ForcedFirebird's m20 dyno thread.
This is a sticky topic.
  • McGyver
    • 4636
    #151
    I'm almost to the point of assembling my 2.7i engine. I'm sure I could slap it together and it'd work just fine, but I would prefer to do it right the first time.
    Would a generic step-by-step engine building guide be sufficient? Are there any m20-specific things that I need to look for?
    • digger
      • Nov 2005
      • 6215
      #152
      most is pretty generic, the only thing thing kinda specific is the intermediate shaft bearings
      • zaq123
        • Jul 2016
        • 1574
        #153
        don't use Lucas assembly lube or any green/blue coloured assembly lube. I almost had a heart attach when I was adjusting valves after the first start, opened the valve cover and saw some green residue mixed with gold coloured break-in oil sitting in the head.
        • McGyver
          • 4636
          #154
          I plan on using Redline Assembly lube for the whole build. Any suggestions for the break in oil?
          Also, I have new mahle 84.5 pistons (11251714810). This should be roughly 9.0:1CR and then will get boosted. Should i use the rings that came with the pistons? Looks like a shiny barrel top ring, grey Napier 2nd ring, and oil control ring.
          I plan to measure/gap the rings for boost.
          • zaq123
            • Jul 2016
            • 1574
            #155
            driven br40 for the oil. follow instructions.
            Mahle are good rings. Follow Mahle instructions for break-in. Keep in mind that cam break-in supersedes rings break-in but it's all plus minus the same.
            Easy on the oil when assembling rings and on cylinder walls.
            ​ I recommend using Marvel mystery oil for that, coat piston bores with it and coat rings/pistons with that. Good assembly Lube on all bearings, cam, crank. If you gonna crank the engine after the assembly, plugs out so no to squeeze the lube with compression from crank bearings. Drill with long extension and 6mm socket to prime the engine before first start. Setup ECU (I assume wont be stock) to prime fuel pump so it starts asap. Didn't start withing first 3-4 sec of cranking? STOP and Start troubleshooting. Don't just sit there and keep on cranking the started while polishing your bores and messing up new rings.
            some general info from JE just to give you an idea
            https://www.jepistons.com/ring-insta...X2NF1LyhZ44atp
            • McGyver
              • 4636
              #156
              I've reached the stage where I'm ready to start measuring and assembling the engine. I don't have a bore gauge or OD mics in the 0-6" range. I know that I should double check my machinist's work, so I bought plastigauge for the main and rod bearing clearances. I'm not building a 10/10ths engine, just looking for some decent longevity on a 2.7i that will get a turbo in the future.
              Is plastigauge good enough?
              I don't really want to buy a bore gauge right now, especially because it would only make sense to get one that reads in 0.0001" and I'd need a 0.5-1.4" for the small end of the rods, 2-6" for everything else, and a set of 0-6" mics. I plan on building at least another engine in the future, so I would get more use out of the tools. But it would also be nice to have time to find a quality used set on eBay instead of getting a cheap set of Chinese tools.
              • zaq123
                • Jul 2016
                • 1574
                #157
                plastigauge is fine. It has a pretty good range to get you in the ball park. I would not worry about the bore gauge ( gotta trust your machinist somehow), just make sure you measure piston ring gap once in the in the bore and adjust it accordingly. Piston to valve clearance is a must so get a second head gasket on hand...just in case. Also make sure to measure crank trust clearance ...very important
                • digger
                  • Nov 2005
                  • 6215
                  #158
                  Plastigauge should not be frowned upon. Most backyard mechanics are doing this with measuring equipment not upto the job because proper equipment is expensive and cannot be justified for a once or twice off endeavor so plastigauge is probably more accurate in some circumstances than using junk equipment without experience
                  • McGyver
                    • 4636
                    #159
                    I appreciate both of your perspectives on this! The cylinders have all been bored for 0.50mm over pistons, main and rods have all been cut and bored to match the crank. Plastigauge will confirm there weren't machining mistakes. It would be cool to get the actual measurements, but I don't think that justifies buying tools with enough precision to provide a real measurement.
                    I plan to file the ring end gaps per cylinder for a Turbo application. I'll also measure/swap piston/rods to get even piston height at TDC for all six cylinders. And I'll balance the piston assemblies as best I can. I'll also check valve clearance to the new guides with the new cam and check piston to valve clearance with the new-but-crushed head gasket. Should be good!
                    • zaq123
                      • Jul 2016
                      • 1574
                      #160
                      I meant thrust crank clearance.. I'm sure you got it but just in case.... Thrust bearing is the reason you should not use an impact wrench on that crank bolt btw. Hand tools only
                      • AliBOSS
                        • Oct 2019
                        • 42
                        #161
Name:	Screenshot_20251212_174115_Adobe Acrobat(1).jpg
ID:	10152911 Good Morning everyone,
                        I would to share with you our Frankenstein M20 that we finally dynoed 1 week ago
                        It's diesel block, 885 hand ported head,Dbilas open M5 3.6 itbs with their trumpets, 3.0 crank knife edge and balanced and 84mm pistons on 140mm rods, electric water pump and fan, mechanical pump deleted. Standalone ecu tuned by me.
                        • 2mAn
                          Señior Mod
                          • 21093
                          #162
                          Those are some impressive numbers!! What’s the compression ratio on your setup
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          Make R3V Great Again -2020
                          • AliBOSS
                            • Oct 2019
                            • 42
                            #163
                            I'm not sure, we are using stock parts from other engines, nothing is forged. The static compression is around 180 but our giant retarded camshaft is lowering the numbers
                            • 88Sedan
                              • Apr 2023
                              • 282
                              #164
                              Those are some of the highest m20 numbers I have seen. I want to know every detail of this motor! I've never heard of an m20 diesel block before or anyone using 140mm rods in an m20.
                              • 2mAn
                                Señior Mod
                                • 21093
                                #165
                                Trying to break this down a little more with my failed ME math
                                84mm Bore X 85.8mm stroke = 2853cc or a solid 2.9L
                                Compression Ratio is still a mystery because US S50 had 135mm rods, EU S50 had 142mm…
                                What fuel does the motor like?
                                Simon
                                Current Cars:
                                -1966 Blue Boat
                                -1969 Red VW
                                -1986 White BMW
                                -2006 Green Thing
