Convince me not to buy ITBs
  • mr.
    • Jun 2013
    • 513
    How pointless would ITBs be in an otherwise stock motor?
    Head, block and cam all factory M20B25 stuff
  • SkiFree
    • Jun 2011
    • 2766
    You will find a lot of information here.
    ADAMS Autosport
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5611
      stock intake sux
      • Metallated
        • Dec 2016
        • 1074
        Make them don't buy them...
        • sampayne
          • Apr 2014
          • 396
          Originally posted by 2mAn
          The BMW V6 is the best
          • mr2peak
            • 2388
            Downside: It will be ~$3k, closer to 4K, for a nicely driving and well tuned ITB setup, giving about 30whp over stock.
            I guess I won't give you upsides... but I chose to build a 2.9 with ITBs and no regrets..
            Drive it hard. Maintain it well.
            A Topless Memorandum
            • digger
              • Nov 2005
              • 6206
              really its only the cost aspect and you want to be handy enough to be able to pull it apart and reinstall it yourself and set it up properly.
              the airbox that comes with it is a very tight fit depending on engine mounts etc some report rubbing and contact, you would not want one without an airbox or airfilter
              • jeffnhiscars
                • Jun 2011
                • 6011
                Can you get by with a chipped ecu or is an aftermarket mandatory ?
                Alice the Time Capsule
                • zaq123
                  • Jul 2016
                  • 1569
                  you will have to run Alpha N. I know Miller can do Factory ECU controlled Alpha N system on S14. They were talking about looking into M20s a few years back...don't know if it's available.
                  • Reichart12
                    • Aug 2012
                    • 2165
                    Do it. Obviously you want to or this thread wouldn't exist.
                    Instagram: Reichart12
                    • Mook613
                      • Apr 2016
                      • 232
                      I also want to do it, but I'm more interested in the beautiful noise they make more so than the nice power boost.
                      • digger
                        • Nov 2005
                        • 6206
                        You can run maf with the warchip custom + tune. Standalone is the way to go though.
                        • varg
                          Florida Turbo Man
                          • May 2014
                          • 3436
                          On a stock engine? Lots of money and not much power. If you're after performance don't bother unless your wallet is sumo fat so you can build an engine worth putting them on, if you're after intake sound, response and aesthetics, do bother.
                          IG @turbovarg
                          '91 318is, M20 turbo
                          • zaq123
                            • Jul 2016
                            • 1569
                            ITB is a goal for my 2.9 stroker as well. My plan was: 1.build the engine (done), drop it in with motronics and work out all issues (in progress) 2. get MS, tune it with the stock intake (to familiarize myself with MS), get ITB as an icing on the cake.
                            Looking at ITB's current prices, I probably should have gotten it sooner....looks like prices came up (exchange rate??)
                            • TobyB
                              • 5297
                              Originally posted by mr2peak
                              Downside: giving about 7whp over stock but 13 ft/lbs less torque
                              heh
                              t
