1987 325e sedan M30B35 swap
  • st.petebiodiesel
    • Jul 2015
    • 211
    #166
    Just for fun I decided to take the car to my local 1/8th mile drag strip. It did not go well.
    I pulled out of the water box, was in the middle of doing a burnout, and the engine died mid burnout. Never even got to stage.
    I got a push back to the pits and attempted to diagnose the problem with minimal tools. Eventually I gave up and proceeded to spectate and kick back a couple of beers.
    I ended up towing my car home hours later.
    Now in the comfort of my garage I could diagnose why the engine died.
    I found my wideband had came un plugged. Apparently I didn't leave enough slack in the harness and when I did my burnout it must of pulled the connectors apart. My MS tune has a 15% EGO correction. It should still run without a wideband.
    Next I checked the timing. I rotated the crank hub to TDC with alternator hub nut. I noticed while I was turning the engine over that the crank wheel was turning but not the crankshaft. EUREKA!
    Apparently I snapped my woodruff key for my crank hub and the ignition system lost timing with the engine.
    After further investigation it was discovered I didn't even have the crankshaft nut. It had loosened at some point and just fell off.
    Fortunately no damage had occurred on the hub or the crank.
    I got a new key and a used nut from my spare stock.
    The torque on the crank nut is something like 300ftlbs. I didn't have a tool to apply that much torque. So I tightened it till the emergency brake could no longer hold the car and tack welded the nut to the crankshaft. That should prevent this from happening ever again.
    I'm going back to the drag strip tomorrow. I'll make another post with hopefully better results.
    Sent from my SM-G960U using Tapatalk
    • st.petebiodiesel
      • Jul 2015
      • 211
      #167
      Made it to the track the other night and had a great time. I probably made 20 passes, many performed back to back.
      Sadly my car is still pretty slow, 9.50 in the 1/8th isn't exactly fast. It converts to a 14.8 in the 1/4.
      Here is my best time.
      Here is a video my friend took, almost beat a poorly driven mustang.
      I'm going to re do my exhaust this week. I installed a Moroso spiral flow muffler when I first built the exhaust and I've read they don't flow great.
      I'm gonna try just replacing it with a straight pipe and just rely on the rear muffler. However if it is too loud I'll install a resonator that looks like it will flow a little better.
      • Anthony B
        • Nov 2012
        • 308
        #168
        How did you go on launch? I struggle to get my car to bite traction even with a 3.15 I still manage too cook 225/50/16 semi slicks
        3” single with a hotdog resonator & resonable sized rear my e30 is LOUD & drones at freeway speed, whilst the rebuilding is taking place I’m redoing the exhaust with with a single 2.5”, centre resonator, & custom headers
        • lukeADE335i
          • Apr 2013
          • 1386
          #169
          Hate to say it, but my 2.5 inch also drones with a decent sized hot dog resonator and rear muffler. I'm going to try an e46 328i rear muffler I have in the shed at some point.
          I think to avoid drone a twin 2 inch system is probably the best option (but obviously much more expensive).
          My e30: OEM+ with M30B35
          • LowR3V'in
            • 4209
            #170
            just get the biggest longest muffler you can fit back there.
            • st.petebiodiesel
              • Jul 2015
              • 211
              #171
              I ended up cutting out my moroso muffler.
              It looked pretty restrictive.
              I just replaced it with a 2.5" straight pipe.
              It made the car only slightly louder. It sounded a lot healthier too. I'm only running an auto parts store magna flow muffler in the back.
              Now to take it back to the track, which ended very fast.
              I was in the middle of doing my first burnout and all the sudden something came loose and shook the ever living shit out of the car. I shut the car off immediately and pushed it back to the pits. I'm not sure what had happened at the time, the car still ran but if I gave it any revs the car shook violently. Maybe something in the clutch cam loose?
              I ended up towing the car home later that night.
              I removed the transmission the following night to find this.
              Clearly I had broken some pressure plate straps.
              Never seen straps tear like this before. I've seen them bend, but not tear out completely. This was a stock e28 535i clutch and pressure plate.
              I'm going to replace it with a e24 m6 clutch.
              • Streichholzschächtelchen
                • Jan 2009
                • 1670
                #172
                Excellent build, lots of "why didn't I think of that" stuff going on. Can't wait for another video!
                Jah bless! :pimp:
                • st.petebiodiesel
                  • Jul 2015
                  • 211
                  #173
                  Replaced my clutch with e24 M6 clutch. It wasn't cheap.
                  Flywheel still looks in excellent shape.
                  I've been watching a lot of drag racing YouTube videos and got pretty interested in nitrous setups. Kinda playing around with the idea of making my sedan a drag car. I know the e30 is supposed to be a twisty road/track car, but I live in Florida where we only have on/off ramps and straight roads.
                  So I pieced together a nitrous system.
                  My microsquirt has a dedicated nitrous controller built in. I run the nitrous all dry and the microsquirt adds additional fuel and retards timing to whatever values I input. Obviously the injectors will be the limiting factor to how much nitrous I can run.
                  Dry nozzle before the throttle body.
                  With this nozzle and solenoid I can only run a 175hp jet, which should be plenty.
                  Here are some pics of the routing of the nitrous.
                  1 step colder plugs after a few 75whp jet runs.
                  Here are my microsquirt settings for the nitrous.
                  I'm currently running a 125hp shot right now. IT'S INSANE!!! 125hp is about all I can run on the stock injectors. Definitely feels like a 300whp e30 sleeper.
                  The 195 tires on the bottle caps are pretty much useless now.
                  • LowR3V'in
                    • 4209
                    #174
                    Why not an aftermarket clutch?
                    aftermarket pp has multiple straps and modded to be stronger than an m5 one.
                    the stock m30 ones are pretty decent though i pushed one to 10psi before it started to let go
                    maybe alittle over 300tq.
                    • AWDBOB
                      hooptie connoisseur
                      • Aug 2013
                      • 4466
                      #175
                      Casual Nos drop in. I love how much you enjoy this car! I envy, very much.
                      • st.petebiodiesel
                        • Jul 2015
                        • 211
                        #176
                        Kinda committed to the drag car build. I've been watching a lot of Hot Rod Drag Week coverage on YouTube. Got a set of Hoosier DR2 drag radials. Which are actually closer to a straight up slick. 225/50-16. Look at all that meat. Also changed my diff bushing to help with those hard launches. I made a couple passes at the test and tune at the local 1/8th mile. I struggled with the launches. I would leave and the car would bog. 8.5 was the best I could do in 3 passes. Then I put in a fresh nitrous bottle and went for 1 more pass. I decided to leave the nitrous on for the entire pass. Normally I would turn it on after I shifted to second or halfway through 1st. That and I gave it a lot more RPMs to prevent the big. The results were impressive. That pass works out to a 12.6 second 1/4 mile. Time for more nitrous! I'm gonna spray this turd to 11 seconds. Sent from my SM-G960U using Tapatalk
                        • wworm
                          • Dec 2016
                          • 1719
                          #177
                          awesome update. Glad to see something different. Get this puppy boosted!
                          1984 Delphin 318i 2 door
                          • LowR3V'in
                            • 4209
                            #178
                            bad ass. i think what come next is turbo.
                            filling tanks every week becomes $$$$$$$.
                            • varg
                              Florida Turbo Man
                              • May 2014
                              • 3396
                              #179
                              Quick! Might want to put a second diff mount on that thing before those launches and shifts start to rip the stock mount out of the floorpan.
                              IG @turbovarg
                              '91 318is, M20 turbo
                              • st.petebiodiesel
                                • Jul 2015
                                • 211
                                #180
                                Went to the local 1/4 mile this weekend. My goal was to run a low 12 second pass. First run I couldn't grab any gear easily but still managed a 13.8 @ 101mph. Immediately after this run the car was obviously hurt. It still ran and drove, but it was making a hell of a racket. Turns out I broke my crankshaft. How could this happen with only 400 whp? I expected to melt a piston or bend a rod with nitrous. Breaking a crank just seems unreal. I'm going to rebuild the engine, just might take awhile. Crazy thing is that the car still ran and drove with the broken crank. Sent from my SM-G960U using Tapatalk
