i gather you are using the b25 60-2 toothed vibration damper on the front?
M20B27 with 173 ecu
so it is the SETA or B25 vibration damper on the front? the one with lots of teeth on it?89 E30 325is Lachs Silber - currently M20B31, M20B33 in the works, stroked to the hilt...
so its not a true ETA then, the eta has a different vibration damper and trigger setup so that why people probably said it cant be done. the harness must match the trigger setup. so actually you havent done anything that couldnt be done
people have been running M20B31 engines for years on 173 ecu89 E30 325is Lachs Silber - currently M20B31, M20B33 in the works, stroked to the hilt...
Well most of the sensors that were on the motor would connect into the wiring harness so they had to be swapped like the oil level reader, oil pressure sensor and crank shaft poison sensor etc all those sensors are completely different from each other that’s why I had to replace the vibration damper they are different in size
people have been running M20B31 engines for years on 173 ecuComment
My ecu is tuned and it goes to 6500 rpm maybe a little more what do you think would happen if the 2.7 went to 6500rpm
yeah there are bunch of things that need to be added / swapped to get it to work not directly plug and play
high risk of loss of valve control resulting in loft and then valve bounce occurring which has been shown to cause the piston to tag the valves and bend valves because the relationship between valve lift and piston position goes out the window. People usually run the dual springs or at very least the single outer springs (beefier ones from M20B23) even better is the beefy outer springs and the inners which is even more rpm capable than the b25 setup89 E30 325is Lachs Silber - currently M20B31, M20B33 in the works, stroked to the hilt...
Simon
Current Cars:
-1966 Blue Boat
-1969 Red VW
-1986 White BMW
-2006 Green Thing
Make R3V Great Again -2020Comment
So is there another head that’s identical to the 200 head that can be swapped out or how does it work do you just replace springs or what.
high risk of loss of valve control resulting in loft and then valve bounce occurring which has been shown to cause the piston to tag the valves and bend valves because the relationship between valve lift and piston position goes out the window. People usually run the dual springs or at very least the single outer springs (beefier ones from M20B23) even better is the beefy outer springs and the inners which is even more rpm capable than the b25 setupComment
