Subframe bushing removal
  • digger
    • Nov 2005
    • 6173
    #46
    I used a threaded rod to get it part way in then a 2 jaw to push it home. With threaded rod I used a bearing puller spacer/puck between the body and sub frame beam so the threaded rod went through hole of the bearing spacer so it was nice and solid so the force was transferred into the bush
    • twright
      • 707
      #47
      Originally posted by mlytle
      dozens of threads on ways to do this...... it just ain't that hard, or toxic.
      it is also easier to drop the entire subframe as one unit than take it apart.
      I don't know how you got this to work. When I tried it, all I did was bend the lip on the subframe bushing and then my 2 jaw puller slipped off the old bushing.
      • jjc034
        • May 2018
        • 107
        #48
        Lots of heat and threaded rod with sockets attached. You'll get it eventually, then have a well deserved cold beer
        Sent from my SM-G973U using Tapatalk
        • twright
          • 707
          #49
          I'm not giving up on this. If anyone wants to help and needs a picture of a cut up subframe bushing, here is one: Click image for larger version  Name:	67787693658__16C69D8E-6ACB-4E9F-8F8F-45C455183C1A.jpg Views:	0 Size:	69.6 KB ID:	10059870
          • bmwman91
            • Oct 2004
            • 3134
            #50
            Having done subframe bushings 3 times now, I have some thoughts.
            1. Unless you can borrow the BMW special puller tools, drop the whole subframe. If you are replacing the subframe bushings, you will probably want to do trailing arm & diff bushings while you are at it. Dropping out the whole rear subframe assembly is honestly easier than trying to do it on-car. Just make sure to cap the flexible brake lines with something that brake fluid won't destroy...if the brake lines drain out completely it might make bleeding a hassle if air gets into the master cylinder.
            2. I've removed bushings both by burning and slitting the outer metal sleeve. The fire solution is toxic and will mess up the powder coating on the subframe. Cutting the sleeve is a lot of work, and carries a risk of damaging the subframe. Last time I did this job, I just paid an auto shop to deal with it on their press.
            3. Installation. I have turned my own tools using iron pipe fittings & Acme threaded rod in the past. That worked OK, but I think that I was about 1Nm away from shearing the rod by the end lol. Last time I did the bushings, I just took the subframe to an auto shop and paid $100 for them to press the old ones out & the new ones in. If you DIY it, you want to use bushing installation lubricant of some sort. Dish soap and water works OK as a DIY installation lubricant.
            Transaction Feedback: LINK
            • monty23psk
              • Mar 2008
              • 1289
              #51
              Thats why I bought the tool years ago and now rent it. Best $50 anyone can spend imho opinion. Can even be used while on the car. Did my e28 like that.
              Alex 88 m5 | 91 318is | 19 Subaru Ascent
              BMW Tool Rentals & Fender Roller
              • twright
                • 707
                #52
                There is one trick I learned on the last installation: When I put the new bushings in, I put them in the freezer for a few hours before. This shrunk them enough that I could push them half of the way in with my fingers.
                • SD-KC
                  • Jan 2018
                  • 116
                  #53
                  I tried the floor Jack method tonight. Froze the bushing and coated the bushing and frame in silicon spray. Didn’t work. Only lifted the car. Going to build the threaded Rod version to pull the bushing into the car.
                  i was wondering. Every build has a socket then washer then nut to pull the bushing into the car. Why not just use a washer?
                  • steel330i
                    • 164
                    #54
                    Remove the subframe, press them out or if no press use heat and lubricant in multiple cycles and get a punch/driver kit from Amazon and a good dead blow.
