M20B27 with 173 ecu
  • Georgiyk
    • Dec 2019
    • 18
    #31
    • digger
      • Nov 2005
      • 6147
      #32
      Originally posted by Georgiyk
      So is there another head that’s identical to the 200 head that can be swapped out or how does it work do you just replace springs or what.
      you can replace springs or put a head with the springs already installed.
      the 200 eta is not much chop for anything, for a performance engine people do a 731 head from a m20b23 or m20b20 which has the same combustion chamber so it matches up with the pistons proerly but slighty larger ports. or they just use the 885 head from m20b25 which while not ideal still is an improvment
      • 2mAn
        Señior Mod
        • 20825
        #33
        Bro shut up no one cares about your 1/4 mile runs
        RUDE.
        Thats the best way to know if you've made your car better or worse... Id also suggest doing a dyno run, but a 1/4 mile run is more fun.
        Simon
        Current Cars:
        -1966 Lotus Elan
        -1986 German Car
        -2006 Volkswagen Jetta TDI
        Make R3V Great Again -2020
        • Georgiyk
          • Dec 2019
          • 18
          #34
          I have the 885 head and it doesn’t fit because the eta and b25 have different pistons
          • digger
            • Nov 2005
            • 6147
            #35
            it fits fine, the pistons arent matched to the chamber correctly but it installs fine but its just not ideal compared to a proper 2.7
            • TobyB
              • 5266
              #36
              Soooo... what sort of noises does it make abut 5500 rpm?
              t
              this is fun.
              • 2mAn
                Señior Mod
                • 20825
                #37
                t
                this is fun.
                BRO
                Redline is 6500+ and it needs to hit AT LEAST 6000 to really take advantage of this setup
                Simon
                Current Cars:
                -1966 Lotus Elan
                -1986 German Car
                • Georgiyk
                  • Dec 2019
                  • 18
                  #38
                  t
                  this is fun.
                  Doesn’t make any noises
                  • roguetoaster
                    Biggus Tippus
                    • 7830
                    #39
                    What noise did it make before it stopped making noises?
                    • Georgiyk
                      • Dec 2019
                      • 18
                      #40
                      Never made any noises
                      • TobyB
                        • 5266
                        #41
                        >disappoint<
                        t
