always a clear distinction, if you want a bit more lowend and midrange advancing can sometimes help, sometimes not and vice versa with retarding. the closer the duration is to the ideal duration for the engine seems to require less adjustment. People that choose a bit much duration often find the engine runs best advanced 2 or 4 degrees (this is a bit of a generalization of course)
              - you screwed up cam choice and you need to get more P to V
              • redlightpete
                • Mar 2012
                • 265
                - Dr. Schrick is mean spirited and locates the alignment hole so that it doesn't time the cam correctly with the stock cam sprocket and stock deck height.
                • digger
                  • Nov 2005
                  • 6147
                  yep, the one i measured was advanced 4 degrees off the bat
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    I don't know how to ask as confrontational a question as the OP so I'll just simply ask...would the I.E. 272 I'm putting on my 731 need an adjustable cam gear ?
                    Alice the Time Capsule
                    • TobyB
                      • 5266
                      Do you want donuts?
                      No!
                      No, you do not want donuts, and I'm going to tell you why...
                      Just trina say...
                      t
                      • digger
                        • Nov 2005
                        • 6147
                        it should run fine without one as i bet many many people have done this but you can get it in exactly the right spot if you get one....
                        install it and see how it aligns. any major issues should be visible by looking at valve lift at TDC. one cam i bought years ago was supposed to be open 2.5mm at TDC but instead it was like 1/4" so no need for any fancy measurements to see it was a tad off
                        regardless check P to V clearance
                        • zaq123
                          • Jul 2016
                          • 1527
                          :nice: priceless..
                          I applaude digger's patience to deal with us all..
                          • jeffnhiscars
                            • Jun 2011
                            • 6011
                            Your assuming I have as much patience in evaluating p>v clearance and valve lift as...well...you do dealing with...umm...some people online :)
                            • LateFan
                              • May 2013
                              • 4404
                              It's impressive - he doesn't seem to get riled up by (us) idiots.
