M20B27 with 173 ecu
  • Georgiyk
    • Dec 2019
    • 18
    M20B27 with 173 ecu
    So everyone said it’s not possible to run a m20B27 eta with a 1.3 173 ecu but I put a eta in my 1989 325i running the original wiring harness with a 173 ecu just proved everyone’s theories wrong car runs great
  • 2mAn
    Señior Mod
    • 21093
    Originally posted by Georgiyk
    So everyone said its not possible to run a m20B27 eta with a 1.3 173 ecu but I put a eta in my 1989 325i running the original wiring harness with a 173 ecu just proved everyones theories wrong car runs great
    Thats great news, congrats. Have you done any 1/4 runs? Im willing to bet it does the 1/4 mile run faster than the 325i did. Gotta redline it to get the most out of it though, thats the key R3V it and R3V it HARD. Have to run it at least 2, maybe 3x to make sure you're getting the launch down. The torque of the 2.7 will roast the tires until you get the launch just right. If you're under 2.0sec 60ft thats a solid launch.
    Please report back.
    Also, pics?
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • e30davie
      • Apr 2016
      • 1788
      Weird first post. Who is everyone? and define running great? checked the AFR? is the ignition optimised for the engine?
      • E30SPDFRK
        • 5716
        Countdown to bent valves starting now
        Byron
        Leichtbau
        • Georgiyk
          • Dec 2019
          • 18
          The car has zero check engine likes i re did the timing while I put the new timing belt and tensioner in its a eta motor and injectors with b25 intake manifold and sensors that I swapped since the plugs didn’t go together the car rips. Yes I know all of you guys are gonna say etas are slow but I did this as a project because everyone on forums said it’s nearly impossible and I wanted to try it out and see from my self I put 200 miles on the car so far and nothing has happened
          • 2mAn
            Señior Mod
            • 21093
            shhhhhh
            The car has zero check engine likes i re did the timing while I put the new timing belt and tensioner in its a eta motor and injectors with b25 intake manifold and sensors that I swapped since the plugs didn't go together the car rips. Yes I know all of you guys are gonna say etas are slow but I did this as a project because everyone on forums said it's nearly impossible and I wanted to try it out and see from my self I put 200 miles on the car so far and nothing has happened
            You need to take it out to the drag strip. holds the R3Vs at ~4500rpms, then drop it and redline again. should make it through the traps at the top of 3rd. Still have the 3.73?
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            • Georgiyk
              • Dec 2019
              • 18
              Lol do you think I’m a moron.
              • packratbimmer
                • Dec 2009
                • 1335
                Now get a chip from SSSquid and you are all set
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  It won't "rip" for long. Even when putting a chip in an eta with only a 5500 rev limiter, the valves lightly kiss the pistons with sustained high revs. The 200 head only came with the outer valve springs, not the inner.
                  I have done the same as you in the past, but also used dual 325i valve springs - but - the 200 head falls on it's face at about 5000rpm, so after that it's just making noise.
                  john@m20guru.com
                  Links:
                  • roguetoaster
                    Biggus Tippus
                    • 7830
                    Yes, but we hope that you'll learn the error of your ways soon and be better for it.
                    • 2mAn
                      Señior Mod
                      • 21093
                      Only if you cant beat the stock 15.5 time... make it happen!
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      • Georgiyk
                        • Dec 2019
                        • 18
                        I know the motor will fall on it Face If I get on it and my car was already chipped when I bought it but I did this as a project just to see if the car would even start and I’m probably gonna wanna see how fast the motor will give up. My next build is the 1988 super eta with the 885 head I have the head in my garage just kinda hard to find the block
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          I know the motor will fall on it Face If I get on it and my car was already chipped when I bought it but I did this as a project just to see if the car would even start and I’m probably gonna wanna see how fast the motor will give up. My next build is the 1988 super eta with the 885 head I hand the head in my garage just kinda hard to find the block
                          I just realized you have two threads, and in tho other one you said you swapped the head. That's not quite the same as using m1.3 on a 2.7. The 2.7i you made has been done so many times. I even have dyno results in my m20 dyno thread.
                          john@m20guru.com
                          Links:
                          • Georgiyk
                            • Dec 2019
                            • 18
                            the motor I put in is all stock with a 200 head. I was saying my next build I want to do the super eta with a 885 head I have a head laying around my garage
                            • agent
                              Vice Grand Pubaa
                              • 7960
                              At least one of them was posted in the correct subforum. Now they both are.
                              Originally posted by kronus
